teilersen wrote:> > >As for the non-uniform sampling. I don't get what that looks like. Your > >not saying the sampling rate increases as a function of the load > >applied? At any rate it may be a function of something so even though > >your coordinate system may not be time you may have a uniform coordinate > >system. > > To be honest then I am not sure myself what it will look like. The sensor > measures two capacitors between each sample. > One will increase and the other will decrease, but it is the reciprocal > value of the capcitans which are linear with the force so I think it will > be some kind of a s-kurve.Yes but what is the relationship of the sample spacing to real time and what makes it non-uniform. Is it the weight of the object or the speed of the belt? It isn't just randomly taking a sample every now and then is it?> > >You have a sampling of the step response that should be good enough. > >Getting the IR from that would just be a high pass filter that probably > >adds nothing useful. But it might not be a bad idea to look at that. > > Why do I get the IR If I high pass filter the signal?In the digital domain finding the derivative or integral is functionally just a high or low pass filter respectively. That's a bit simplified but not much. The step response is the integral of the IR.> > Jerry wrote that my "trapezoidal" signal will mostely contain low > frequncies.Yes and one might guess that the low frequencies contain the information you want. Finding the IR will involve removing the low frequencies (removes DC completely) so I would guess it wouldn't be that helpful.>If I multiply that with my the IR in the frequency domain then > > I suppose I get the frequency spectrum of the signal I measure. > I do not expext to get the IR back from a simple low pass filtering. I > would expect that I would have to try deconvolution which is hard because > I have zeroes in the frequency domain of the input (the "trapezoidal") > > >What you need to do is find something in there that correlates > >accurately to the weight of the object. Maybe its the total energy over > >a period of time or maybe its the magnitude of a certain frequency at > >some point in the process. Once you know what your looking for you can > >think about the design of a filter to achieve that. > > Sounds like a good idea, but I am not sure how I should do that in > practice?Well you need data for objects of known weight. If you find that certain frequencies remain the same no matter what the object weighs then filtering those frequencies out might be a logical first step. At that point you would know what the filter you want to design is intended to do. My point -jim ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
method for digital filtering
Started by ●February 23, 2006
Reply by ●February 24, 20062006-02-24
Reply by ●November 2, 20062006-11-02
Hi, keep it simple. Here are two easy methods: first low pass filter. I know you don't like but it will do the trick and is the method of choice in many checkweighing applications. However as you are interested in freq. close to DC you should make sure that no other componets of the checkweigher contribute in that region. this is done by increasing the natural freq. of the system i.e. make it lighter and by reducing the size of your rollers, as this will push imbalances into high freq. If you find the filter is to slow do this: move your cut off a bit higher say 30Hz-40Hz this should get rid of electrical noise and mains hum. Now find 3 extremes in your ocillation...these contains all the information about the steady state...given the system is reasonable well behaved. But them is this formula: ss=(a(2)^2-a(1)*a(3))-(2a(2)-a(1)-a(3) a(n) is your extremes...1 the first 2 second.... Have fun tell me if it has worked.... Christian>teilersen wrote: >> >> >As for the non-uniform sampling. I don't get what that looks like.Your>> >not saying the sampling rate increases as a function of the load >> >applied? At any rate it may be a function of something so even though >> >your coordinate system may not be time you may have a uniformcoordinate>> >system. >> >> To be honest then I am not sure myself what it will look like. Thesensor>> measures two capacitors between each sample. >> One will increase and the other will decrease, but it is thereciprocal>> value of the capcitans which are linear with the force so I think itwill>> be some kind of a s-kurve. > >Yes but what is the relationship of the sample spacing to real time and >what makes it non-uniform. Is it the weight of the object or the speed >of the belt? It isn't just randomly taking a sample every now and then >is it? > > >> >> >You have a sampling of the step response that should be good enough. >> >Getting the IR from that would just be a high pass filter thatprobably>> >adds nothing useful. But it might not be a bad idea to look at that. >> >> Why do I get the IR If I high pass filter the signal? > >In the digital domain finding the derivative or integral is functionally >just a high or low pass filter respectively. That's a bit simplified but >not much. The step response is the integral of the IR. > >> >> Jerry wrote that my "trapezoidal" signal will mostely contain low >> frequncies. > >Yes and one might guess that the low frequencies contain the information >you want. Finding the IR will involve removing the low frequencies >(removes DC completely) so I would guess it wouldn't be that helpful. > > >>If I multiply that with my the IR in the frequency domain then >> >> I suppose I get the frequency spectrum of the signal I measure. >> I do not expext to get the IR back from a simple low pass filtering. I >> would expect that I would have to try deconvolution which is hardbecause>> I have zeroes in the frequency domain of the input (the "trapezoidal") >> >> >What you need to do is find something in there that correlates >> >accurately to the weight of the object. Maybe its the total energyover>> >a period of time or maybe its the magnitude of a certain frequency at >> >some point in the process. Once you know what your looking for youcan>> >think about the design of a filter to achieve that. >> >> Sounds like a good idea, but I am not sure how I should do that in >> practice? > >Well you need data for objects of known weight. If you find that certain >frequencies remain the same no matter what the object weighs then >filtering those frequencies out might be a logical first step. At that >point you would know what the filter you want to design is intended to >do. > My point > >-jim > >----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure UsenetNews==---->http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+Newsgroups>----= East and West-Coast Server Farms - Total Privacy via Encryption=---->
