Hi NG, I have a problem regarding normalization when performing cross-correlation: I have a relatively short signal/waveform ("A") which I'm cross-correlating with a longer timeseries ("B") to look for this waveform. Since there are large fluctuations in B, I have decided to apply some sort of normalization scheme to both A and B. So, for A I divided all the samples with the squareroot of the average power of the signal, i.e. sqrt(sum(A(i)^2)/N). As for B, I do the same thing FOR EACH WINDOW OF "B" THAT "A" PASSES IN THE CORRELATION. That is, before the windows are multiplied and summed in the correlation, the segment of B in question undergoes the same treatment as described above. The result looks very strange, and is definately not correct. Do you see any flaws in my method? Thanks! Best, M.L.
Normalization and cross-correlation - what am I doing wrong?
Started by ●February 23, 2006
Reply by ●February 23, 20062006-02-23
Normalized correlation is: sum(A(i)B(i))/sqrt(sum(A(i)^2) sum(B(i)^2)) Where all summations are over the same number of elements N (regardless of the actual length of each signal, which may have elements that do not participate in the correlation). M.L. wrote:> Hi NG, > > I have a problem regarding normalization when performing > cross-correlation: > > I have a relatively short signal/waveform ("A") which I'm > cross-correlating with a longer timeseries ("B") to look for this > waveform. Since there are large fluctuations in B, I have decided to > apply some sort of normalization scheme to both A and B. So, for A I > divided all the samples with the squareroot of the average power of the > signal, i.e. sqrt(sum(A(i)^2)/N). As for B, I do the same thing FOR > EACH WINDOW OF "B" THAT "A" PASSES IN THE CORRELATION. That is, before > the windows are multiplied and summed in the correlation, the segment > of B in question undergoes the same treatment as described above. > > The result looks very strange, and is definately not correct. Do you > see any flaws in my method? > > > Thanks! > > Best, > > M.L. >
the description of your problem is not easy to understand. why normalize with power? I would do it like this a_new=a/max(a); b_new=b/max(b); cross-correlate a_new with b_new and look for peak(s) in cross-correlation. can you upload screenshots to some webpage so we can see why it looks "strange"? which language are you programming in?
Hi, Thanks - both of you. I changed my code (MatLab by the way) to use the formula stated in twains post and now it seems to work much better. I think my mistake was that I divided the sqrt(power) with the number of samples in the window. Apart from that, I had the same calculation.. Thanks! I appreciate it.. Best, M.L.
