Hello, I am working on getting fftw working, and I feel like I'm almost there, but have run into a new problem. I am performing a dft in several loops using the guru interface, where the input array is 4D, and the FFT is taken on the last dimension. This seemed to be mostly working earlier this week, but is now giving me problems; I'm not sure what I might have changed to cause this. I am using borland c++ on windows, and have compiled my own fftw library, and have run the bench program on it to test that it works as expected (as far as I can tell). I used: bench -v1 --verify 64 128 4096 10000 100000 and did not get any errors. I am using the guru split interface with a real to complex calculation, ie: plan = fftw_plan_guru_split_dft_r2c(1, dimsPre, 3, howmany_dimsPre, xPre, outRe, outIm, FFTW_MEASURE); xPre has been initialized and has values copied from another input; outRe and outIm have been initialized with: double *xPre, *outRe, *outIm; ... outRe = new double[nSamples]; outRe = new double[nSamples]; (nSamples takes into account the fact that the output will have nfft/2+1 samples per iteration, as does the howmany_dimsPre array). When the plan is executed with: fftw_execute_split_dft_r2c(plan, xPre, outRe, outIm); the values in the outRe are reasonable, but the outIm values are in the 1E+/-300 range. I only want the magnitude, so I'm using: sqrt(outRe[n] * outRe[n] + outIm[n]*outIm[n]) which obviously gives floating point overflow exceptions. Any ideas on what might be causing this? Are there additional tests I can run with bench to ensure that the library is actually working correctly? Thanks! Adam
fftw- problems with imaginary using split format
Started by ●February 25, 2006
Reply by ●February 25, 20062006-02-25
jawilson wrote:> Any ideas on what might be causing this? Are there additional tests I > can run with bench to ensure that the library is actually working > correctly?You can run e.g.: tests/bench -y r/8x10x4x6 to test correctness for a 4d real-input ("r") transform in split-complex ("/") format. If this passes, most likely you have some error in the strides etcetera you are passing to FFTW. Figuring out how to deal correctly with multi-dimensional array formats seems to take most people some time.
