Hello, Can someone explain what this mean? Everytime I start CCS it gave me a message saying the following: "C6x11 DSK (TI)/CPU_1: The Startup GEL File was specified in the Setup Program for this processor, and will be used instead of the one specified on the command line." What is CPU_1? And what is this command line that it is talking about?
GEL
Started by ●July 14, 2004
Reply by ●July 14, 20042004-07-14
Hello Peter, Go to your directory for CCS and run Setup Code Composer Studio. Do not import config (close). Then you'll see on the left side "My System->Your Emulator->CPU_1" This is your "CPU_1" you can also rename it to grimblfix ;-) Remember that you can have more than one CPU on a board (JTAG-Chain). Remember that you can have more than one board of CPU's (e.g. one with a single chip and one with more). Further Remember that you can have more than one Emulator (e.g. a 510 and a DSK and a 560...). Right click on emulator -> properties and see Board properties->Startup GEL File(s) Here your target specific GEL-file is mentioned. Despite all this the CCS-help is not that worse. It shourely will tell you what a GEL File is for. About the command line I can't help. May you start CCS with added commands in the command line ? Good luck, Wolfgang "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag news:tQ2Jc.13106$ek5.12365@pd7tw2no...> Hello, > Can someone explain what this mean? Everytime I start CCS it gave me a > message saying the following: > "C6x11 DSK (TI)/CPU_1: > The Startup GEL File was specified in the Setup Program for this processor, > and will be used instead of the one specified on the command line." > > What is CPU_1? And what is this command line that it is talking about? > >
Hello, I'm sorry but what is this Setup program that we are referring to here? "Wolfgang" <never@nowhere.com> wrote in message news:cd2k3k$kod$07$1@news.t-online.com...> Hello Peter, > > Go to your directory for CCS and run Setup Code Composer Studio. > Do not import config (close). Then you'll see on the left side > "My System->Your Emulator->CPU_1" > This is your "CPU_1" you can also rename it to grimblfix ;-) > Remember that you can have more than one CPU on a board (JTAG-Chain). > Remember that you can have more than one board of CPU's (e.g. one with asingle chip and one with more).> Further Remember that you can have more than one Emulator (e.g. a 510 anda DSK and a 560...).> > Right click on emulator -> properties and see Board properties->StartupGEL File(s)> Here your target specific GEL-file is mentioned. > > Despite all this the CCS-help is not that worse. It shourely will tell youwhat a GEL File is for.> > About the command line I can't help. May you start CCS with added commandsin the command line ?> > Good luck, >Wolfgang> > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitragnews:tQ2Jc.13106$ek5.12365@pd7tw2no...> > Hello, > > Can someone explain what this mean? Everytime I start CCS it gave me a > > message saying the following: > > "C6x11 DSK (TI)/CPU_1: > > The Startup GEL File was specified in the Setup Program for thisprocessor,> > and will be used instead of the one specified on the command line." > > > > What is CPU_1? And what is this command line that it is talking about? > > > >
Hello Peter, The "Setup program" is a separat program comming with CCS. Normally you've: - Code Composer Studio - Setup Code Composer Studio - Configuration Tool This is for 5000 and 6000 'er CCS-Version the same. "Setup Code Composer Studio" is missing if you've a DSK (you don't need to setup as you can't change from DSK to another board). Good luck, Wolfgang P.S.: Don't know what you have. Hence Help is limited. ------------------------------------------------------------------------------------------------------------ "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag news:uQ5Jc.13361$Mr4.4750@pd7tw1no...> Hello, > > I'm sorry but what is this Setup program that we are referring to here? > > "Wolfgang" <never@nowhere.com> wrote in message > news:cd2k3k$kod$07$1@news.t-online.com... > > Hello Peter, > > > > Go to your directory for CCS and run Setup Code Composer Studio. > > Do not import config (close). Then you'll see on the left side > > "My System->Your Emulator->CPU_1" > > This is your "CPU_1" you can also rename it to grimblfix ;-) > > Remember that you can have more than one CPU on a board (JTAG-Chain). > > Remember that you can have more than one board of CPU's (e.g. one with a > single chip and one with more). > > Further Remember that you can have more than one Emulator (e.g. a 510 and > a DSK and a 560...). > > > > Right click on emulator -> properties and see Board properties->Startup > GEL File(s) > > Here your target specific GEL-file is mentioned. > > > > Despite all this the CCS-help is not that worse. It shourely will tell you > what a GEL File is for. > > > > About the command line I can't help. May you start CCS with added commands > in the command line ? > > > > Good luck, > > > Wolfgang > > > > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag > news:tQ2Jc.13106$ek5.12365@pd7tw2no... > > > Hello, > > > Can someone explain what this mean? Everytime I start CCS it gave me a > > > message saying the following: > > > "C6x11 DSK (TI)/CPU_1: > > > The Startup GEL File was specified in the Setup Program for this > processor, > > > and will be used instead of the one specified on the command line." > > > > > > What is CPU_1? And what is this command line that it is talking about? > > > > > > > >
Reply by ●July 15, 20042004-07-15
Hello, I have the DSK. So how do I do what you said about the GEL file if I don't have the setup program you were describing? "Wolfgang" <never@nowhere.com> wrote in message news:cd31fo$oop$06$1@news.t-online.com...> Hello Peter, > > The "Setup program" is a separat program comming with CCS. > Normally you've: > - Code Composer Studio > - Setup Code Composer Studio > - Configuration Tool > This is for 5000 and 6000 'er CCS-Version the same. > "Setup Code Composer Studio" is missing if you've a DSK > (you don't need to setup as you can't change from DSK to another board). > > Good luck, Wolfgang > > P.S.: Don't know what you have. Hence Help is limited. > > ------------------------------------------------------------------------------------------------------------> "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitragnews:uQ5Jc.13361$Mr4.4750@pd7tw1no...> > Hello, > > > > I'm sorry but what is this Setup program that we are referring to here? > > > > "Wolfgang" <never@nowhere.com> wrote in message > > news:cd2k3k$kod$07$1@news.t-online.com... > > > Hello Peter, > > > > > > Go to your directory for CCS and run Setup Code Composer Studio. > > > Do not import config (close). Then you'll see on the left side > > > "My System->Your Emulator->CPU_1" > > > This is your "CPU_1" you can also rename it to grimblfix ;-) > > > Remember that you can have more than one CPU on a board (JTAG-Chain). > > > Remember that you can have more than one board of CPU's (e.g. one witha> > single chip and one with more). > > > Further Remember that you can have more than one Emulator (e.g. a 510and> > a DSK and a 560...). > > > > > > Right click on emulator -> properties and see Boardproperties->Startup> > GEL File(s) > > > Here your target specific GEL-file is mentioned. > > > > > > Despite all this the CCS-help is not that worse. It shourely will tellyou> > what a GEL File is for. > > > > > > About the command line I can't help. May you start CCS with addedcommands> > in the command line ? > > > > > > Good luck, > > > > > Wolfgang > > > > > > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag > > news:tQ2Jc.13106$ek5.12365@pd7tw2no... > > > > Hello, > > > > Can someone explain what this mean? Everytime I start CCS it gaveme a> > > > message saying the following: > > > > "C6x11 DSK (TI)/CPU_1: > > > > The Startup GEL File was specified in the Setup Program for this > > processor, > > > > and will be used instead of the one specified on the command line." > > > > > > > > What is CPU_1? And what is this command line that it is talkingabout?> > > > > > > > > > > >
Hello, Ok. You can't. Unfortunately I don't have a DSK any more, so I can't help. Look if it is possible to give commands when starting CCS - But I don't know. Good luck, Wolfgang P.S.: CCS does not bring this message after install. Don't you remember what you've done to get it ? (Sometimes I whish I'd have a Video-Camera behind me ...) "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag news:bmpJc.23609$Mr4.21159@pd7tw1no...> Hello, > > I have the DSK. So how do I do what you said about the GEL file if I don't > have the setup program you were describing? > > "Wolfgang" <never@nowhere.com> wrote in message > news:cd31fo$oop$06$1@news.t-online.com... > > Hello Peter, > > > > The "Setup program" is a separat program comming with CCS. > > Normally you've: > > - Code Composer Studio > > - Setup Code Composer Studio > > - Configuration Tool > > This is for 5000 and 6000 'er CCS-Version the same. > > "Setup Code Composer Studio" is missing if you've a DSK > > (you don't need to setup as you can't change from DSK to another board). > > > > Good luck, Wolfgang > > > > P.S.: Don't know what you have. Hence Help is limited. > > > > -------------------------------------------------------------------------- > ---------------------------------- > > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag > news:uQ5Jc.13361$Mr4.4750@pd7tw1no... > > > Hello, > > > > > > I'm sorry but what is this Setup program that we are referring to here? > > > > > > "Wolfgang" <never@nowhere.com> wrote in message > > > news:cd2k3k$kod$07$1@news.t-online.com... > > > > Hello Peter, > > > > > > > > Go to your directory for CCS and run Setup Code Composer Studio. > > > > Do not import config (close). Then you'll see on the left side > > > > "My System->Your Emulator->CPU_1" > > > > This is your "CPU_1" you can also rename it to grimblfix ;-) > > > > Remember that you can have more than one CPU on a board (JTAG-Chain). > > > > Remember that you can have more than one board of CPU's (e.g. one with > a > > > single chip and one with more). > > > > Further Remember that you can have more than one Emulator (e.g. a 510 > and > > > a DSK and a 560...). > > > > > > > > Right click on emulator -> properties and see Board > properties->Startup > > > GEL File(s) > > > > Here your target specific GEL-file is mentioned. > > > > > > > > Despite all this the CCS-help is not that worse. It shourely will tell > you > > > what a GEL File is for. > > > > > > > > About the command line I can't help. May you start CCS with added > commands > > > in the command line ? > > > > > > > > Good luck, > > > > > > > Wolfgang > > > > > > > > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag > > > news:tQ2Jc.13106$ek5.12365@pd7tw2no... > > > > > Hello, > > > > > Can someone explain what this mean? Everytime I start CCS it gave > me a > > > > > message saying the following: > > > > > "C6x11 DSK (TI)/CPU_1: > > > > > The Startup GEL File was specified in the Setup Program for this > > > processor, > > > > > and will be used instead of the one specified on the command line." > > > > > > > > > > What is CPU_1? And what is this command line that it is talking > about? > > > > > > > > > > > > > > > > > >
Reply by ●July 18, 20042004-07-18
Hello, Just realized that I do have the Setup CCS utility. I can access this by starting CCS, and then go File->Setup CCS. I do see also the GEL file as you instructed and now understand that this is the file the message was referring to during CCS startup. So, the question is do CCS not normally have a GEL file after installed? "Wolfgang" <never@nowhere.com> wrote in message news:cd5inl$nmc$06$1@news.t-online.com...> Hello, > > Ok. You can't. Unfortunately I don't have a DSK any more, so I can't help. > Look if it is possible to give commands when starting CCS - But I don'tknow.> > Good luck, Wolfgang > > P.S.: CCS does not bring this message after install. Don't you rememberwhat you've done to get it ?> (Sometimes I whish I'd have a Video-Camera behind me ...) > > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitragnews:bmpJc.23609$Mr4.21159@pd7tw1no...> > Hello, > > > > I have the DSK. So how do I do what you said about the GEL file if Idon't> > have the setup program you were describing? > > > > "Wolfgang" <never@nowhere.com> wrote in message > > news:cd31fo$oop$06$1@news.t-online.com... > > > Hello Peter, > > > > > > The "Setup program" is a separat program comming with CCS. > > > Normally you've: > > > - Code Composer Studio > > > - Setup Code Composer Studio > > > - Configuration Tool > > > This is for 5000 and 6000 'er CCS-Version the same. > > > "Setup Code Composer Studio" is missing if you've a DSK > > > (you don't need to setup as you can't change from DSK to anotherboard).> > > > > > Good luck, Wolfgang > > > > > > P.S.: Don't know what you have. Hence Help is limited. > > > > > > -------------------------------------------------------------------------- > > ---------------------------------- > > > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag > > news:uQ5Jc.13361$Mr4.4750@pd7tw1no... > > > > Hello, > > > > > > > > I'm sorry but what is this Setup program that we are referring tohere?> > > > > > > > "Wolfgang" <never@nowhere.com> wrote in message > > > > news:cd2k3k$kod$07$1@news.t-online.com... > > > > > Hello Peter, > > > > > > > > > > Go to your directory for CCS and run Setup Code Composer Studio. > > > > > Do not import config (close). Then you'll see on the left side > > > > > "My System->Your Emulator->CPU_1" > > > > > This is your "CPU_1" you can also rename it to grimblfix ;-) > > > > > Remember that you can have more than one CPU on a board(JTAG-Chain).> > > > > Remember that you can have more than one board of CPU's (e.g. onewith> > a > > > > single chip and one with more). > > > > > Further Remember that you can have more than one Emulator (e.g. a510> > and > > > > a DSK and a 560...). > > > > > > > > > > Right click on emulator -> properties and see Board > > properties->Startup > > > > GEL File(s) > > > > > Here your target specific GEL-file is mentioned. > > > > > > > > > > Despite all this the CCS-help is not that worse. It shourely willtell> > you > > > > what a GEL File is for. > > > > > > > > > > About the command line I can't help. May you start CCS with added > > commands > > > > in the command line ? > > > > > > > > > > Goodluck,> > > > > > > > > Wolfgang > > > > > > > > > > "Peter Choi" <choi@mecca.ca> schrieb im Newsbeitrag > > > > news:tQ2Jc.13106$ek5.12365@pd7tw2no... > > > > > > Hello, > > > > > > Can someone explain what this mean? Everytime I start CCS itgave> > me a > > > > > > message saying the following: > > > > > > "C6x11 DSK (TI)/CPU_1: > > > > > > The Startup GEL File was specified in the Setup Program forthis> > > > processor, > > > > > > and will be used instead of the one specified on the commandline."> > > > > > > > > > > > What is CPU_1? And what is this command line that it is talking > > about? > > > > > > > > > > > > > > > > > > > > > > > >
Reply by ●July 19, 20042004-07-19
