Hi all, I have been working on AMR-WB,on ARM9E and i am using ADS 1.2 tools. Please clarity this doubt. 1. How to know the complexity of a program? I am using profiling method as given in AXD Deguggers Guide (pdf document). a.Select File-> Load the image In that dialog,enable the 'profile', flat sampling and make the interval as 100 micro.sec. b.Select Options->Profiling-> Toggle Profiling c.Execute the program d.Select Options->Profiling-> Write to file e.Save the file(xyz.prf) in that dialog. But i am unable to open xyz.prf file to see the profiling information? Is this correct procedure to know the complexity of a program? Thanks in advance. Regards, rajanikanth.
complexity of a program in ARM 9E
Started by ●March 2, 2006
