multivariate cepstrum
Started by Francis Woolfe July 13, 2004
Hi
I know what the cepstrum of a univariate ARMA model is. Does anyone know how
to extend the idea to multivariate ARMA processes? Recomendations for a good
textbook?
MODEL:
x(t) = SUM( k=1..P, a(k)x(t-k) ) + SUM( k=1..Q, b(k)w(t-k) )
where w(t) ~ N(0,S) are normally distributed multivariate random variables,
and x(t) is a z by 1 vector.
DEFINITION FOR UNIVARIATE CASE, z=1:
Simply put, it's the fourier transform of the power spectrum.
A(z) = "Z"-transf. of a(k) = SUM( k=1..P, a(k)z^(-k) );
B(z) = "Z"-transf. of b(k) = SUM( k=1..Q, b(k)z^(-k) );
H(z) = system function = B(z) / A(z)
log H(z) = SUM( k=0..infinity, h(k)z^(-k) )
and h(k) are the cepstrum coefficients!
USES OF CEPSTRA
You can define a "cepstral distance", eg in natural language processing.
It's a measure of disparity
between ARMA models (in this case).
ANY help at all would be grately appreciated. Thanks very much -- Franco.
(also posted to: sci.stat.math, sci.stat.consult, comp.dsp,
comp.ai.nat-lang)
"Francis Woolfe" <franco.woolfe@ntlworld.com> wrote in message
news:UyXIc.146$3E6.69@newsfe2-win.ntli.net...
> Hi > > I know what the cepstrum of a univariate ARMA model is. Does anyone know
how
good
> textbook? > > MODEL: > > x(t) = SUM( k=1..P, a(k)x(t-k) ) + SUM( k=1..Q, b(k)w(t-k) ) > > where w(t) ~ N(0,S) are normally distributed multivariate random
variables,
> and x(t) is a z by 1 vector. > > DEFINITION FOR UNIVARIATE CASE, z=1: > > Simply put, it's the fourier transform of the power spectrum. > > A(z) = "Z"-transf. of a(k) = SUM( k=1..P, a(k)z^(-k) ); > B(z) = "Z"-transf. of b(k) = SUM( k=1..Q, b(k)z^(-k) ); > > H(z) = system function = B(z) / A(z) > > log H(z) = SUM( k=0..infinity, h(k)z^(-k) ) > > and h(k) are the cepstrum coefficients! > > USES OF CEPSTRA > > You can define a "cepstral distance", eg in natural language processing. > It's a measure of disparity > between ARMA models (in this case). > > > ANY help at all would be grately appreciated. Thanks very much -- Franco. > > (also posted to: sci.stat.math, sci.stat.consult, comp.dsp, > comp.ai.nat-lang) > >
They are going to be Cepstrum matrices - not coefficients with your ARMA model. Tom
"Francis Woolfe" <franco.woolfe@ntlworld.com> wrote in message news:<UyXIc.146$3E6.69@newsfe2-win.ntli.net>...
> Hi > > I know what the cepstrum of a univariate ARMA model is. Does anyone know how > to extend the idea to multivariate ARMA processes? Recomendations for a good > textbook?
I have seen the 2D cepstrum mentioned in the context of image processing. You might want to at sci.image.processing as well. Rune
