Hello, I am working on my senior design project and was hoping I could find some help. I need to design a MATLAB program which generates multiple beams for a 4x4 planar antenna array. Right now, I am assuming that I know the direction of the incoming signals (theta and phi). I have some source code which generates the beam for one incoming signal. I am not quite sure how I can extend the code to handle multiple beams. If anyone can provide any tips or source code that I could look at, I would greatly appreciate it. If I need to provide more information, please let me know. Thanks.
Multiple Beam Digital Beamforming
Started by ●March 6, 2006
Reply by ●March 6, 20062006-03-06
<chimera451@gmail.com> wrote in message news:1141665552.481797.250650@u72g2000cwu.googlegroups.com...> Hello, > > I am working on my senior design project and was hoping I could find > some help. I need to design a MATLAB program which generates multiple > beams for a 4x4 planar antenna array. Right now, I am assuming that I > know the direction of the incoming signals (theta and phi). I have some > source code which generates the beam for one incoming signal. I am not > quite sure how I can extend the code to handle multiple beams. ><...> You could just repeat it. If you've got no significant non-linearities then repeating the whole thing for each beam, ensuring that you use the same element locations and patterns, is simple. best of luck - Mike
chimera451@gmail.com wrote:> I am working on my senior design project and was hoping I could find > some help. I need to design a MATLAB program which generates multiple > beams for a 4x4 planar antenna array. Right now, I am assuming that I > know the direction of the incoming signals (theta and phi). I have some > source code which generates the beam for one incoming signal. I am not > quite sure how I can extend the code to handle multiple beams. > > If anyone can provide any tips or source code that I could look at, I > would greatly appreciate it. If I need to provide more information, > please let me know. Thanks. >Basically a beamformer is nothing more than a variable delay for each receive channel, followed by a summing node. That is how medical ultrasound scanners work and there should be plenty of literature. If multiple directions are to be received at the same time you tap off from the delay lines (or algorithm) at the correct spot, where your signals would be in phase for the selected direction. In ultrasound there is also 'dynamic focus' where the taps are adjusted with time-of-flight but I guess you don't have to focus really close in this case. BTW, Skolnik's "Radar Handbook" is an excellent resource here. Regards, Joerg http://www.analogconsultants.com
Reply by ●March 7, 20062006-03-07
chimera451@gmail.com wrote:> Hello, > > I am working on my senior design project and was hoping I could find > some help. I need to design a MATLAB program which generates multiple > beams for a 4x4 planar antenna array. Right now, I am assuming that I > know the direction of the incoming signals (theta and phi). I have some > source code which generates the beam for one incoming signal. I am not > quite sure how I can extend the code to handle multiple beams. > > If anyone can provide any tips or source code that I could look at, I > would greatly appreciate it. If I need to provide more information, > please let me know. Thanks.I think the beamformer basically uses the single-beam ealgorithm and scans theta and phi. It's quite expensive, computationally speaking. Rune
Reply by ●March 8, 20062006-03-08
