Hi all, I've been looking at MIMO-OFDM based systems for about the last week (802.11n and 802.16) and have a couple of questions that I was hoping someone out there could answer. Here goes: 1) I want to look (in detail) at one of the more computationally demanding blocks of a typical MIMO-OFDM reciever. The main blocks that I have really been looking at have been a QR-based channel estimator, a Sphere decoder and Turbo decoder. What I would like to know is, if you were given the task of implementing a MIMO-OFDM system, what "block" or section of the algorithm would you consider to be a most computationally complex, i.e. what block is the limiting factor in terms of implementation complexity? 2) Are there any models freely available on the internet that model a MIMO-OFDM system, MATLAB, C++ etc...? 4) If a model is not available on the internet, I will implement my own. What components of such a simulation are important in producing a representative MIMO-OFDM based system? Do you know of any other (simpler) models that work along the same lines (802.11a for example) that are freely available upon which I may base my work? 3) Up until now I've been looking a papers on MIMO-OFDM based systems, do you know of any books on this subject? Thanks very much for the help, Stephen
MIMO-OFDM systems
Started by ●March 7, 2006
Reply by ●March 8, 20062006-03-08
Dear, MIMO OFDM are two separate topics (MIMO + OFDM). I guess you should tackle each topic separately in the begining. YOu can start by studying and reading about OFDM,Implement you own OFDM system, then you implement a MIMO channel system. YOu can check this link for OFDM books: http://www.amazon.com/exec/obidos/search-handle-url/ref=br_ss_hs/002-4286791-4825616?platform=gurupa&url=index%3Dstripbooks%3Arelevance-above%26dispatch%3Dsearch%26results-process%3Dbin&field-keywords=OFDM Thanks Hany Steve wrote:> Hi all, > > I've been looking at MIMO-OFDM based systems for about the last week > (802.11n and 802.16) and have a couple of questions that I was hoping > someone out there could answer. Here goes: > > 1) I want to look (in detail) at one of the more computationally > demanding blocks of a typical MIMO-OFDM reciever. The main blocks that > I have really been looking at have been a QR-based channel estimator, a > Sphere decoder and Turbo decoder. What I would like to know is, if you > were given the task of implementing a MIMO-OFDM system, what "block" or > section of the algorithm would you consider to be a most > computationally complex, i.e. what block is the limiting factor in > terms of implementation complexity? > > 2) Are there any models freely available on the internet that model a > MIMO-OFDM system, MATLAB, C++ etc...? > > 4) If a model is not available on the internet, I will implement my > own. What components of such a simulation are important in producing a > representative MIMO-OFDM based system? Do you know of any other > (simpler) models that work along the same lines (802.11a for example) > that are freely available upon which I may base my work? > > 3) Up until now I've been looking a papers on MIMO-OFDM based systems, > do you know of any books on this subject? > > Thanks very much for the help, > > Stephen
Thanks for the help, I'm aware that MIMO and OFDM are two different concepts: one is a multicarrier modulation scheme and the other is a method of improving diversity on a wireless channel. What I would like to know is how these two scheme fit together in a system and what the most significant block in such a system would be. Stephen
