Hello I�m wondering what rules applies if I�m sampling a signal in short bursts? Lets say I want to sample a level and I do that by sampling 10 sample points at 1 �s apart. Then I calculate I mean value of these 10 points. The sampling frequency in the bursts are 1 MHz. Should I calculate my antialias filter by that value (fN = 500 kHz) ?
Sampling in short bursts?
Started by ●March 8, 2006
Reply by ●March 8, 20062006-03-08
Hello Helmut,> > I�m wondering what rules applies if I�m sampling a signal in short bursts? > Lets say I want to sample a level and I do that by sampling 10 sample points > at 1 �s apart. Then I calculate I mean value of these 10 points. The > sampling frequency in the bursts are 1 MHz. Should I calculate my antialias > filter by that value (fN = 500 kHz) ? > >If you expect noise above 500kHz in the signal then that would make sense. I'd place it a bit lower though since you can't really make a brickwall filter. It will have a slope even if it was a long Tchebychev. Regards, Joerg http://www.analogconsultants.com
