Hi, I'm looking for any good references for viterbi implementations that allow for a data rate higher than the clock rate. As I understand it, this implies using butterflies in the trellis of higher than radix 2. Any help is much appreciated. Phil
Viterbi Decoder: Bit Rate > Clock Rate
Started by ●March 8, 2006
Reply by ●March 9, 20062006-03-09
Data rate higher than clock rate => the viterbi decoder operates on symbols, rather than on bits. You need some kind of TCM decoder? But what has that got to do anything with butterflies and radix 2? What exactly are you going to decode with your Viterbi decoder?
What I am trying to do is increase the throughput of a viterbi decoder that is currently contrained by the FPGA clock rate. What you say is right. The decoder would have to operate on symbols rathter than on bits. I may have been incorrect to assume that this was tied to the use of radix 2 butterflies in the trellis. Do you know of any papers to do with the symbol decoders to solve my bottleneck?
Reply by ●March 13, 20062006-03-13
In case anyone is interested, I did end up finding something related to speeding up the viterbi decoder. It in not quite what I was expecting, but seems promissing. The reference is the following: "High-Speed Parallel Viterbi Decoding: Algorithm and VLSI-Architecture", G. Fettweis and H. Meyr, IEEE Communication Magazine, May 1991. BR, Phil
