Hey, Im working with an ADSP-21364 SHARC processor and EZKIT. I have a problem when trying to integrate two programs that use the serial ports. My first program is based on the "Block based talkthrough" example, SPORT0 is used to take audio input from the ADC and SPORT2 is used to output the processed audio to a DAC. This stand-alone program functions correctly. My second program implements a UART receive on serial port 3B, this is based on the Eng-to-Eng note EE-191. Bytes are received through DAI pin 5 and stored in a buffer. This stand-alone program also functions correctly. My problem comes when combining the two programs. As the programs use different serial ports and different DAI pins I didn't think there would be a problem. However when I combined the programs the audio processing works but the UART receiver does not. (Some random data received, no correct data). Through debugging I have traced the problem down to this line in the SRU config: SRU(DAI_PB_07_O, DAI_PB_13_I); When this line is commented out the UART receiver functions correctly but the audio processing program stops outputting audio. I understand that this SRU config statement is connecting the ADC clk directly to the DAC clk, why would this interfere with my UART receive program? Many Thanks, Ronan O'Malley
sharc serial port sru config problem
Started by ●March 9, 2006
Reply by ●March 9, 20062006-03-09
"omalley.ronan@gmail.com" <omalley.ronan@gmail.com> wrote in news:1141908665.342538.135700@i39g2000cwa.googlegroups.com:> Hey, > > Im working with an ADSP-21364 SHARC processor and EZKIT. > > I have a problem when trying to integrate two programs that use the > serial ports. > > My first program is based on the "Block based talkthrough" example, > SPORT0 is used > to take audio input from the ADC and SPORT2 is used to output the > processed audio to > a DAC. This stand-alone program functions correctly. > > My second program implements a UART receive on serial port 3B, this is > based on the > Eng-to-Eng note EE-191. Bytes are received through DAI pin 5 and > stored in a > buffer. This stand-alone program also functions correctly. > > My problem comes when combining the two programs. As the programs > use different > serial ports and different DAI pins I didn't think there would be a > problem. > > However when I combined the programs the audio processing works but the > UART > receiver does not. (Some random data received, no correct data). > Through debugging I > have traced the problem down to this line in the SRU config: > > SRU(DAI_PB_07_O, DAI_PB_13_I); > > When this line is commented out the UART receiver functions correctly > but the audio > processing program stops outputting audio. > > I understand that this SRU config statement is connecting the ADC clk > directly to > the DAC clk, why would this interfere with my UART receive program? > > Many Thanks, > > Ronan O'Malley > >If you are using different DAI lines, SPORTs etc., there shouldn't be a problem. Could you have a problem with interference between interrupt handlers? For example, if you are using secondary DAGs and Registers for ISRs (which is my perference), make sure that nesting is off or that the higher priority ISR preserves any registers and DAGs used by the lower priority interrupt. I have programs that use a variation of the UART from EE-191 with two independent sports running I2S. My application runs on a 21262 which is essentially the same for this discussion. My guess is you just have the typical dumb mistake (the one that is obvious after you find it). Clark's Law (Rule of 10): All bugs take 10 seconds, 10 minutes, 10 hours or 10 days to solve (and they're all dumb shits) Clark's Law Reboot: Clark's Law can be reset by going home. The problem is usually resolved wthin 1 mile of the office. Clark's Law Reminder: When you are absolutely sure that you have done everything correct, and are clearly moving toward the 10 hour metric, reread the errata. When the 10 hours have passed, you may be a future contributor to the errata list, or of course, one of your peers shows you that it was actually a dumb shit on your part. At this point, I am usually more relieved than annoyed, and I usually owe someone a beer or two. I claim all these laws as my own but I am sure they have been discovered and rediscovered many times before and after me. Dave Clark's Law (my father): Murphy was a god damned optimist! I don't think he claims this is uniquely his observation either. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
ha ha, Thanks Al, at least after the day i've had, i can come out with a smile! :) "For example, if you are using secondary DAGs and Registers for ISRs (which is my perference), make sure that nesting is off or that the higher priority ISR preserves any registers and DAGs used by the lower priority interrupt. " Im actually coding everything in C, could it be that the assembly generated for each of the ISR's is accessing the same registers? pardon the pun but this is really bugging me, Ronan Ronan
"omalley.ronan@gmail.com" <omalley.ronan@gmail.com> wrote in news:1141933260.496829.288400@v46g2000cwv.googlegroups.com:> ha ha, > > Thanks Al, at least after the day i've had, i can come out with a > smile! :) > > "For example, if you are using secondary DAGs and Registers for ISRs > (which is my perference), make sure that nesting is off or that the > higher priority ISR preserves any registers and DAGs used by the lower > priority interrupt. " > > Im actually coding everything in C, could it be that the assembly > generated for each of the ISR's is accessing the same registers? > > pardon the pun but this is really bugging me, > > Ronan > > Ronan >I never write C ISRs since they tend to save everything. I prefer short ISRs and therefore, I usually pass semaphores to the foreground loop to execute most everything. An assembly ISR looks like this (assuming no nesting): PUSH STS; // Enable secondary registers & DAGs BIT SET MODE1 SRRFL | SRRFH | SRD1L | SRD1H | SRD2L | SRD2H; assembly instructions....... POP STS; RTI; The total overhead is three instructions not counting the return. I doubt that the C ISR is accessing the same registers even with nesting. Try turning the nesting off, then they will always be independent. This will be a sanity check. You might try posting to the adsp yahoo group. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Reply by ●March 10, 20062006-03-10
