Hi, I am very confused about the names of discrete wavelet transform and I don't know what to do. In the book "Wavelets and subband coding" and in the book "Introduction to data compression" says that the discrete-time wavelet transform is a wavelet series that uses continuous function but the corresponing transform is discrete. The discrete wavelet transform is the one that everything is discrete.in the book "Data compression the complete reference" the writer inserts another transform the integer wavelet transform. Is the integer wavelet transform the same with the discrete wavelet transform? I've seen also and the name fast wavelet transform. I am very confused. In the website "A Really Friendly Guide to wavelets" I think that the writer with the phrase "discrete wavelet transform" means the discrete-time wavelet transform. WHICH IS FINALLY THE DISCRETE WAVELET TRANSFORM????? PLEASE HELP!
discrete-time wavelet transform vs discrete wavelet transform vs integer wavelet transform
Started by ●March 12, 2006
Reply by ●March 13, 20062006-03-13
leonadavinci@gmail.com wrote:> Hi, > > I am very confused about the names of discrete wavelet transform and I > don't know what to do. > > In the book "Wavelets and subband coding" and in the book "Introduction > to data compression" > says that the discrete-time wavelet transform is a wavelet series that > uses continuous function but the corresponing transform is discrete. > The discrete wavelet transform is the one that everything is > discrete.in the book "Data compression the complete reference" the > writer inserts another transform the integer wavelet transform. Is the > integer wavelet transform the same with the discrete wavelet transform? > I've seen also and the name fast wavelet transform. I am very confused. > In the website "A Really Friendly Guide to wavelets" I think that the > writer with the phrase "discrete wavelet transform" means the > discrete-time wavelet transform. WHICH IS FINALLY THE DISCRETE WAVELET > TRANSFORM????? PLEASE HELP!I think the discrete-time wt is used to mean wavelet transform of continuous signals with discrete sampling. I.e you calculate the inner product (integral) at discrete points in time and scale. In discrete wavelet transform you only calculate the inner products of the continuous signal and the scaling function at one scale and for discrete points in time. From there on you use discrete dyadic filter bank to calculate the rest of the decomposition (i.e approx and detail coefficients for the rest of the scales). This is also referred to as Fast Wavelet Transform. -- Jani Huhtanen Tampere University of Technology, Pori
Jani Huhtanen wrote:> leonadavinci@gmail.com wrote: > > > Hi, > > > > I am very confused about the names of discrete wavelet transform and I > > don't know what to do. > > > > In the book "Wavelets and subband coding" and in the book "Introduction > > to data compression" > > says that the discrete-time wavelet transform is a wavelet series that > > uses continuous function but the corresponing transform is discrete. > > The discrete wavelet transform is the one that everything is > > discrete.in the book "Data compression the complete reference" the > > writer inserts another transform the integer wavelet transform. Is the > > integer wavelet transform the same with the discrete wavelet transform? > > I've seen also and the name fast wavelet transform. I am very confused. > > In the website "A Really Friendly Guide to wavelets" I think that the > > writer with the phrase "discrete wavelet transform" means the > > discrete-time wavelet transform. WHICH IS FINALLY THE DISCRETE WAVELET > > TRANSFORM????? PLEASE HELP! > > I think the discrete-time wt is used to mean wavelet transform of continuous > signals with discrete sampling. I.e you calculate the inner product > (integral) at discrete points in time and scale. > > In discrete wavelet transform you only calculate the inner products of the > continuous signal and the scaling function at one scale and for discrete > points in time. From there on you use discrete dyadic filter bank to > calculate the rest of the decomposition (i.e approx and detail coefficients > for the rest of the scales). This is also referred to as Fast Wavelet > Transform. > > -- > Jani Huhtanen > Tampere University of Technology, PoriIs there any good book that explain these things?
Reply by ●March 14, 20062006-03-14
leonadavinci@gmail.com wrote:> > Jani Huhtanen wrote: >> leonadavinci@gmail.com wrote:/* snip */> > Is there any good book that explain these things?I learned basics of wavelets from "Wavelets and Filter Banks by Gilbert Strang, Truong Nguyen" http://www.amazon.com/gp/product/0961408871/102-4667879-7500913?v=glance&n=283155 It explains these things quite well, but requires also some work from the reader. But there should be better books out there (I hope). I suggest you take a trip to your local/uni library. -- Jani Huhtanen Tampere University of Technology, Pori
