Hello, I have an eZdsp F2812 Board connected with a PC through a parallel port. On the DSP there is my program, which is running with a frequency of 20kHz. I would like to send some data from the board to the PC, where there will be a simple GUI to control the behavior of my program. Could you tell me the easiest solution for this? How to write a routine which sends the data from the DSP to the PC through the parallel port and how to read the data back? And what should I do on the PC to read/write to DSP? I have never tried to do such a communication. Greetings, pawl
eZdsp F2812 and PC
Started by ●March 13, 2006
Reply by ●March 13, 20062006-03-13
There is a tutorial, I think it is called something like Volume, as in volume control, that interfaces a PC to a DSP application using CCS. It is at least included in newer versions of CCS. You may want to see if you have it or something similar.
