Hello, If a signal is usampled by a factor L & then passed through a filter to interpolate & now I downsample this signal by N where L>N,(or decimate), will my resulting signal have an upsampling rate of : L/N ? Will there be any change to the statistics of this signal? If my original signal was gaussian distributed,will the new signal be gaussian distributed too? Looking forward for a reply! Thank you. Regds, parvathy.
Interpolation & Decimation
Started by ●March 14, 2006
Reply by ●March 14, 20062006-03-14
"parvathy.rv" <parvathy.rv@gmail.com> wrote in message news:48CdnWJg-5sje4vZnZ2dnUVZ_s-dnZ2d@giganews.com...> Hello, > If a signal is usampled by a factor L & then passed through a filter to > interpolate & now I downsample this signal by N where L>N,(or decimate), > will my resulting signal have an upsampling rate of : L/N ? > Will there be any change to the statistics of this signal? If my original > signal was gaussian distributed,will the new signal be gaussian > distributed too? > Looking forward for a reply! Thank you. > > Regds, > parvathy.This sounds too much like a homework problem. You should clarify this first and then expect some reasonable answers. Also - it would be nice if you wrote what your thoughts are on these questions and let the group correct you. Cheers Bhaskar
