Hi, (Accept my apologies if I am posting to the wrong newsgroup: I am not totally sure what group would be best to address regarding my question.) I am working with general 2-D adaptive arrays right now and my understanding (from EE's in this area) is that null-steering is typically better than optimization of the SINR (constrained or unconstrained). Based on what I've read about these methods, it is not totally clear to me what the basis for this statement is, or that it is even true under all circumstances. The closest I've come is a cryptic statement in "Adaptive Array Processing" by Allen and Ghavami in which they state that main beam steering (which is their name for unconstrained beamforming) "will not produce a maximum SNR in the presence of directional interference". However, if you look at the formula they use, you see that the covariance matrix they are using is due only to the noise and is not the conventional "noise" covariance matrix that one uses to perform unconstrained beamforming with a directional source of interference. It is easy to prove mathematically that using the total "noise covariance matrix as R"noise" = R"jammers" + R"randomnoise", last statement is patently false. Does anyone know of a text or journal article that gives a good rigorous mathematical justification for this claim? The only thing I can see which would possibly support this statement is that in practice some of the assumptions made (like the fact that signals source, directional intereference sources and the noise are uncorrelated) are not typically satisfied or that perhaps there are other issues (like beamwidth and the presence of side lobes) that vitiate the efficacy of SINR optimization relative to null-steering. You can reply to this message directly or e-mail me. MTIA, Matt
Beamforming question
Started by ●March 14, 2006
Reply by ●March 15, 20062006-03-15
Hi, This book might help: "Adaptive Filter Theory", from Simon Haykin. They go over null steering briefly on pg. 119-125. They assume the angle of the interfering source is known and poses the problem as a constrained problem. More detail is given in later chapters. hth
Reply by ●March 17, 20062006-03-17
Brenneman wrote:> Hi, > > (Accept my apologies if I am posting to the wrong newsgroup: I am not > totally sure what group would be best to address regarding my > question.) > > > I am working with general 2-D adaptive arrays right now and my > understanding (from EE's in this area) is that null-steering is > typically better than optimization of the SINR (constrained or > unconstrained). Based on what I've read about these methods, it is not > > totally clear to me what the basis for this statement is, or that it is > > even true under all circumstances.A wild guess would be that given an arry, the gain is fixed. There is only so much that can be achieved to increase the S part in the S/N ratio. To increase further, you need to reduce the N part, which is exactly what is done in interference cancellers. If you know the DoA of a noise (point) source, the best you can do is to place a null in that direction. Rune
Reply by ●March 18, 20062006-03-18
Hi Rune, This is a nice argument, but I'm not sure that it is consistent with what we know about these methods mathematically. In unconstrained optimization, you _are_ optimizing the SINR, so I don't see how null-steering can outperform the unconstrained beamforming method. OTOH, I think you are right, in the sense that null-steering does seem to be the method of choice and there is a consensus that it is better than unconstrained beamforming. So it seems that there must be some other function that null-steering must be optimizing. Since it is not SINR, what is it? Matt
Reply by ●March 29, 20062006-03-29
Brenneman wrote:> Hi Rune, > > This is a nice argument, but I'm not sure that it is consistent with > what we know about these methods mathematically. > In unconstrained optimization, you _are_ optimizing the SINR, so I > don't see how null-steering can outperform the unconstrained > beamforming method.I reckon we are talking about different flavours of the same thing. I sketched the "trivial" example when the ineterfering source is a point source and the bearing is known. One then can make the problem more realistic (and harder) by relaxing the constraints, either by assuming a distributes source instead of a point source, or by assuming the bearing to be unknown. Or both. Depending on the exact formulation of the problem, one arrives at different optimum solutions.> OTOH, I think you are right, in the sense that > null-steering does seem to be the method of choice and there is a > consensus that it is better than unconstrained beamforming. So it seems > that there must be some other function that null-steering must be > optimizing. Since it is not SINR, what is it?Now you are asking very detailed questions I am not able to answer. It might help if you defined exactly what you mean by "constrained beamformers" etc, so that we are sure we discuss the same things. Generally speaking, one has a choise between something that is simple to implement, is robust, and works reasonably well; and something that is complicated, requires prior information that could be hard to come by, and workse very well but is sensitive to flaws in prior information. For instance, if you try to track one particular source in an environment where several interfering sources exist, and all move at similar bearing rates, it is not obvious how to design an adaptive null-stearing beamformer that nulls the interfering sources while keeping the desired source. In that sort of scenario, an unconstrained beamfomer might be preferable, since the effect of the beamformer is consistent from time to time, and an operator can be trained to account for such effects. A constrained beamfomer that dynamically reacts to the various interfering sources might require an operator with a PhD in adaptive filters to interpret the situation. Again, it is a choise between simplicity and robustness on one hand, and accurate results from "itchy" methods, on the other. Rune
