Frequency multiplication required
Started by devidasbhonde March 15, 2006
Hi,
I need to multiply a low frequency (human heart beat measured by a piezo
crystal)
of aprox one hertz by say 200, so that it would be audible. Realtime, with
minimum delay.
I wish to use it for biofeedback.
All its harmonics should be multiplied too.
How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ?
Regards and thanks,
Devidas
devidasbhonde wrote:
> Hi, > > I need to multiply a low frequency (human heart beat measured by a piezo > crystal) > of aprox one hertz by say 200, so that it would be audible. Realtime, with > minimum delay. > I wish to use it for biofeedback. > All its harmonics should be multiplied too. > > How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ? > > Regards and thanks, > > Devidas
Let's see if I get this straight. You have a signal that is periodic at approximately one Hz. You want to speed it by a factor of 200, so that it becomes a pitch approximately G or G# below middle C. Right so far? This is easy to do by collecting samples at a suitable rate and playing them back 200 times faster. What does "real time" mean here? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> Hi, > > I need to multiply a low frequency (human heart beat measured by a piezo > crystal) > of aprox one hertz by say 200, so that it would be audible. Realtime, with > minimum delay. > I wish to use it for biofeedback. > All its harmonics should be multiplied too. > > How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ? > > Regards and thanks, > > Devidas > > >
Heart sounds are audiable without any processing. I think you want to extract the beat to beat pediod and convert that to a tone but when you mentioned harmonics, I don't really understand what your looking for. Also healthy hearts have a fair amount of beat to beat variability.
As he mentioned "biofeedback" and you can not "control something 200 times faster than it occurs", I wonder if he suffered confusion of terms. Interpretation #1 He was really trying to describe AM modulation of a tone. Interpretation #2 He was really trying to describe FM modulation of a tone by the average period between beats. I'd lean towards #2 as it would seem to match what I vaguely recall of the goals of biofeedback. OP needs to specify goal not method.
Richard Owlett wrote:
> devidasbhonde wrote: > >> Hi, >> >> I need to multiply a low frequency (human heart beat measured by a piezo >> crystal) >> of aprox one hertz by say 200, so that it would be audible. Realtime, >> with >> minimum delay. >> I wish to use it for biofeedback. >> All its harmonics should be multiplied too. >> >> How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ? >> >> Regards and thanks, >> >> Devidas >> >> >> > > > As he mentioned "biofeedback" and you can not "control something 200 > times faster than it occurs", I wonder if he suffered confusion of terms.
Maybe more than just terms. There may be some unwarranted assumptions that need examining.
> Interpretation #1 > He was really trying to describe AM modulation of a tone. > > Interpretation #2 > He was really trying to describe FM modulation of a tone by the average > period between beats. > > I'd lean towards #2 as it would seem to match what I vaguely recall of > the goals of biofeedback.
I wouldn't want to superpose my assumptions on his. I'll wait for clarification.
That's always good. In this case, one needs to distinguish heartbeats as events from the frequencies generated by those events. Raising the frequency without creating virtual tachycardia may prove difficult. Creating a pitch inversely proportional to the period between beats is simple, but not directly applicable to harmonics. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
If I understand you correctly, you are looking at the same thing that kreuters is asking about in the thread "frequency shifting (compressing?)" in this newsgroup except that you want to scale up in frequency rather than down. As I responded to him, if you find a solution at that extreme a scale value please come back here and share the results. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Jerry Avins wrote:
> devidasbhonde wrote: > > Hi, > > > > I need to multiply a low frequency (human heart beat measured by a piezo > > crystal) > > of aprox one hertz by say 200, so that it would be audible. Realtime, with > > minimum delay. > > I wish to use it for biofeedback. > > All its harmonics should be multiplied too. > > > > How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ? > > > > Regards and thanks, > > > > Devidas > > Let's see if I get this straight. You have a signal that is periodic at > approximately one Hz. You want to speed it by a factor of 200, so that > it becomes a pitch approximately G or G# below middle C. Right so far? > > This is easy to do by collecting samples at a suitable rate and playing > them back 200 times faster. What does "real time" mean here?
I humbly think that your solution wouldn't work here since, as I understand it, it's supposed to play a different frequency depending on the heart beat rate, and that real time here means that it should be "live", for example, you would hear "in real time" the signal changing as the heart would change it's rhythm
Stan Pawlukiewicz wrote:
> devidasbhonde wrote: > > Hi, > > > > I need to multiply a low frequency (human heart beat measured by a piezo > > crystal) > > of aprox one hertz by say 200, so that it would be audible. Realtime, with > > minimum delay. > > I wish to use it for biofeedback. > > All its harmonics should be multiplied too. > > > > How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ? > > > > Regards and thanks, > > > > Devidas > > > > > > > Heart sounds are audiable without any processing. I think you want to > extract the beat to beat pediod and convert that to a tone but when you > mentioned harmonics, I don't really understand what your looking for. > > Also healthy hearts have a fair amount of beat to beat variability.
I think that by harmonics he means he doesn't want it to be ~1 Hz + 200 Hz but rather ~1 Hz * 200. Thus a change of 0.1 Hz in the heart beat rhythm would be heard as a change of 20 Hz
Michel Rouzic wrote:
> Jerry Avins wrote: > >>devidasbhonde wrote: >> >>>Hi, >>> >>>I need to multiply a low frequency (human heart beat measured by a piezo >>>crystal) >>>of aprox one hertz by say 200, so that it would be audible. Realtime, with >>>minimum delay. >>>I wish to use it for biofeedback. >>>All its harmonics should be multiplied too. >>> >>>How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ? >>> >>>Regards and thanks, >>> >>>Devidas >> >>Let's see if I get this straight. You have a signal that is periodic at >>approximately one Hz. You want to speed it by a factor of 200, so that >>it becomes a pitch approximately G or G# below middle C. Right so far? >> >>This is easy to do by collecting samples at a suitable rate and playing >>them back 200 times faster. What does "real time" mean here? > > > I humbly think that your solution wouldn't work here since, as I > understand it, it's supposed to play a different frequency depending on > the heart beat rate, and that real time here means that it should be > "live", for example, you would hear "in real time" the signal changing > as the heart would change it's rhythm
Indeed. It appears that your understanding of his problem exceeds Davidas's. I hope to get him to think more about what he really wants to do. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> Stan Pawlukiewicz wrote: > >>devidasbhonde wrote: >> >>>Hi, >>> >>>I need to multiply a low frequency (human heart beat measured by a piezo >>>crystal) >>>of aprox one hertz by say 200, so that it would be audible. Realtime, with >>>minimum delay. >>>I wish to use it for biofeedback. >>>All its harmonics should be multiplied too. >>> >>>How do I do it ? On PC or using a processor like Atmel AVR@20Mhz ? >>> >>>Regards and thanks, >>> >>>Devidas >>> >>> >>> >> >>Heart sounds are audiable without any processing. I think you want to >>extract the beat to beat pediod and convert that to a tone but when you >>mentioned harmonics, I don't really understand what your looking for. >> >>Also healthy hearts have a fair amount of beat to beat variability. > > > I think that by harmonics he means he doesn't want it to be ~1 Hz + 200 > Hz but rather ~1 Hz * 200. Thus a change of 0.1 Hz in the heart beat > rhythm would be heard as a change of 20 Hz
He wants to multiply all frequencies by 200 without dividing all periods by the same amount. Can you think of a way to do that? I can't. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
