hello, be aware, I'm new to DSP algorithms :) I have more pcm streams. first I have to change the sample rates of some pcm streams and than I have to "add" all streams in a (new) pcm stream (with a given sample rate). How can I do this? As I read on the dspguru.com, changing the sample rate might be done with using multirate algorithm. But how can I do the "sampling" of the streams? Thanks. Cheers, Willy
mixing pcm
Started by ●March 17, 2006
Reply by ●March 17, 20062006-03-17
Do you have access to the samples in a memory buffer? I am not a guru in DSP either, but I did some audio programming on the PC. What you can do is calculate a fixed point divisor of the sample rate and your output rate. Say if your sample rate is not higher than 65535, then you can use 16.16 fixed point So basically to get this increment (sample rate << 16) / output rate This will give you a 32bit value (assuming you are doing a 32/16 div) and then the upper 16bits will have your whole increment and the lower your fractional output. Now just have a running counter, repeatedly add this 32-bit value to an accumulator, and take the high 16-bits as an index to the sample buffer. If you are in fact "sampling" your samples, than you can use this number to decide when to skip a sample in the output. -Isaac
"Willy" <backhaus_willy@yahoo.de> writes:> hello, > > be aware, I'm new to DSP algorithms :) > > I have more pcm streams. first I have to change the sample rates of > some pcm streams and than I have to "add" all streams in a (new) pcm > stream (with a given sample rate). > How can I do this? > > As I read on the dspguru.com, changing the sample rate might be done > with using multirate algorithm. But how can I do the "sampling" of > the streams?Willy, Sample rate conversion is a non-trivial task, in general. Even just adding two streams together at the same sample rate can be more involved than you might suspect. We can try to help you here, but beware this is not really a project for a beginner. To proceed, give details on the input stream sample rate(s) and the output stream sample rate. -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
