Hi, I am building an fixed point OFDM for 802.16,using 2^10 quantisation(ie the floating point values are multiplied by 1024). The system was working fine, so I decided to test with AWGN channel. The problem is that the code for AWGN that I have is for Floating point. I normalised the output of the IFFT by- IFFt symbol = Symbol / sqrt(real*real+imag*imag), and converted this to float. Then I added noise. Since I am using 2^10, I multiplied this final noisy signal with 1024, and reconverted back to fixed point. I am getting very poor BER(10e-2 even at 10db). Now if I remove the IFFT and FFT, I get good BER. I tested the IFFT-FFT by itself, taking a MATLAB output as reference. I get very good performance, very close to MATLAB results(floating point, converted to fixed point at end of calculation). The only problem I can think of is that way I am adding noise to IFFT is wrong. Does anyone know how we add AWGN noise to fixed point IFFT- am I missing any steps? Thanks Shan
IFFT fixed point and AWGN channel
Started by ●March 17, 2006
Reply by ●March 17, 20062006-03-17
shan_100 said the following on 17/03/2006 17:11:> I am building an fixed point OFDM for 802.16,using 2^10 quantisation(ie > the floating point values are multiplied by 1024). The system was working > fine, so I decided to test with AWGN channel. The problem is that the code > for AWGN that I have is for Floating point. > > I normalised the output of the IFFT by- > > IFFt symbol = Symbol / sqrt(real*real+imag*imag), and converted this to > float.If you're doing the division in fixed point, won't you get horrendous rounding errors?> I am getting very poor BER(10e-2 even at 10db). Now if I remove the IFFT > and FFT, I get good BER.10dB what? SNR or Eb/No? What constellation are you using? -- Oli
Reply by ●March 19, 20062006-03-19
>If you're doing the division in fixed point, won't you get horrendous >rounding errors?I convert it to float for adding AWGN noise.>> I am getting very poor BER(10e-2 even at 10db). Now if I remove theIFFT>> and FFT, I get good BER. > >10dB what? SNR or Eb/No? What constellation are you using?Eb/N0 with QPSK shan
