I just begin a project of DM642 and I don't know why the link cmd file is needed and how to write it. I think that, as gel file has already define the memory map, why the link.cmd is still needed?
how to write a link cmd file for DM642?
Started by ●March 17, 2006
Reply by ●March 18, 20062006-03-18
On 17 Mar 2006 19:52:55 -0800, "X.Y." <Xieyu1219@gmail.com> wrote in comp.dsp:> I just begin a project of DM642 and I don't know why the link cmd file > is needed and how to write it. I think that, as gel file has already > define the memory map, why the link.cmd is still needed?The gel file tells the debugger about the memory map. It doesn't tell the linker anything. You need to tell the linker where the memory is in your particular model of the DSP part, and you also have to tell it where to put different parts of your program, the code, the variable data, the constant data, the stack, and so on. Code Composer Studio should come with some sample programs that include cmd files. Also go to http://www.dspvillage.ti.com and look up your DSP. There should be more sample programs, with cmd files, that you can download. You may need to look at the data sheet for your chip model to figure out where all the memory spaces are. -- Jack Klein Home: http://JK-Technology.Com FAQs for comp.lang.c http://c-faq.com/ comp.lang.c++ http://www.parashift.com/c++-faq-lite/ alt.comp.lang.learn.c-c++ http://www.contrib.andrew.cmu.edu/~ajo/docs/FAQ-acllc.html
Reply by ●March 19, 20062006-03-19
"X.Y." <Xieyu1219@gmail.com> wrote...> I just begin a project of DM642 and I don't know why the link cmd file > is needed and how to write it. I think that, as gel file has already > define the memory map, why the link.cmd is still needed?As Jack Klein wrote: the GEL is mainly for the debugger. When you use Code Composer Studio (CCS) you don't need to create a *.cmd file yourself. In CCS: set up a project, include the DSP/BIOS group to setup the memory regions etc. See the tutorial, project set up, DSP/BIOS settings. A cmd file for the linking phase is generated automagically. After a build you can find the generated .cmd file in your project directory. Only if you do need specials things like a host loading the DSP through the HPI bus, you may have to ADD a small .cmd file of your own, that will be used TOGETHER with the DSP/BIOS project generated .cmd file. See the examples used for generating HEX files using the HEX6X utility. Regards, Arie de Muijnck
