Half Sine pulse shaping filter question
Started by roger.kp ●March 18, 2006
Hi Roger
I don't know how you're trying to demodulate the OQPSK signal, but I
think I know why you're not getting the result you expect.
The OQPSK specified in the 802.15.4 standard uses a half-sine shaping
pulse on each of the quadrature carriers (sin and cos). The symbol
period on each of these carriers is 2T (where T is the chip period). If
we consider demodulating only a single of these quadrature carriers
(e.g. sin), then the waveform is a set of half-sine pulses every 2T
seconds of duration 2T seconds (plus some noise and assuming no
distortion).
To recover the original data signal it is sufficient to use a matched
filter (or equivalently correlating) and then choose as the received
data samples spaced 2T seconds apart and beginning T seconds after the
peak of the input waveform. This can be done for each quadrature
carrier separately. Note also that there is an assumption here of
correct timing in the receiver.
802.15.4 uses this OQPSK modulation to modulate chip sequences of
length 16 (8 on each of the quadrature carriers) and thus by examining
the received chip sequence the original 16-ary signal may be decoded.
This is one simple possibility which I hope is relevant and helps you.
Dave
