Hello all, I think there may be a bug in the Winfilter08 program. However, the bug which I will state below, is really too obvious so I am doubting myself. Anyway, hear goes: In the C code generation of an IIR filter (lowpass, 8th order, chebychev, fs=1000Hz, fcut1=250Hz, Ripple=1dB), I think that there is an error that gets generated when the fixed point (16 or 8bit) is chosen. This was based on the fact that the output should yield (y[n] = a0*x[n] + a1*x[n-1] + a2*x[n-2] - b1*y[n-1] - b2*y[n-2]), This is the outputted code: .....[cut] //Calculate the new output x[0] = NewSample; y[0] = ACoef[0] * x[0]; for(n=1; n<=NCoef; n++) y[0] += ACoef[n] * x[n] - BCoef[n] * y[n]; y[0] /= BCoef[0]; ------------ 1st division return y[0] / DCgain; ------------ 2nd division I agree with the 1st division. The Bcoef[1 to n] coefficients were all amplified by the Bcoef[0] value, so a division is necessary to bring down the coefficients to their original intended values. This had to be done because of the fixed-point approach. However, the Acoef[0 to n] coefficients were all amplified by the Bcoef[0]*DCgain value. In this case, both the division by Bcoef[0] and by DCgain are necessary. (In order to assess the factor of amplication of the coefficents, the fixed-point evaluated coefficients were compared to the floating-point evaluated coefficients. The floating point evaluated coefficients are used as a reference.) However, the last division seen in the C code return y[0] / DCgain; performs the [divide by DCgain] division on all coefficients, both Bcoef[1 to n] and Acoef[0 to n]. This should lead to an erroneous return value. Is this a correct assumption? -Roger
Winfilter bug?
Started by ●March 21, 2006
Reply by ●March 22, 20062006-03-22
No. Your understanding is right till your last statement. Only the An coefs are scaled by DCgain. It is like scaling the input signal by DCgain. Therefore, the output signal must be scaled down "return y[0] / DCgain". The preserved y[0] is not scaled down because the y[] values must retain the system DCgain. Cheers, Adrian
Hmmm.... Let's see if I were to insert/draw a DCgain amplification BEFORE the [input of the IIR filter in the direct form I diagram], then yes I would need to attenuate by DCgain the [output of the IIR filter in the direct form I diagram]. Amplifying the input of the IIR filter (by DCgain), OR amplifying only the corresponding feedforward coefficients by DCgain -from the bloc diagram perspective- seems like it should have the same effect. If we were to look at it from the equation point of view: (y[n] = a0*(DCgain*x[n])*Bcoef[0] + a1*(DCgain*x[n-1])*Bcoef[0] + a2*(DCgain*x[n-2])*Bcoef[0] - b1*y[n-1]*Bcoef[0] - b2*y[n-2])*Bcoef[0], it would imply that the SEEN effective input to the IIR filter would be x'[n]=DCgain*x[n] So again, it seems correct. A division by Dcgain would be necessary on y[n] in order to extract x[n]. So my question is: Why did we go to all the trouble to amplyfing the input (of the filter) by DCgain ? Does it have to do something with boosting up the resolution of the Acoef[n] ? -Roger
