Hello, all, I'm having a very strange occurrence with Analog Devices ADSP-21065L SHARC DSP: the data come out of the serial port with the MSB of each byte cleared, despite the fact that internally (and I checked this with the VisualDSP++ debugger) the data have it in both states - sometimes high, other times low. This happens only on a handful of boards, and I don't see any differences in the serial port control registers between the "good" and the "bad" ones. As I'm not familiar with hardware (I'm a firmware engineer, not an electric engineer), I don't know where exatly to start. Does anyone have a similar experience? Any suggestions and opinions are welcome. Thanks in advance, Arkady.
Analog Devices ADSP-21065L serial port trouble
Started by ●March 21, 2006
Reply by ●March 22, 20062006-03-22
Hi, Zarin wrote:> Hello, all, > I'm having a very strange occurrence with Analog Devices ADSP-21065L > SHARC DSP: the data come out of the serial port with the MSB of each > byte cleared, despite the fact that internally (and I checked this with > the VisualDSP++ debugger) the data have it in both states - sometimes > high, other times low. This happens only on a handful of boards, and I > don't see any differences in the serial port control registers between > the "good" and the "bad" ones. As I'm not familiar with hardware (I'm > a firmware engineer, not an electric engineer), I don't know where > exatly to start. Does anyone have a similar experience? > > Any suggestions and opinions are welcome. > > Thanks in advance, > Arkady.Do all of your boards have the same revision of the DSP chip? Which one? JaaC
