Hi, I'm kind of newbie with matlab so pleace be patient. =) Well anyway, in one algorithm I'm trying to implement with Matlab I need to divide a Fourier transform with i*w (i is imaginary unit and w omega or 2*pi*f). So it's something like this: Fs = 501; %sampling frequency t=[-1:1/Fs:1]; x = cos(2*pi*10*t); Xf = fft(x); f = [-0.5*Fs:Fs/N:0.5*Fs-1/Fs]; frequency vector xt1 = ifft(ifftshift(fftshift(Xf)./(j*2*pi*f))); subplot(2,1,1); plot(t,x); grid on; subplot(2,1,2); plot(t,xt1); grid on; This works a little bit but at least the scaling goes wrong. And I've also noticed there can't be any zeros in the frequency vector, because then everithing goes to infinity. I know that diveding with i*w in the frequency-domain is same as integration in time-domain, but I don't really know how to do integration with Matlab. So if you have any correction ideas or some totally different kind of approach in mind, help would be greatly appreciated. -Mika
Matlab fft and frequency vector
Started by ●March 23, 2006
Reply by ●March 23, 20062006-03-23
"Mika" <ee8460@kolumbus.fi> wrote in message news:dvuq41$1ll$1@phys-news4.kolumbus.fi...> Hi, > > I'm kind of newbie with matlab so pleace be patient. =) Well anyway, in > one > algorithm I'm trying to implement with Matlab I need to divide a Fourier > transform with i*w (i is imaginary unit and w omega or 2*pi*f). So it's > something like this: > > Fs = 501; %sampling frequency > t=[-1:1/Fs:1]; > x = cos(2*pi*10*t); > > Xf = fft(x); > > f = [-0.5*Fs:Fs/N:0.5*Fs-1/Fs]; frequency vector > > xt1 = ifft(ifftshift(fftshift(Xf)./(j*2*pi*f))); > > subplot(2,1,1); > plot(t,x); > grid on; > > subplot(2,1,2); > plot(t,xt1); > grid on; > > This works a little bit but at least the scaling goes wrong. And I've also > noticed there can't be any zeros in the frequency vector, because then > everithing goes to infinity. I know that diveding with i*w in the > frequency-domain is same as integration in time-domain, but I don't really > know how to do integration with Matlab. So if you have any correction > ideas > or some totally different kind of approach in mind, help would be greatly > appreciated. > > -Mika > >
"Mika" <ee8460@kolumbus.fi> wrote in message news:dvuq41$1ll$1@phys-news4.kolumbus.fi...> Hi, > > I'm kind of newbie with matlab so pleace be patient. =) Well anyway, in > one > algorithm I'm trying to implement with Matlab I need to divide a Fourier > transform with i*w (i is imaginary unit and w omega or 2*pi*f). So it's > something like this: > > Fs = 501; %sampling frequency > t=[-1:1/Fs:1]; > x = cos(2*pi*10*t); > > Xf = fft(x); > > f = [-0.5*Fs:Fs/N:0.5*Fs-1/Fs]; frequency vector > > xt1 = ifft(ifftshift(fftshift(Xf)./(j*2*pi*f))); > > subplot(2,1,1); > plot(t,x); > grid on; > > subplot(2,1,2); > plot(t,xt1); > grid on; > > This works a little bit but at least the scaling goes wrong. And I've also > noticed there can't be any zeros in the frequency vector, because then > everithing goes to infinity. I know that diveding with i*w in the > frequency-domain is same as integration in time-domain, but I don't really > know how to do integration with Matlab. So if you have any correction > ideas > or some totally different kind of approach in mind, help would be greatly > appreciated. > > -MikaI don't know, it looks like you're doing quite a few unecessary fft/ifft operations! Xf > fft of x with normal registration fftshift(Xf) hmmmmm... I have NO idea what you're attempting here. what you will get is a sort of ifft of Xf that is shifted around in time. ifftshift(the above) what you get is a sort of fft of x that is shifted around in frequency ifft (of the above) what you get is an ifft of that strange fft of that strange ifft of that fft Whew! that's enough to make my mind spin! I have no idea what that would be. Are you sure you don't want something like this: fftshift(x)=Xf then weigh by the intended weighting function Xf > Xfw ifftshift (Xfw) done! I'm not sure but I presume that fftshift followed by ifftshift gets you back to x. Fred
> I don't know, it looks like you're doing quite a few unecessary fft/ifft > operations! >Yeah you might be right =)> Xf > fft of x with normal registration > fftshift(Xf) hmmmmm... I have NO idea what you're attempting here. > what you will get is a sort of ifft of Xf that is shifted around intime.> ifftshift(the above) what you get is a sort of fft of x that is shifted > around in frequency > ifft (of the above) what you get is an ifft of that strange fft of that > strange ifft of that fft > Whew! that's enough to make my mind spin! > I have no idea what that would be. >fftshift means that it shifts zero-frequency component to center of spectrum. Because Matlab's fft puts the zero frequency to the beginnig. And ifftshift undoes the effects of fftshift. But they are not really necessary because you can get the same results using different frequency vector. Like this f1 = [1/Fs:Fs/N:0.5*Fs]; f2 = [-0.5*Fs:Fs/N:0-Fs/N]; f = [f1 f2]; xt1 = ifft(fft(Xf)./(j*2*pi*f)); is equivalent with f = [-0.5*Fs:Fs/N:0.5*Fs-1/Fs]; xt1 = ifft(ifftshift(fftshift(fft(Xf))./(j*2*pi*f))); in the first one the frequency vector goes from 0 to Fs/2 and then from -Fs/2 to 0. And in the second one the frequency vector goes from -Fs/2 to Fs/2. And my real problem is how I should choose the right frequency vector?> Are you sure you don't want something like this: > > fftshift(x)=Xf > then weigh by the intended weighting function Xf > Xfw > ifftshift (Xfw) > done! > I'm not sure but I presume that fftshift followed by ifftshift gets youback> to x.Actually it should go something like fft(x) = Xf then the weighting Xf > Xfw ifft(Xfw) I just don't know the right weighting function. =) -Mika
"Mika" <ee8460@kolumbus.fi> wrote in message news:dvv04a$50b$1@phys-news4.kolumbus.fi...> > I just don't know the right weighting function. =) > > -MikaOK - what are you trying to accomplish? Fred
Reply by ●March 24, 20062006-03-24
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:jtWdncwv3qwoy77ZRVn-jQ@centurytel.net...> > "Mika" <ee8460@kolumbus.fi> wrote in message > news:dvv04a$50b$1@phys-news4.kolumbus.fi... > > > > > > I just don't know the right weighting function. =) > > > > -Mika > > OK - what are you trying to accomplish? >I'm trying to count Lateral Energy Fraction (LEF) of room with the method suggested by Kleiner 1989. In this method you measure the room impulse response with two omni michrophones and from those two impulse responses according to Kleiner you should get figure8 microphone response like this: fig8 = ifft(fft(omni1-omni2)*c/(j*2*pi*f*b)); where omni1 and omni2 are the measured impulse responses, c speed of sound and b distance between the microphones. But my problem is how I create this frequency vector f in Matlab. I have tried things like f = [-0.5*Fs:Fs/N:0.5*Fs-1/Fs]; and f1 = [1/Fs:Fs/N:0.5*Fs]; f2 = [-0.5*Fs:Fs/N:0-Fs/N]; f = [f1 f2]; and f = [0:Fs/N:Fs-Fs/N]; where Fs is the samplig frequency and N length of the impulse response. However none of these seem to work. -Mika
Reply by ●March 25, 20062006-03-25
"Mika" <ee8460@kolumbus.fi> wrote in message news:e00fcj$bjm$1@phys-news4.kolumbus.fi...> > "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message > news:jtWdncwv3qwoy77ZRVn-jQ@centurytel.net... >> >> "Mika" <ee8460@kolumbus.fi> wrote in message >> news:dvv04a$50b$1@phys-news4.kolumbus.fi... >> >> >> > >> > I just don't know the right weighting function. =) >> > >> > -Mika >> >> OK - what are you trying to accomplish? >> > I'm trying to count Lateral Energy Fraction (LEF) of room with the method > suggested by Kleiner 1989. In this method you measure the room impulse > response with two omni michrophones and from those two impulse responses > according to Kleiner you should get figure8 microphone response like this: > > fig8 = ifft(fft(omni1-omni2)*c/(j*2*pi*f*b)); > > where omni1 and omni2 are the measured impulse responses, c speed of sound > and b distance between the microphones. But my problem is how I create > this > frequency vector f in Matlab. I have tried things like > > f = [-0.5*Fs:Fs/N:0.5*Fs-1/Fs]; and > > f1 = [1/Fs:Fs/N:0.5*Fs]; > f2 = [-0.5*Fs:Fs/N:0-Fs/N]; > f = [f1 f2]; and > > f = [0:Fs/N:Fs-Fs/N]; > > where Fs is the samplig frequency and N length of the impulse response. > However none of these seem to work. > > -MikaI don't know about LEF. Your words suggest that a "microphone response" that is a beam pattern but I'm not sure. "figure 8" surely suggests that... So does the distance between microphones and the speed of sound being in there. Accordingly it's unclear to me where the "fs" comes in to any of this. For a beam pattern I'd probably use something like -pi to pi. Now, if you're doing numeric calculations then indeed things need to be sampled or discrete. So maybe the solution to your problem is to decide what the independent variables are and go from there. In the response fig8, I see "f" as frequency. If it's for a beam pattern then there's a pattern for *each* frequency but I don't see the spatial angles like theta or phi in the expression. Maybe it's a single measure of each pattern? Anyway, I'd be likely to compute the measure as a function of frequency going from zero to however high you need to go and not include negative frequencies as this appears to not be a signal but, rather, a measure. But I'm guessing. Fred
"Mika" <ee8460@kolumbus.fi> writes:> Hi, > > I'm kind of newbie with matlab so pleace be patient. =) Well anyway, in one > algorithm I'm trying to implement with Matlab I need to divide a Fourier > transform with i*w (i is imaginary unit and w omega or 2*pi*f). So it's > something like this: > > Fs = 501; %sampling frequency > t=[-1:1/Fs:1]; > x = cos(2*pi*10*t); > > Xf = fft(x); > > f = [-0.5*Fs:Fs/N:0.5*Fs-1/Fs]; frequency vector > > xt1 = ifft(ifftshift(fftshift(Xf)./(j*2*pi*f))); > > subplot(2,1,1); > plot(t,x); > grid on; > > subplot(2,1,2); > plot(t,xt1); > grid on; > > This works a little bit but at least the scaling goes wrong. And I've also > noticed there can't be any zeros in the frequency vector, because then > everithing goes to infinity. I know that diveding with i*w in the > frequency-domain is same as integration in time-domain, but I don't really > know how to do integration with Matlab. So if you have any correction ideas > or some totally different kind of approach in mind, help would be greatly > appreciated. > > -MikaHi Mika, Several points: 1. Using the N-point DFT implies that the input signal x[n] is periodic with period N. Is this the assumption you wish to make? 2. The integration property you describe has the following form for the discrete-time Fourier series (i.e., the DFT): \sum_{k=-\infty}^{n} <==> (1 / (1 - exp(-jk(2*pi/N)))) * a_k, where a_k is the kth DFT coefficient of x[n], 0 <= k <= N - 1. 3. The fftshift/ifftshift operations are incorrect according to the above property. 4. The division is not by j*2*pi*f, as for the continuous-time Fourier transform, but by 1 - exp(-jk(2*pi/N)), per the property above. 5. The result is finite-valued only if there is no DC term in the Fourier series, i.e., a_0 = 0. This is from "Signals and Systems," Oppenheim et al. So, your Matlab code is fine - your theory is wrong. In general, you cannot take a continuous-time Fourier transform property, discretize it, and apply it to the DFT. -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
