How do I modulate a given clock signal, without using any other frequency source(ie. no PLLs, VCOs, Ring osc. etc.) I have only 1 frequency ie of the clock signal and I need to modulate that same signal. Is this possible ? Any help would be appreciated. Thnx in advance.... Regards Apurva
Clock frequency modulation
Started by ●March 24, 2006
Reply by ●March 24, 20062006-03-24
Apurva Agarwal wrote:> How do I modulate a given clock signal, without using any other > frequency source(ie. no PLLs, VCOs, Ring osc. etc.) > I have only 1 frequency ie of the clock signal and I need to modulate > that same signal. > Is this possible ? > > Any help would be appreciated. > Thnx in advance.... > > > Regards > ApurvaWhat sort of modulation do you want to put on the clock signal? AM, FM, PM? If the clock originates from an oscillator with a tuning input, then you could modulate its frequency by changing the DC voltage applied to that input. If it is a standard two-lead crystal, then you might be able to pull it one way or the other by changing the component values around the crystal. John
Apurva Agarwal wrote:> How do I modulate a given clock signal, without using any other > frequency source(ie. no PLLs, VCOs, Ring osc. etc.) > I have only 1 frequency ie of the clock signal and I need to modulate > that same signal. > Is this possible ?Special relativity, although not practical, makes this possible;)> > Any help would be appreciated. > Thnx in advance.... > > > Regards > Apurva >
You could try replacing your clock with a VCXO and modulate it with a digital or audio signal. Thomas "Apurva Agarwal" <agarwal.apurva@gmail.com> wrote in message news:1143186368.104940.94690@e56g2000cwe.googlegroups.com...> How do I modulate a given clock signal, without using any other > frequency source(ie. no PLLs, VCOs, Ring osc. etc.) > I have only 1 frequency ie of the clock signal and I need to modulate > that same signal. > Is this possible ? > > Any help would be appreciated. > Thnx in advance.... > > > Regards > Apurva >
Apurva Agarwal wrote:> How do I modulate a given clock signal, without using any other > frequency source(ie. no PLLs, VCOs, Ring osc. etc.) > I have only 1 frequency ie of the clock signal and I need to modulate > that same signal. > Is this possible ?If you clarify what you mean by "modulate", your question might have an answer. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●March 25, 20062006-03-25
On 23 Mar 2006 23:46:08 -0800, "Apurva Agarwal" <agarwal.apurva@gmail.com> wrote:>How do I modulate a given clock signal, without using any other >frequency source(ie. no PLLs, VCOs, Ring osc. etc.) >I have only 1 frequency ie of the clock signal and I need to modulate >that same signal. >Is this possible ? > >Any help would be appreciated. >Thnx in advance....Frequency modulation of a clock without the use of a high(er) frequency reference clock is (1) possible and (2) commonly done (in ASICs) using a DLL. Here's how: Pass your reference clock into a tapped delay line. Fine tune the delay line so that its length is exactly equal to one period of the input clock. Each tap on the delay line then represents a different phase of the input clock. Connect the taps to the inputs of a wide multiplexer, to allow you to select one tap at a time. The output of the multiplexer is your output signal. Apply a counter to the select inputs of the multiplexer. Slowly incrementing (or decrementing) the counter will cause the phase of the output to increment (or decrement) with respect to the input clock. This is a different way of saying that you have changed the frequency. Getting this to work without generating glitches or lots of jitter is left as a exercise for the reader. Regards, Allan.
On Sat, 25 Mar 2006 20:08:37 +1100, Allan Herriman <allanherriman@hotmail.com> wrote:>On 23 Mar 2006 23:46:08 -0800, "Apurva Agarwal" ><agarwal.apurva@gmail.com> wrote: > >>How do I modulate a given clock signal, without using any other >>frequency source(ie. no PLLs, VCOs, Ring osc. etc.) >>I have only 1 frequency ie of the clock signal and I need to modulate >>that same signal. >>Is this possible ? >> >>Any help would be appreciated. >>Thnx in advance.... > >Frequency modulation of a clock without the use of a high(er) >frequency reference clock is (1) possible and (2) commonly done (in >ASICs) using a DLL. > >Here's how: > >Pass your reference clock into a tapped delay line. Fine tune the >delay line so that its length is exactly equal to one period of the >input clock.To do this you need a PLL ("fine tune the delay line so that its length is exactly equal to one period of the input clock") which requires someone to do this fine tuning; the only way of which I know is to run a PLL, use replica bias and use twice as many delay elements in the DLL as that of the PLL so it's outside the requirements of the OP as it requires PLL, VCO and Ring OSc all at the same time :-)>Getting this to work without generating glitches or lots of jitter is >left as a exercise for the reader.This portion I am curious about though. I have a solution which works but my glitch suppression is a little bit more complicated than I am comfortable with. Any references I can look up on this ?
Reply by ●March 26, 20062006-03-26
On Sun, 26 Mar 2006 03:52:32 GMT, mk<kal*@dspia.*comdelete> wrote:>On Sat, 25 Mar 2006 20:08:37 +1100, Allan Herriman ><allanherriman@hotmail.com> wrote: > >>On 23 Mar 2006 23:46:08 -0800, "Apurva Agarwal" >><agarwal.apurva@gmail.com> wrote: >> >>>How do I modulate a given clock signal, without using any other >>>frequency source(ie. no PLLs, VCOs, Ring osc. etc.) >>>I have only 1 frequency ie of the clock signal and I need to modulate >>>that same signal. >>>Is this possible ? >>> >>>Any help would be appreciated. >>>Thnx in advance.... >> >>Frequency modulation of a clock without the use of a high(er) >>frequency reference clock is (1) possible and (2) commonly done (in >>ASICs) using a DLL. >> >>Here's how: >> >>Pass your reference clock into a tapped delay line. Fine tune the >>delay line so that its length is exactly equal to one period of the >>input clock. > >To do this you need a PLL ("fine tune the delay line so that its >length is exactly equal to one period of the input clock") which >requires someone to do this fine tuning; the only way of which I know >is to run a PLL, use replica bias and use twice as many delay elements >in the DLL as that of the PLL so it's outside the requirements of the >OP as it requires PLL, VCO and Ring OSc all at the same time :-)You can do it with just the DLL. No VCO required. You will need a phase detector to compare the phase at the end of the delay line with the incoming clock though.>>Getting this to work without generating glitches or lots of jitter is >>left as a exercise for the reader. > >This portion I am curious about though. I have a solution which works >but my glitch suppression is a little bit more complicated than I am >comfortable with. Any references I can look up on this ?I don't know of any that give useful details, sorry. Regards, Allan
Reply by ●March 27, 20062006-03-27
