Hello About the DWT: The DWT provides data compression by setting a threshold value and all coefficients that are less than the choosen value will be reduced to zero or eliminated and the signal can be reconstructed from the thresholded coefficients. Therefore, I would like to ask about the lossless compression , does this involve just the DWT and IDWT without setting any threshold value? or does it involve more than that? Thanks in advance
DWT and Data Compression
Started by ●March 29, 2006
Reply by ●March 30, 20062006-03-30
Umutesi Faith wrote:> Hello > > About the DWT: > The DWT provides data compression by setting a threshold value and all > coefficients that are less than the choosen value will be reduced to zero > or eliminated and the signal can be reconstructed from the thresholded > coefficients. > Therefore, I would like to ask about the lossless compression , does this > involve just the DWT and IDWT without setting any threshold value? or does > it involve more than that? > > Thanks in advanceLossless compression algorithms might or might not use a discrete wavelet transform. Here's a good source for you: http://en.wikipedia.org/wiki/Lossless_compression Cheers! --M
"mlimber" <mlimber@gmail.com> writes:> Umutesi Faith wrote: >> Hello >> >> About the DWT: >> The DWT provides data compression by setting a threshold value and all >> coefficients that are less than the choosen value will be reduced to zero >> or eliminated and the signal can be reconstructed from the thresholded >> coefficients. >> Therefore, I would like to ask about the lossless compression , does this >> involve just the DWT and IDWT without setting any threshold value? or does >> it involve more than that? >> >> Thanks in advance > > Lossless compression algorithms might or might not use a discrete > wavelet transform. Here's a good source for you: > > http://en.wikipedia.org/wiki/Lossless_compression > > Cheers! --MA the strings "wavelet" and "dwt" do not occur in that page. Can you give a pointer to an example of lossless compression based on wavelets? -- % Randy Yates % "Watching all the days go by... %% Fuquay-Varina, NC % Who are you and who am I?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://home.earthlink.net/~yatescr
For lossless compression, you would typically use reversible integer to integer wavelet transforms (keywords for googling). One of the papers that might be helpful is: Reversible Integer-to-Integer Wavelet Transforms for Image Compression: Performance Evaluation and Analysis Michael D. Adams, Faouzi Kossentini, IEEE TRANSACTIONS ON IMAGE PROCESSING, VOL. 9, NO. 6, JUNE 2000 Hope this helps Raja Umutesi Faith wrote:> Hello > > About the DWT: > The DWT provides data compression by setting a threshold value and all > coefficients that are less than the choosen value will be reduced to zero > or eliminated and the signal can be reconstructed from the thresholded > coefficients. > Therefore, I would like to ask about the lossless compression , does this > involve just the DWT and IDWT without setting any threshold value? or does > it involve more than that? > > Thanks in advance
ysriraja@gmail.com writes:> For lossless compression, you would typically use reversible integer to > integer wavelet transforms (keywords for googling). One of the papers > that might be helpful is: > > Reversible Integer-to-Integer Wavelet Transforms for Image Compression: > Performance Evaluation and Analysis > Michael D. Adams, Faouzi Kossentini, IEEE TRANSACTIONS ON IMAGE > PROCESSING, VOL. 9, NO. 6, JUNE 2000 > > Hope this helps > RajaIf you're not quantizing the wavelet coefficients, then how does a DWT help? At least from the 30,000-foot level? Seems like there's as little entropy in the transformed data as the original data, no? -- % Randy Yates % "Midnight, on the water... %% Fuquay-Varina, NC % I saw... the ocean's daughter." %%% 919-577-9882 % 'Can't Get It Out Of My Head' %%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra http://home.earthlink.net/~yatescr
You're right. The wavelet transform cannot be guaranteed to decrease the entropy by itself. However, by subband partitioning one has the luxury of defining different context models (As the low frequency and high frequency subbands have different pdf's) for each subband to be used for arithmetic coding. So maybe applying the wavelet transform just provides more flexibility in the pre-processing prior to entropy coding. Randy Yates wrote:> If you're not quantizing the wavelet coefficients, then how does > a DWT help? At least from the 30,000-foot level? Seems like there's > as little entropy in the transformed data as the original data, no? > -- > % Randy Yates % "Midnight, on the water... > %% Fuquay-Varina, NC % I saw... the ocean's daughter." > %%% 919-577-9882 % 'Can't Get It Out Of My Head' > %%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra > http://home.earthlink.net/~yatescr
Reply by ●April 1, 20062006-04-01
Hello, Thanks for the reply. I guess this was just my straight approach about lossless data compression with wavelet as i was referring to the data compression concept of dwt with matlab programme! However, by performing the DWT , using the quadrature mirror filters (ex: daubechies,...), and digital filtering mechamism (FIR filtering), do we speak in this particular case about the wavelet window, as we have at hand just the discrete signal and the filters that will just do the transform?? In fact this works perfectly but i don't see how this is related to any kind of window? could these filters be the window? in continuous wavelet transform(CWT) the window concept is quite clear as it is referred to as the mother wavelet!! thanks !
