I am working on a project in which, based on the LMS adaptive algorithm, I have to perform the following: echo cancelation and co-channel interference supression. I have tried the inplementation of the algorithm in Mathlab but for noise cancelation. For noise cancelation it was was simple: d = awgn(x, 22);// signal distorted by noise SNR is -22 dB mu = 0.08;//step size ha = adaptfilt.lms(20, mu);//the lms filter [yy, ee] = filter(ha, x, d);//yy is the filtered signal But how can I model the echo signal(for echo cancelation)?I know it is a delayed and attenuated version of the initial signal but I need a mathematical model. If this correct? d = x + x(n+delay)/attenuation factor. As for co-channel interference supression i need more help.I am in dark on this one.
LMS implementatiom for echo cancelation ad co-channel interference supression
Started by ●April 4, 2006
Reply by ●April 4, 20062006-04-04
Are you working on an ATSC TV receiver? Adaptive Eq does not normally help against co-channel intereference when the interfrerring signal is the same kind of signal as the desired....But an adaptive EQ in an ATSC TV recevier can help against co-channnel interference if the desired signal is a digital ATSC signal and the interfererer is an NTSC analog TV signal. This is because, in this case, the interference is concentrated in a few small frequency ranges and the EQ filter can create notches at those frequencies. Mark
