Hi,guys! I have a question about digital audio system. As we know, a lot of digital audio system has a Pre-Emphasis circuit before the A/D circuit. The audio signal must pass a treble-boost filter before they go to the A/D. And my question is, what's the effect of this Pre-Emphasis circuit? To reduce the noise? To enhance the A/D's performance? Or other effect? Thanks!
What's the effect of the Pre-Emphasis circuit?
Started by ●April 4, 2006
Reply by ●April 9, 20062006-04-09
>Hi,guys! >I have a question about digital audio system. >As we know, a lot of digital audio system has a Pre-Emphasis circuit >before the A/D circuit. The audio signal must pass a treble-boost filter >before they go to the A/D. >And my question is, what's the effect of this Pre-Emphasis circuit? To >reduce the noise? To enhance the A/D's performance? Or other effect? > >Thanks! >Anybody here?
RockBear wrote:> >Hi,guys! > >I have a question about digital audio system. > >As we know, a lot of digital audio system has a Pre-Emphasis circuit > >before the A/D circuit. The audio signal must pass a treble-boost filter > >before they go to the A/D. > >And my question is, what's the effect of this Pre-Emphasis circuit? To > >reduce the noise? To enhance the A/D's performance? Or other effect? > > > >Thanks!ya gotta be careful about thanking people in advance for help.> Anybody here?oh, all right. i would expect the opposite. i would expect a LPF for anti-aliasing before the A/D. in modern audio systems the A/D is a sigma-delta type which is grossly oversampled (by 64 or 128 times). usually the manufacturer of the A/D recommends a simple passive RC LPF before the A/D which, by itself is insufficient to do the anti-aliasing job, but the decimation stages of the A/D (where they down sample from 3 MHz to 48 kHz) does the rest. so it surprize me that they would do that pre-emphasizing as you say. in FM and FM stereo transmission, they pre-emphasize the audio going in in the manner you suggest because the nature of additive noise to the FM signal will end up in the high frequencies. to reduce that noise, they de-emphasize the audio, reducing that trebley noise, but that also reduces the treble of the audio, so to fix that, they pre-emphasize it at the transmitter. there is a standard for that so that all FM receivers can count on the pre-emphasis being the same for all transmitters, and vis-versa. i suppose the reason why they may have a pre-emphasis like that in your audio system is that someone thought that the quantization noise (along with the analog front end noise) was "hissy" or trebley in some way so they de-emphasized it in the output and pre-emphasized the audio in the input to fix it. but, frankly, it seems backwards to me. i am not sure that i accept the premise of your question and that is why i didn't respond when i first read it. r b-j
Reply by ●April 10, 20062006-04-10
On 9 Apr 2006 18:44:55 -0700, "robert bristow-johnson" <rbj@audioimagination.com> wrote:> >RockBear wrote: >> >Hi,guys! >> >I have a question about digital audio system. >> >As we know, a lot of digital audio system has a Pre-Emphasis circuit >> >before the A/D circuit. The audio signal must pass a treble-boost filter >> >before they go to the A/D. >> >And my question is, what's the effect of this Pre-Emphasis circuit? To >> >reduce the noise? To enhance the A/D's performance? Or other effect? >> > >> >Thanks! > >ya gotta be careful about thanking people in advance for help. > >> Anybody here? > >oh, all right. i would expect the opposite. i would expect a LPF for >anti-aliasing before the A/D. in modern audio systems the A/D is a >sigma-delta type which is grossly oversampled (by 64 or 128 times). >usually the manufacturer of the A/D recommends a simple passive RC LPF >before the A/D which, by itself is insufficient to do the anti-aliasing >job, but the decimation stages of the A/D (where they down sample from >3 MHz to 48 kHz) does the rest. so it surprize me that they would do >that pre-emphasizing as you say. > >in FM and FM stereo transmission, they pre-emphasize the audio going in >in the manner you suggest because the nature of additive noise to the >FM signal will end up in the high frequencies. to reduce that noise, >they de-emphasize the audio, reducing that trebley noise, but that also >reduces the treble of the audio, so to fix that, they pre-emphasize it >at the transmitter. there is a standard for that so that all FM >receivers can count on the pre-emphasis being the same for all >transmitters, and vis-versa."There is a standard" I only wish that was the case. Even in FM radio, different pre-emphasis time constants are used depending on your locale. 75us and 50us are the time constants encountered. 75us was chosen at a time before it was realised that FM radio would be used for music. (It's good for voice.) 50us came later, and is probably a better choice overall.>i suppose the reason why they may have a pre-emphasis like that in your >audio system is that someone thought that the quantization noise (along >with the analog front end noise) was "hissy" or trebley in some way so >they de-emphasized it in the output and pre-emphasized the audio in the >input to fix it. but, frankly, it seems backwards to me. i am not >sure that i accept the premise of your question and that is why i >didn't respond when i first read it.CD audio has the option for pre- and de-emphasis, but I don't think I've ever seen a disk that's used it. The older ('80s) players would indicate that the pre-emphasis flag had been seen on the disk. More modern players don't bother to do that. Regards, Allan
Allan Herriman wrote:> On 9 Apr 2006 18:44:55 -0700, "robert bristow-johnson" > <rbj@audioimagination.com> wrote: > > >in FM and FM stereo transmission, they pre-emphasize the audio going in > >in the manner you suggest because the nature of additive noise to the > >FM signal will end up in the high frequencies. to reduce that noise, > >they de-emphasize the audio, reducing that trebley noise, but that also > >reduces the treble of the audio, so to fix that, they pre-emphasize it > >at the transmitter. there is a standard for that so that all FM > >receivers can count on the pre-emphasis being the same for all > >transmitters, and vis-versa. > > "There is a standard" I only wish that was the case. Even in FM > radio, different pre-emphasis time constants are used depending on > your locale. 75us and 50us are the time constants encountered. 75us > was chosen at a time before it was realised that FM radio would be > used for music. (It's good for voice.) 50us came later, and is > probably a better choice overall.wow. i never heard of the 50us pre-emphasis "standard", but i guess i didn't look deep enough: http://www.pcs-electronics.com/en/products.php?sub=stereo_encod in the U.S., doesn't the FCC set preemphsis spec by regulation? http://www.fcc.gov/Bureaus/Mass_Media/Databases/documents_collection/pn740710.pdf i can't find a more definitive online doc at the moment, but frankly this 50 us pre-emphasis for FM broadcast was unheard of by me unitl this moment. too bad they didn't pick 50us to begin with. i would have thunk that they had dealt with the psychoacoustic issues and that is what indicated the 75us pre-emphasis to begin with. how much worse than 50 can it be? and what do modern stereo receivers use? what's worse than the wrong standard (that is slightly off) is when there are inconsistencies in the standard. kinda like the pin 2 or pin 3 hot issue of those XLR connectors. r b-j
> >Allan Herriman wrote: >> On 9 Apr 2006 18:44:55 -0700, "robert bristow-johnson" >> <rbj@audioimagination.com> wrote: >> >> >in FM and FM stereo transmission, they pre-emphasize the audio goingin>> >in the manner you suggest because the nature of additive noise to the >> >FM signal will end up in the high frequencies. to reduce that noise, >> >they de-emphasize the audio, reducing that trebley noise, but thatalso>> >reduces the treble of the audio, so to fix that, they pre-emphasizeit>> >at the transmitter. there is a standard for that so that all FM >> >receivers can count on the pre-emphasis being the same for all >> >transmitters, and vis-versa. >> >> "There is a standard" I only wish that was the case. Even in FM >> radio, different pre-emphasis time constants are used depending on >> your locale. 75us and 50us are the time constants encountered. 75us >> was chosen at a time before it was realised that FM radio would be >> used for music. (It's good for voice.) 50us came later, and is >> probably a better choice overall. > >wow. i never heard of the 50us pre-emphasis "standard", but i guess i >didn't look deep enough: > >http://www.pcs-electronics.com/en/products.php?sub=stereo_encod > >in the U.S., doesn't the FCC set preemphsis spec by regulation? > >http://www.fcc.gov/Bureaus/Mass_Media/Databases/documents_collection/pn740710.pdf > >i can't find a more definitive online doc at the moment, but frankly >this 50 us pre-emphasis for FM broadcast was unheard of by me unitl >this moment. > >too bad they didn't pick 50us to begin with. i would have thunk that >they had dealt with the psychoacoustic issues and that is what >indicated the 75us pre-emphasis to begin with. how much worse than 50 >can it be? and what do modern stereo receivers use? what's worse than >the wrong standard (that is slightly off) is when there are >inconsistencies in the standard. kinda like the pin 2 or pin 3 hot >issue of those XLR connectors. > >r b-j > >Thank you for your answers! Buy what i said is exist in digital audio effects box, just like Digitch XMM\DF7, or BOSS GT3 and so on. I know there usually is a pre-emphasis circuit or pre-emphasis IIR in the FM system, but what i said is different from this pre-emphasis module. The pre-emphasis circuit in the digital effects box usually boost the 1kHz~15kHz about 3dB~5dB. and it has a attenuation from 15kHz~20kHz, whitch to reduce the higher frequency(more than 20kHz) that you had mentioned. You can see the circuit here: http://www.experimentalistsanonymous.com/diy/Schematics/Vibrato%20and%20Pitch%20Shift/Digitech%20XP100.pdf In the page 2, the C7 and R41 boost the 1kHz~20kHz about 3dB.
robert bristow-johnson wrote:> Allan Herriman wrote: > >>On 9 Apr 2006 18:44:55 -0700, "robert bristow-johnson" >><rbj@audioimagination.com> wrote: >> >> >>>in FM and FM stereo transmission, they pre-emphasize the audio going in >>>in the manner you suggest because the nature of additive noise to the >>>FM signal will end up in the high frequencies. to reduce that noise, >>>they de-emphasize the audio, reducing that trebley noise, but that also >>>reduces the treble of the audio, so to fix that, they pre-emphasize it >>>at the transmitter. there is a standard for that so that all FM >>>receivers can count on the pre-emphasis being the same for all >>>transmitters, and vis-versa. >> >>"There is a standard" I only wish that was the case. Even in FM >>radio, different pre-emphasis time constants are used depending on >>your locale. 75us and 50us are the time constants encountered. 75us >>was chosen at a time before it was realised that FM radio would be >>used for music. (It's good for voice.) 50us came later, and is >>probably a better choice overall. > > > wow. i never heard of the 50us pre-emphasis "standard", but i guess i > didn't look deep enough: > > http://www.pcs-electronics.com/en/products.php?sub=stereo_encod > > in the U.S., doesn't the FCC set preemphsis spec by regulation? > > http://www.fcc.gov/Bureaus/Mass_Media/Databases/documents_collection/pn740710.pdf > > i can't find a more definitive online doc at the moment, but frankly > this 50 us pre-emphasis for FM broadcast was unheard of by me unitl > this moment. > > too bad they didn't pick 50us to begin with. i would have thunk that > they had dealt with the psychoacoustic issues and that is what > indicated the 75us pre-emphasis to begin with. how much worse than 50 > can it be? and what do modern stereo receivers use? what's worse than > the wrong standard (that is slightly off) is when there are > inconsistencies in the standard. kinda like the pin 2 or pin 3 hot > issue of those XLR connectors.75 microseconds seems to be highly correlated with 60 Hz power. The rest of the world uses 50 microseconds. (At least one receiver had a switch.) Note that the preemphasis is a single R-C time constant; minimum phase. If the deemphasis is not likewise minimum phase, you won't get the original waveform back. There's another way to look at FM preemphasis. You could just as well say that the modulation is phase modulation, flat on the high end, and rolled off below the turnover frequency. Some of the whys and wherefores actually make more sense that way. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
RockBear wrote:> But what i said is exist in digital audio effects box, just like Digitch > XMM\DF7, or BOSS GT3 and so on. I know there usually is a pre-emphasis > circuit or pre-emphasis IIR in the FM system, but what i said is different > from this pre-emphasis module. > The pre-emphasis circuit in the digital effects box usually boost the > 1kHz~15kHz about 3dB~5dB. and it has a attenuation from 15kHz~20kHz, > whitch to reduce the higher frequency(more than 20kHz) that you had > mentioned. > You can see the circuit here: > http://www.experimentalistsanonymous.com/diy/Schematics/Vibrato%20and%20Pitch%20Shift/Digitech%20XP100.pdf > In the page 2, the C7 and R41 boost the 1kHz~20kHz about 3dB.the corner frequency for the treble boost start at 1/(2*pi*(R41 + R11||R10)*C7) and rolls back level at 1/(2*pi*R41*C7). now i didn't analyze the output section but it looks like the de-emphasis (for the left output) is a function of R32, C23, R27, and C15. someone else can work on that one. anyway, the reason for it is as i stated. somebody thought that adding the de-emphasis on the output makes the noise sound quieter. the pre-emphasis is needed to counter the effect of the de-emphasis for the desired signal. r b-j
