Hello. Generally we do up sampling by inserting zeros and passing through Image rejection filter. Instead of inserting zeros we can duplicate the samples and pass through a filter. the advantage of going for second mathod is i can choose a less order filter compared to the first methode. similarly is it possible to do the same methode for sampling rate conversion by non integer factor. if so what is is the cut off frequency of the filter and which design method i should fallow. -kareem
resampling using duplication of samples
Started by ●April 5, 2006
Reply by ●April 5, 20062006-04-05
kareem wrote:> Hello. > > Generally we do up sampling by inserting zeros and passing through Image > rejection filter. Instead of inserting zeros we can duplicate the samples > and pass through a filter. the advantage of going for second mathod is i > can choose a less order filter compared to the first methode.That is true. You can view the duplicating samples as the action of an FIR with kernel h1 = [1 1] on the zero-inserted upsampled sequence. h is a lowpass filter with a zero at Nyquist. Notice that you have -3dB gain at Nyquist/2, which means that you affect your original signal as well as attenuate the images. Now assume that the second filter which gets rid of the rest of the images is h2, and it has length N. Because the upsampling with duplication and filtering occur in series, you might as well upsample by zero-inserting and filter the the resulting stream with h3 = h1 * h2, the resulting output the same. The length of h3 is N+1. When you compute the output of h3, you only need to calculate (N+1)/2 MACs, because every second value in the filter state delay is equal to zero. So you have: 1. Cost for upsampling with duplicating samples and filtering with h2: N multiply/accumulates. 2. Cost for upsampling by zero-inserting and filtering with h3: (N+1)/2 multiply/accumulates. For N > 2, the second way produces less computation cost - you don't save anything by duplicating samples! This and the fact the h1 has considerable attenuation in the passband is the reason for using upsampling by zero-inserting. Regards, Andor
kareem wrote:> Hello. > > Generally we do up sampling by inserting zeros and passing through Image > rejection filter. Instead of inserting zeros we can duplicate the samples > and pass through a filter. the advantage of going for second mathod is i > can choose a less order filter compared to the first methode. similarly is > it possible to do the same methode for sampling rate conversion by non > integer factor. if so what is is the cut off frequency of the filter and > which design method i should fallow. > > -kareem > >This was covered in depth recently. The apparent economy that this technique offers breaks down quickly on close inspection. http://groups.google.com/group/comp.dsp/browse_frm/thread/e44b4a9e529996fc/05a740edfab354cb?tvc=1&q=comp.dsp+lyons+upsampling+zeros+hold#05a740edfab354cb or http://tinyurl.com/eqqax -- Mark B
