Hello, I was recently working with a DSP engineer who was making an argument to me that if I didn't oversample (above Nyquist) that I would be "losing information," and I still fail to understand exactly what information I would be losing. The context of our particular application, is that we are dwelling on a signal for a fixed period of time (a design constraint), but we can sample at whatever rate we want. In my mind, higher sample rates losely translate into more expensive A/Ds and higher processing overhead. I suggested we sample just above Nyquist and perform our 1024 point FFT. He said he would prefer to sample at 3x Nyquist. Okay, more samples are better, I guess, but I don't know how they give more information other than adding length to the FFT. The dwell time sets the "bin width" and increasing N, by decreasing Ts to support a fixed dwell, does nothing more than increase the number of bins in the FFT. The window function used dictates, to some degree the energy split or "straddling loss" between bins if the frequency of the sampled signal fails to fall directly on a FFT bin, but I can pick whatever window I want without regard to the sample rate. We are doing a complex FFT, and phase information is important in this particular application, but I fail to see that there is any loss of phase info, regardless of the window function or sample rate. I have been working with DFTs/FFTs for a number of years, althought I am an analyst, not a DSP Engineer. Could someone tell me what fundamental concept I am missing. Thanks, John
Oversampling and the FFT
Started by ●April 5, 2006
Reply by ●April 5, 20062006-04-05
>Hello, >I was recently working with a DSP engineer who was making an argument to >me that if I didn't oversample (above Nyquist) that I would be "losing >information," and I still fail to understand exactly what information I >would be losing. The context of our particular application, is that weare>dwelling on a signal for a fixed period of time (a design constraint),but>we can sample at whatever rate we want. In my mind, higher sample rates >losely translate into more expensive A/Ds and higher processing overhead.>I suggested we sample just above Nyquist and perform our 1024 point FFT.>He said he would prefer to sample at 3x Nyquist. Okay, more samples are >better, I guess, but I don't know how they give more information other >than adding length to the FFT. The dwell time sets the "bin width" and >increasing N, by decreasing Ts to support a fixed dwell, does nothingmore>than increase the number of bins in the FFT. The window function used >dictates, to some degree the energy split or "straddling loss" between >bins if the frequency of the sampled signal fails to fall directly on a >FFT bin, but I can pick whatever window I want without regard to the >sample rate. We are doing a complex FFT, and phase information is >important in this particular application, but I fail to see that thereis>any loss of phase info, regardless of the window function or sample rate.>I have been working with DFTs/FFTs for a number of years, althought I aman>analyst, not a DSP Engineer. Could someone tell me what fundamental >concept I am missing. >Thanks, >John > >Nyquist rate simply specifies the minimum rate at which the signal has to be sampled, so that it can be reconstructed successfully. If your sampling rate is much more than the Nyquist rate, more will be the information you are getting. How much more depends on the nature of the signal and how much entropic it is. In fact, keeping the signal as analog preserves all the information and by making it digital we are actually impairing the information available. Then why are we going for digital signals? Just because samples are easier and faster to process by modern digital computers compared to processing the analog signals by analog circuits. So, what your colleague says is true. - Krishna
John wrote: ...> >He said he would prefer to sample at 3x Nyquist. Okay, more samples are > >better, I guess, but I don't know how they give more information other > >than adding length to the FFT. The dwell time sets the "bin width" and > >increasing N, by decreasing Ts to support a fixed dwell, does nothing > more > >than increase the number of bins in the FFT. The window function used > >dictates, to some degree the energy split or "straddling loss" between > >bins if the frequency of the sampled signal fails to fall directly on a > >FFT bin, but I can pick whatever window I want without regard to the > >sample rate. We are doing a complex FFT, and phase information is > >important in this particular application, but I fail to see that there > is > >any loss of phase info, regardless of the window function or sample rate.You have essentially done the whole analysis above to show that no additional "information" is revealed by regarding the DFT output of oversampled signals. Any other questions? :-) krishna_sun82 wrote:> Nyquist rate simply specifies the minimum rate at which the signal has to > be sampled, so that it can be reconstructed successfully. If your sampling > rate is much more than the Nyquist rate, more will be the information you > are getting.Krishna, do we agree that "successful reconstruction" means that the signal is, well, successfully reconstructed? In that case it would be interesting to hear from you how additional "information" that you supposedly get by oversampling can be used to, um, even more succesfully reconstruct the signal? Regads, Andor
JohnReno wrote:> Hello, > I was recently working with a DSP engineer who was making an argument to > me that if I didn't oversample (above Nyquist) that I would be "losing > information," and I still fail to understand exactly what information I > would be losing. The context of our particular application, is that we are > dwelling on a signal for a fixed period of time (a design constraint), but > we can sample at whatever rate we want. In my mind, higher sample rates > losely translate into more expensive A/Ds and higher processing overhead. > I suggested we sample just above Nyquist and perform our 1024 point FFT. > He said he would prefer to sample at 3x Nyquist. Okay, more samples are > better, I guess, but I don't know how they give more information other > than adding length to the FFT. The dwell time sets the "bin width" and > increasing N, by decreasing Ts to support a fixed dwell, does nothing more > than increase the number of bins in the FFT. The window function used > dictates, to some degree the energy split or "straddling loss" between > bins if the frequency of the sampled signal fails to fall directly on a > FFT bin, but I can pick whatever window I want without regard to the > sample rate. We are doing a complex FFT, and phase information is > important in this particular application, but I fail to see that there is > any loss of phase info, regardless of the window function or sample rate. > I have been working with DFTs/FFTs for a number of years, althought I am an > analyst, not a DSP Engineer. Could someone tell me what fundamental > concept I am missing.John, I suspect that your colleague's explanation is a rationalization of what he has learned from experience. "Lose information" doesn't provide a basis for needing to sample faster than twice the highest frequency of interest, but the need is there nonetheless. Any frequencies in the signal higher than half the sampling frequency will corrupt the samples with aliases. It is not practically possible to remove them without also removing part of the signal of interest. Either way, information is lost; not because of the sampling process, but because of what we need to do to get a clean signal or the consequences of not getting one. Raising the sampling frequency allows the use of filters that don't affect the band of interest. If that's what your colleague means by retaining more information, then I concur. Because a practical sampling frequency is always above the Nyquist frequency, there is another effect of critical sampling than we mostly ignore because it's never evident. It is not possible to know the amplitude of a signal at exactly half the sampling frequency. While it doesn't alias, we can't reconstruct it. The mathematics of sampling shows that we can reconstruct any frequency below that, no matter how slightly below, with perfect accuracy. The real world doesn't have hard edges like that. In fact, the mathematics is based on an unchanging signal and an infinite observation time. With real-world signals, the closer a frequency is to the Nyquist limit, the longer it takes to determine its amplitude. With changing signals -- the only interesting kind, after all -- reasonably prompt data analysis requires some headroom. Your colleague's choice of 3x may be appropriate in some applications, but much less is needed in many (CDs sample at 44.1KHz and claim to reproduce 20) and more in some (5 and even 10x can make it easier to design stable servos). Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Two additional thoughts. If there is noise in the adc, then sampling at a higher rate will cause that noise to be averaged over three samples rather than just the one. This might improve the snr a little. A long time ago Crystal (now Cirrus Logic) shipped two different versions of their audio delta-sigma adcs. One version had a flat response to 20kHz when sampling at 44.1kHz, but allowed a couple of kHz of aliasing. The other version had a corner frequency of about 18kHz and did not have significant aliasing. I imagine that the first one was intended to make the response curves look good in product reviews, while the second was intended for more serious use. John
JohnReno wrote:> Hello, > I was recently working with a DSP engineer who was making an argument to > me that if I didn't oversample (above Nyquist) that I would be "losing > information," and I still fail to understand exactly what information I > would be losing. The context of our particular application, is that we are > dwelling on a signal for a fixed period of time (a design constraint), but > we can sample at whatever rate we want. In my mind, higher sample rates > losely translate into more expensive A/Ds and higher processing overhead. > I suggested we sample just above Nyquist and perform our 1024 point FFT. > He said he would prefer to sample at 3x Nyquist. Okay, more samples are > better, I guess, but I don't know how they give more information other > than adding length to the FFT. The dwell time sets the "bin width" and > increasing N, by decreasing Ts to support a fixed dwell, does nothing more > than increase the number of bins in the FFT. The window function used > dictates, to some degree the energy split or "straddling loss" between > bins if the frequency of the sampled signal fails to fall directly on a > FFT bin, but I can pick whatever window I want without regard to the > sample rate. We are doing a complex FFT, and phase information is > important in this particular application, but I fail to see that there is > any loss of phase info, regardless of the window function or sample rate. > I have been working with DFTs/FFTs for a number of years, althought I am an > analyst, not a DSP Engineer. Could someone tell me what fundamental > concept I am missing.When dealing with perfect samples from a perfectly bandlimited signal, then sampling above Nyquist is invertable, which means that no information is lost. However in the real world, there are effects due to the finite slope of any bandlimiting filters, which can either lose information from the signal of interest by pass-band ripple, and/or add alias information from having a non-zero stop-band. Also the phase of a sharp filter may change more rapidly near the transition which may amplify any phase noise. A higher sampling rate not only allows a flatter filter both in magnitude and phase response, but even if the filter isn't changed, contaminates signal data with less of any alias noise, due to folding less of the stop band into the samples. The more noise you add to a set of samples, the less information it can carry. Also, but I'm not sure of this, quantization errors (either in the sampling or inside the FFT) might have a greater effect on signals near the Nyquist frequency of a given sampling rate than on those farther below it. Again, adding error reduces information carrying capacity. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
