Hi all Ive decided to take the plunge and try to figure out how actually the FFT works by doing my own implmentation. DSP isnt my area and I am having a couple of problems understanding exactly what goes on under the hood. The main point that Im struggling with at the moment is the twiddle factors, namely how to calculate them within the butterfly loop in a real, in-place, DIT FFT. My understanding is that the twiddle factor is nk W N where N is the number of samples in the input data k is the frequency bin that the current calculation goes into n is the sample number the part that im unsure about is the n term and possibly the k. so say i have an 8 sample bit reversed input array that ive already recombined so that it currently consists of 2 four point dft's, to compute the final dft; [a][b][c][d][e][f][g][h] combines into [a+(Wkn)e][b+(Wkn)f][c+(Wkn)g][d+(Wkn)h][a-(Wkn)e][b-(Wkn)f][c-(Wkn)g][d-(Wkn)h] kn where Wkn = W N so N = 8, k = index of the frequency bin(?) and n = not sure, possibly the sample number of the term multiplied by Wnk? Im sure Im misinterpreting something about the twiddle factors thats affecting my understanding of exactly whats happening and hence my ability to implement it. Its a basic question but any help/clarification/corrections greatly appreciated! thanks in advance
Phase/twiddle factors calculations
Started by ●April 6, 2006
Reply by ●April 6, 20062006-04-06
take a look at this thread: http://groups.google.com/group/comp.dsp/browse_thread/thread/f5cf80ff9a8a820e/9618b0c210804570#9618b0c210804570 dunno if Dr. FFTW would agree or not (and i gladly defer to him as the FFT expert here) but for my money, it was easier for me to deal with the radix-2 DIF Cooley-Tukey FFT than the DIT. with DIF, you split the DFT summation into two halves with the earlier indices in one and the latter indices in the other (whereas the DIT puts the evens indices in one and the odds in another). the data goes into the DIF FFT in normal order and comes out in bit-reversed order whereas for the DIT it's the other way around. a long time ago i wrote an FFT (using DIF) and an iFFT (using DIT) in C so that the first took normal order data and returned bit-reversed and the latter took bit-reversed order data and returned normal order. i used this in a so-called "fast convolution", and i thought that this was sorta optimal because the transfer function H[k] would also be pre-calculated and pre-bit-reversed, so that there was no bit reversing done in the fast-convolution itself. i once posted the code, it's pretty simple but not hyper-optimzed like FFTW is. r b-j
robert bristow-johnson wrote:> but for my money, it was easier for me to deal with > the radix-2 DIF Cooley-Tukey FFT than the DIT.Since DIT and DIF algorithms are simply transposes of one another, they can always be implemented with essentially the same amount of code and should be the same difficulty. You essentially just reverse the steps to get DIT from DIF or vice versa.
stevenj@alum.mit.edu wrote:> robert bristow-johnson wrote: > > but for my money, it was easier for me to deal with > > the radix-2 DIF Cooley-Tukey FFT than the DIT. > > Since DIT and DIF algorithms are simply transposes of one another, they > can always be implemented with essentially the same amount of code and > should be the same difficulty. You essentially just reverse the steps > to get DIT from DIF or vice versa.no dispute with that, Steven. i just meant that, conceptually or pedagogically, it's easier for me to start with the simple DFT definition and fanagle that into the DIF algorithm. r b-j
Many thanks Rob and Steve for replying so soon. I had a look at that link and it did clear up a couple of things for me. I understand the difference between DIF and DIT approaches and I think Ive made a bit of progress. I now believe the twiddle factors are calcuated as follows (still using the DIT approach) where WX = W(N) ^ X, (N) being a subscript to W n = sample number, k = frequency bin 2 point dft's - N = 2 [] [] [] [] 00 11 00 11 nk nk nk nk W0 W1 W0 W1 4 point dft's - N = 4 [] [] [] [] [] [] [] [] 00 01 02 03 10 11 12 13 nk nk nk nk nk nk nk nk W0 W0 W0 W0 W0 W1 W2 W3 8 point dft's - N = 8 [] [] [] [] [] [] [] [] [] [] [] [] [] [] [] [] 00 01 02 03 04 05 06 07 10 11 12 13 14 15 16 17 nk nk nk nk nk nk nk nk nk nk nk nk nk nk nk nk W0 W0 W0 W0 W0 W0 W0 W0 W0 W1 W2 W3 W4 W5 W6 W7 and so forth. Im still a bit shoddy on the physical interpretation of the twiddle factors, but I believe one way of looking at them is a result of shifting the odd samples in the time domain to facilitate the recombination, this shift being essentally a convolution with a shifted impulse/delta function, and hence the frequency domain equivalent being the multiplication of the spectrum by a sinusoid. Please feel free to correct any mistakes or misconceptions in the above or to add anything. Thanks again!
Reply by ●April 7, 20062006-04-07
SeanOg wrote:> Im still a bit shoddy on the physical interpretation of the > twiddle factors, but I believe one way of looking at them is a result of > shifting the odd samples in the time domain to facilitate the > recombination, this shift being essentally a convolution with a shifted > impulse/delta function, and hence the frequency domain equivalent being > the multiplication of the spectrum by a sinusoid. > > Please feel free to correct any mistakes or misconceptions in the above or > to add anything. > >SeanOg, That is one way of looking at it, but there is a relatively simple physical interpretation of the fiddle-factor which I would like to add. I will consider the final stage of a decimation-in-time FFT where two N/2-length FFTs are combined to form one N-length FFT. One N/2-length FFT will have been been generated from the 'even' time-domain samples and the other from the 'odd' samples. The set of time-domain samples contributing to the 'odd' N/2-length FFT has a delay of one sample-period relative the 'even' set, and this introduces an increasing phase-offset into each of the 'odd' frequency components. This phase-offset is proportional to the frequency of the component. When the two half-length FFTs are combined to form a single full-length FFT, an increasing phase-adjustment must be made to the frequency components from the 'odd' FFT before summing them with their 'even' counterparts. This adjustment is done by multiplying each 'odd' component by a complex factor having unit-amplitude and a phase-angle which varies from zero up to 2*pi*(N-1)/N radian. The complex phase-adjustment factors are known as the 'twiddle' factors. Conceptually, two 'sweeps' through the N/2-length FFTs are necessary to generate N output components, but the FFT Butterfly applies some cunning trigonometry so that only one sweep is needed and that only N/2 complex phase-adjustment factors are needed. A similar analysis to the above can be applied to the second-last stage and so on, working back from the FFT's last stage. Regards, John
Reply by ●April 8, 20062006-04-08
Many thanks for that great explaination John, makes a lot of sense. Ive the algorithm implemented and its doing what I want it to do so the programming is fine, however im getting some strange results so one of my steps is incorrect conceptually, so Ill probally be back to pick your brains some more! thanks again
Reply by ●April 9, 20062006-04-09
SeanOg wrote:> Many thanks for that great explaination John, makes a lot of sense. > > Ive the algorithm implemented and its doing what I want it to do so the > programming is fine, however im getting some strange results so one of my > steps is incorrect conceptually, so Ill probally be back to pick your > brains some more! > > thanks againI'm glad you found it useful SeanOrg, and I would be glad to help further if possible. Regards, John
Reply by ●May 18, 20072007-05-18
Hi all.. I would be grateful if more info on the above could be provided with regards the equations to precompute the twiddle factors for each stage/butterfly in the FFT. This is to enable me write a piece of code to generate this ( i have not found much on this). I am aware that for a DIF radix-2 FFT the total number of butterflies is N/2LogN. The total number of twiddle factors involved is ( N/2 - 1). Also the last stage involves multiplication by a twiddle factor of 1. Could this be illustrated for an 8 point FFT for the 3 stages. How can i calculate the values for the twiddle factors (cos ra + j sin ra) for the entire range and relate that to each stage and butterfly. Any clarifications, pointers on this would be great! Cheers _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
Reply by ●June 3, 20072007-06-03
On Fri, 18 May 2007 08:59:40 -0500, "mahesh_u2" <mahesh_susindran@yahoo.co.uk> wrote:>Hi all.. > >I would be grateful if more info on the above could be provided with >regards the equations to precompute the twiddle factors for each >stage/butterfly in the FFT. This is to enable me write a piece of code to >generate this ( i have not found much on this). >I am aware that for a DIF radix-2 FFT the total number of butterflies is >N/2LogN. The total number of twiddle factors involved is ( N/2 - 1). Also >the last stage involves multiplication by a twiddle factor of 1. Could >this be illustrated for an 8 point FFT for the 3 stages. How can i >calculate the values for the twiddle factors (cos ra + j sin ra) for the >entire range and relate that to each stage and butterfly. >Any clarifications, pointers on this would be great! >CheersHello Mahesh, I didn't see your post until now. If you're still interested, you can find the answer to your question at: Lyons, R. "Program Aids Analysis of FFT Algorithms", EDN Magazine, Aug. 6, 1987. or in Section 13.16 of the book: "Understanding Digital Signal Processing, 2nd edition, by R. Lyons. The answer to your problem is far too involved to try to decribe it here in ASCII text. Good Luck, [-Rick-]
