hi can someone please explain the meaning of this code its about computing the autocorrelation function IN MATLAB r1=[zeros(1,101)]; for i=1:1:50 x=rand(1,5000); r=zeros(1,101); fori=1:1:50 z=[x zeros(1,i)]; y=[zeros(1,i) x]; r(51+i)=sum(z.*y)./(5000-i); end r(51)=sum(x.*x)./(5000); z=[ zeros(1,i) x]; y=[x zeros(1,i)]; r(i)=sum(z.*y)./(5000-i);
urgent
Started by ●April 9, 2006
Reply by ●April 9, 20062006-04-09
"dew" <ukap70@gmail.com> wrote in message news:1144583032.170137.284430@v46g2000cwv.googlegroups.com...> hi > can someone please explain > the meaning of this code > its about computing the autocorrelation function IN MATLAB > > r1=[zeros(1,101)];set up a column vector r1 of 101 elements all of which are set to 0> for i=1:1:50starting at i=1 execute the instructions between here and end then increment i by 1 : exit for-end loop when i>50 : note that this overwrites matlab's default value for i=sqrt(-1).> x=rand(1,5000);fill a 5000 element column vector x with double precision values between 0 and 1 selected from a uniform distribution - note that this is _inside_ the loop> r=zeros(1,101);see r1 but this is _inside_ the loop so wipes out the last value that you stored in r> fori=1:1:50set up a 50 element row vector fori so that element n holds value n.> z=[x zeros(1,i)];add i zeros on to the end of x and call it z> y=[zeros(1,i) x];add i zeros on to the beginning of x and call it y effectively shifting the non-zero values of y w.r.t. those of z> r(51+i)=sum(z.*y)./(5000-i);multiply the shifted and original sequence together , for some reason normalise by dividing by 5000-i and store the sum in element 51+i of the 101 element vector r> endloop back incrementing i by 1 as previously noted or continue to next line of code if i>50 after the increment> r(51)=sum(x.*x)./(5000);put the mean squared value of x in element 51 of r at this point i is not incrementing any more , the vector fori has not been used at all, nor has r1 and everything runs very very slowly as x is filled with a new set of random numbers and y and z are redimensioned every time the loop executes. As r is zeroed at the start of each loop it should hold non-zero values for element 51 and 101. I could be completely wrong but thats as close as I can get to a description of what this segment of code should be doing. Best of luck - Mike
