CONTEXT:********************** Transmit x(n) receive y(n). Wiener-Hopf (MMSE) FIR Equalizer is... w = inv(Ryy)rxy where Ryy is the received signal autocorrelation and rxy is the channel input-output crosscorrelation: rxy(k) = E(x(n-D)y(n+k)). The D is a delay parameter chosen to make sure the equalizer is causal. It specifies the location of the impulse of the equalized channel. QUESTION:********************* Is it possible to impose a delay constraint on the actual equalizer? Would it have to be linear phase for this to work? I was hoping to specify the equalizer output as being a fixed delay relative to the equalizer input.
Wiener Hopf Equalizer delay
Started by ●July 6, 2004
Reply by ●July 8, 20042004-07-08
The delay of the equalizer is dependent on the length of the channel Impulse Response. "porterboy" <porterboy76@yahoo.com> wrote in message news:c4b57fd0.0407060630.7b67827c@posting.google.com...> CONTEXT:********************** > > Transmit x(n) receive y(n). Wiener-Hopf (MMSE) FIR Equalizer is... > w = inv(Ryy)rxy > where Ryy is the received signal autocorrelation and rxy is the > channel input-output crosscorrelation: rxy(k) = E(x(n-D)y(n+k)). The D > is a delay parameter chosen to make sure the equalizer is causal. It > specifies the location of the impulse of the equalized channel. > > QUESTION:********************* > > Is it possible to impose a delay constraint on the actual equalizer? > Would it have to be linear phase for this to work? I was hoping to > specify the equalizer output as being a fixed delay relative to the > equalizer input.
Reply by ●July 9, 20042004-07-09
"trellis coder" <trellis_coder@earthlink.net> wrote in message news:<d%4Hc.8721$R36.2109@newsread2.news.pas.earthlink.net>...> The delay of the equalizer is dependent on the length of the channel Impulse > Response.I understand that is the case if an unconstrained Wiener-Hopf equlaizer is used. I was wondering is there a constrained Wiener-Hopf solution, which allows delay specification? Anyway, I found a solution, whereby the equalizer is constrained to be linear phase, and hence has a fixed delay equal to half its length. However, the performance drop is significant compared to the unconstrained case.
