Hi, I conducted a series of experiments into the effect of inter-aural signal differences on the perception of sound direction. I change two variables (the inter-aural time difference ITD, and inter-aural level difference ILD) and measure the human directional response. I change ITD by inserted blank samples to the beginning of one channel, then I change the ILD by multiplying all samples in one channel by a number smaller than 1. I then need to plot the combined effect of ILD and ITD against the perceived direction. But what, mathematically, have I done? Based on intuition I normalised the two to give them equal weighting and then added them together. This gives me the lovely straight line I am looking for. I am having a hard time justifying this in my mind. Any comments would be most welcome. Richard
Experimental analysis problem
Started by ●April 17, 2006
Reply by ●April 17, 20062006-04-17
I would first plot ILD and ITD seperalty against perceived direction instead of trying to normalize and combine them together. Mark
Mark wrote:> I would first plot ILD and ITD seperalty against perceived direction > instead of trying to normalize and combine them together. > > Mark >Thanks for your reply Mark. That was a seperate part of the experiment. I performed trials in which I varied the ITD and ILD seperately in which I plotted them against perceived direction. Then I there were trials where I varied both at once in order to find how they interact. For these trials if I plot the ILD or ITD alone against direction I get a very broad envelope but if I add the two together I get exactly what i'm looking for, a linear relationship between the sum of ILD and ITD against the direction. I have read sources saying that the ITD and ILD are multiplied to localize sound. I tried multiplying the ILD and ITD values together and the result is a mess. But then maybe that is a meaningless thing to do in the context of how I combined them, or maybe adding them is and its coincidence. Which comes back to my question. If I add some samples and then multiply all the samples by some number, what function have I performed? Any further thoughts? Richard
Reply by ●April 18, 20062006-04-18
Richard wrote:> Hi, > > I conducted a series of experiments into the effect of inter-aural > signal differences on the perception of sound direction. I change two > variables (the inter-aural time difference ITD, and inter-aural level > difference ILD) and measure the human directional response. I change > ITD by inserted blank samples to the beginning of one channel, then I > change the ILD by multiplying all samples in one channel by a number > smaller than 1. I then need to plot the combined effect of ILD and ITD > against the perceived direction. > > But what, mathematically, have I done? > > Based on intuition I normalised the two to give them equal weighting and > then added them together. This gives me the lovely straight line I am > looking for. I am having a hard time justifying this in my mind. > > Any comments would be most welcome. > > RichardPlease can anyone else add anything to this thread? Come on, seriously, this could be the difference between me getting a 1st and a 2:1 in my degree. Can you live with that on your conscience ;-) ? Richard
Richard skrev:> Richard wrote: > > > Hi, > > > > I conducted a series of experiments into the effect of inter-aural > > signal differences on the perception of sound direction. I change two > > variables (the inter-aural time difference ITD, and inter-aural level > > difference ILD) and measure the human directional response. I change > > ITD by inserted blank samples to the beginning of one channel, then I > > change the ILD by multiplying all samples in one channel by a number > > smaller than 1. I then need to plot the combined effect of ILD and ITD > > against the perceived direction. > > > > But what, mathematically, have I done? > > > > Based on intuition I normalised the two to give them equal weighting and > > then added them together. This gives me the lovely straight line I am > > looking for. I am having a hard time justifying this in my mind. > > > > Any comments would be most welcome. > > > > Richard > > Please can anyone else add anything to this thread? > > Come on, seriously, this could be the difference between me getting a > 1st and a 2:1 in my degree. Can you live with that on your conscience ;-) ?You don't want me start ranting along those lines, believe me! I don't know much about your particular field of work, but having worked a bit with experimental data, I prefer somebody who presents some result, explains how he got there and then expresses whatever doubts or reservations he might have, over somebody who express "perfect" results as if there were no problems whatsoever.>From your phrasing of the problem, I suspect I know how you thinkabout such matters. You would have to search out what your supervisor thinks about the matter, and depending on what you find, think very carefully about how you want to play the game. A cleared-out consciousness is one thing. A cleared-out bank account might be far more serious. Rune
Hi Richard, ILD is mostly responsible for sound localization at high frequencies (say 2> KHz, not sure exactly). While ITD is mostly responsible for sound localization of low frequency sources. So if you want to study their coupled effects you *must* take into account the frequency of the source that you are using and you can't really assume the ILD and ITD are independent of one another... It seems like you can do an analysis of variance (ANOVA) of your data with an interaction term for ITD and ILD, as long as you have varied these parameters independent of one another. This is essentially a multi-regression on ITD, ILD and their interaction. Keep in mind that there is a frequency effect here and that you might miss non-linear relationships here...you will need to hold the frequency constant to simplify the experiment.
Hi Ikaro, thanks for your reply Ikaro wrote:> Hi Richard, > > ILD is mostly responsible for sound localization at high frequencies > (say 2> KHz, not sure exactly). > While ITD is mostly responsible for sound localization of low frequency > sources. > > So if you want to study their coupled effects you *must* take into > account the frequency of the source that you are using and you can't > really assume the ILD and ITD are independent of one another... >Whilst this is true, my research and experience suggests it is only partially true. The brain does not consider the ITD for sounds above about 1.5khz. In the real world there is very little ILD for sounds below 1.5khz because the wavelength is larger than the width of the head so there is almost perfect diffraction. However, I have shown that the brain will use an ILD if it exists for those sounds (and I am putting it in artificially). However, as a result the brain is very sensitive to the ILD at low frequencies and it is therefore a very frequency dependant cue as you point out. The sounds that I am using have very little content above 1500hz. I am not assuming they are independent at all. It is the way the two interact that I am trying to determine. It seems that sometimes the brain follows ITD, occasionally it follows ILD, and most of the time it finds some point somewhere between where the ITD and ILD says it is.> It seems like you can do an analysis of variance (ANOVA) of your data > with an interaction term for ITD and ILD, as long as you have varied > these parameters independent of one another. This is essentially a > multi-regression on ITD, ILD and their interaction. >I performed logistic regression on the trials in which I varied only one of them. In the trials where I varied both at once I considered trying perform some regresson test that took both into account but could not find the correct way to do it. Is an ANOVA appropriate in this case?> Keep in mind that there is a frequency effect here and that you might > miss non-linear relationships here...you will need to hold the > frequency constant to simplify the experiment. >I am using a single sound for all experiments, that of a snare drum beat. It has large frequency content between 150 and 400hz and significant content up to about 1000hz but not much above that. This is the main reason I chose the sound. Is this what you mean? Thanks again
Rune Allnor wrote:> Richard skrev: > >>Richard wrote: >> >>Please can anyone else add anything to this thread? >> >>Come on, seriously, this could be the difference between me getting a >>1st and a 2:1 in my degree. Can you live with that on your conscience ;-) ? > > You don't want me start ranting along those lines, believe me!:-)> > I don't know much about your particular field of work, but having > worked a bit with experimental data, I prefer somebody who > presents some result, explains how he got there and then > expresses whatever doubts or reservations he might have, > over somebody who express "perfect" results as if there were > no problems whatsoever.I try, perfect results are after all rather dull. Having said that I don't want to present an analysis of my results from which I conclude what I can, only to then discover later that my analysis is simply wrong and I fail for it.> > From your phrasing of the problem, I suspect I know how you think > about such matters. You would have to search out what your > supervisor thinks about the matter, and depending on what you > find, think very carefully about how you want to play the game. >My impression is he's pretty sharp on signal processing. Having said that he knows very little about psychology which is the focus of the experiment.> A cleared-out consciousness is one thing. A cleared-out bank > account might be far more serious. > > Rune >Do you mean a cleared out concience? I haven't had one of them for years. If you do mean what you wrote then I am planning to clear out my bank account in order to clear my consciousness just as soon as I hand this report in. Mmmmmm Whiskey! Richard
>I performed logistic regression on the trials in which I varied only one >of them. In the trials where I varied both at once I considered trying >perform some regresson test that took both into account but could not >find the correct way to do it. Is an ANOVA appropriate in this case?Not if you are varying ILD and ITD dependently. In this case you *might* go by using ANCOVA, and setting one of the stimulus as a covariate variable. But the best way would be to add independent noise (pertubations) to both stimulus (note that you will need 2 independent noise sources). And see how these pertubations affect the accuracy, either by doing ANOVA as mentioned here, or an analysis of perceptual weights for human observers. Check the following paper for an implementation of that: Berg, B. G. (1989). "Analysis of weights in multiple observation tasks," J. Acoust. Soc. Am. 86, 1743-1746 The key point is that the predictors in your model should be varied independtly of each other.>I am using a single sound for all experiments, that of a snare drum >beat. It has large frequency content between 150 and 400hz and >significant content up to about 1000hz but not much above that. This is >the main reason I chose the sound. Is this what you mean?No. Ideally it would be best if the sounds were within one critical band of the auditory system . Since you stimulus goes across several critical bands, its possible that the subject weigth the cues differently across the critical bands. Not to mention that they might switch listening strategies... all of which would complicate investigation of the perceptual weights given to ILD and ITD (as well as their interactions).
Richard skrev:> Rune Allnor wrote: > > > Richard skrev: > > > >>Richard wrote: > >> > >>Please can anyone else add anything to this thread? > >> > >>Come on, seriously, this could be the difference between me getting a > >>1st and a 2:1 in my degree. Can you live with that on your conscience ;-) ? > > > > You don't want me start ranting along those lines, believe me! > > :-) > > > > > I don't know much about your particular field of work, but having > > worked a bit with experimental data, I prefer somebody who > > presents some result, explains how he got there and then > > expresses whatever doubts or reservations he might have, > > over somebody who express "perfect" results as if there were > > no problems whatsoever. > > I try, perfect results are after all rather dull.Most certainly agreed.> Having said that I > don't want to present an analysis of my results from which I conclude > what I can, only to then discover later that my analysis is simply wrong > and I fail for it.With real-life experiments, one can never do more than one's best. If there is a "truth" out there, I have never found it. If your supervisor is worth his salary, he will look at the arguments you present and see if you make sense of them. There will always be one more argument to present, but one have to stop somewhere. After all, one have only so much time available.> > From your phrasing of the problem, I suspect I know how you think > > about such matters. You would have to search out what your > > supervisor thinks about the matter, and depending on what you > > find, think very carefully about how you want to play the game. > > > > My impression is he's pretty sharp on signal processing. Having said > that he knows very little about psychology which is the focus of the > experiment.Is he good with experimental work?> > A cleared-out consciousness is one thing. A cleared-out bank > > account might be far more serious. > > > > Rune > > > > Do you mean a cleared out concience?Yep. as you might have noticed, orthography is not among my stronger sides...> I haven't had one of them for > years. If you do mean what you wrote then I am planning to clear out my > bank account in order to clear my consciousness just as soon as I hand > this report in. Mmmmmm Whiskey!Laphroaigh is my favourite... made a lasting impression. Bad jokes aside: I meant that some people want your results to correspond to their truths. If you encounter any of those, you will have some pretty far-reaching decisions to make; most of which affect the in-flux side of your bank account. Rune
