Hello FFT can convert a given number of samples from time domain to frequency domain. Ok... what about the inverse? Basically I'd like to have something like that: input -> FFT -> "something" -> output with input = output I think I could do that generating sinusoides on the frequency/amplitude given by FFT and summing them, but it probably will be very slow Any ideas? thanks
Compose FFT
Started by ●July 5, 2004
Reply by ●July 5, 20042004-07-05
Luis Fernando wrote:> Hello > > FFT can convert a given number of samples from time domain to > frequency domain. > Ok... what about the inverse? > > Basically I'd like to have something like that: > > input -> FFT -> "something" -> output > with input = outputYou are describing an inverse FFT. ifft( fft( x ) ) == x The mathematics are almost exactly the same as the forward FFT. I'm curious. How did you learn about the FFT without being exposed to the inverse FFT? -- Mark
Reply by ●July 6, 20042004-07-06
Well, the FFT is invertible - just use the iFFT. But since in your application input = output, there is probably no reason to use it at all...? --smb wavebox@wavebox.com.br (Luis Fernando) wrote in message news:<fb78d2e7.0407051418.72ae4004@posting.google.com>...> Hello > > FFT can convert a given number of samples from time domain to > frequency domain. > Ok... what about the inverse? > > Basically I'd like to have something like that: > > input -> FFT -> "something" -> output > with input = output > > I think I could do that generating sinusoides on the > frequency/amplitude given by FFT and summing them, but it probably > will be very slow > > Any ideas? > > thanks
in fact I didn't learn that i'm still learning many things in a very short time and i was told to make an FFT... then I found the FFT function on VisualDSP++, called dit and it worked ;) Mark Borgerding <mark@borgerding.net> wrote in message news:<UslGc.186055$DG4.167479@fe2.columbus.rr.com>...> Luis Fernando wrote: > > Hello > > > > FFT can convert a given number of samples from time domain to > > frequency domain. > > Ok... what about the inverse? > > > > Basically I'd like to have something like that: > > > > input -> FFT -> "something" -> output > > with input = output > > > You are describing an inverse FFT. > ifft( fft( x ) ) == x > > The mathematics are almost exactly the same as the forward FFT. > > I'm curious. How did you learn about the FFT without being exposed to > the inverse FFT? > > > -- Mark
yes of course that's a test ;) spam@dspdimension.com (Stephan M. Bernsee) wrote in message news:<42c34ef.0407052023.24174d2a@posting.google.com>...> Well, the FFT is invertible - just use the iFFT. But since in your > application input = output, there is probably no reason to use it at > all...? > > --smb
