Hi all, I am currently doing a fftw_2d_r2c and i want to know if I must normalize my datas to get a relevant representation of the real part and the imaginary part in the frequency domain. Assuming that i have an image of size nx*ny, I have supposed that I should divide by sqrt(nx*ny), is this right? Greetings, Greg
normalizing fftw in the frequency domain
Started by ●April 20, 2006
Reply by ●April 20, 20062006-04-20
greg838 skrev:> Hi all, > > I am currently doing a fftw_2d_r2c and i want to know if I must normalize > my datas to get a relevant representation of the real part and the > imaginary part in the frequency domain.I don't think you *have* to do that, unless your application uses some image intensity to estimate some physical parameter. In those cases, the sensors as well as each step in the processing chain are meticulously calibrated. There aren't very many applications of that sort around.> Assuming that i have an image of > size nx*ny, I have supposed that I should divide by sqrt(nx*ny), is this > right?Seems right to me. To check, try and see if Parseval's identity holds (matlab notation): %%%%%%%%%%%%%%%%%%%%%%%%%%%%% N = 512; M = 512; x=rand(N,M); X = fft2(x)/sqrt(N*M); Ex = 0; EX = 0; for n=1:N for m=1M Ex = Ex + abs(x(n,m))^2; EX = EX + abs(X(n,m))^2; end end r=Ex/EX; %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% If r==1 at the end of this script, you have found the correct scaling constant. Rune
Reply by ●May 2, 20062006-05-02
