Coding Gain
Started by john ●April 21, 2006
Hello all,
I have a question about coding gain for a convolutional code. In the
books that I have, the coding gain is presented in the form of graph of
BER vs Eb/No for a given modulation format, typically BPSK. The coding
gain is the horizontal distance between the uncoded and coded curves on
the graph.
My question is, what if I change the modulation format to FSK instead?
I understand that both curves (coded and uncoded) will shift to the
right and change shape a bit, but will the coding gain (horizontal
distance between them) stay the same?
If it matters, at this point I am only considering hard decision, rate
1/2, K=7.
Regards,
John
john wrote:
> Hello all, > > I have a question about coding gain for a convolutional code. In the > books that I have, the coding gain is presented in the form of graph of > BER vs Eb/No for a given modulation format, typically BPSK. The coding > gain is the horizontal distance between the uncoded and coded curves on > the graph. > > My question is, what if I change the modulation format to FSK instead? > I understand that both curves (coded and uncoded) will shift to the > right and change shape a bit, but will the coding gain (horizontal > distance between them) stay the same? > > If it matters, at this point I am only considering hard decision, rate > 1/2, K=7. > > Regards, > > John >
I doubt that the coding gain will stay the same. What the code really does is shift the uncoded line to the left a certain amount. Since an incoherently detected FSK signal isn't going to have the same shape to it's waterfall curve the vertical distance (coding gain) will be different. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
Tim Wescott wrote:
> john wrote: > > > Hello all, > > > > I have a question about coding gain for a convolutional code. In the > > books that I have, the coding gain is presented in the form of graph of > > BER vs Eb/No for a given modulation format, typically BPSK. The coding > > gain is the horizontal distance between the uncoded and coded curves on > > the graph. > > > > My question is, what if I change the modulation format to FSK instead? > > I understand that both curves (coded and uncoded) will shift to the > > right and change shape a bit, but will the coding gain (horizontal > > distance between them) stay the same? > > > > If it matters, at this point I am only considering hard decision, rate > > 1/2, K=7. > > > I doubt that the coding gain will stay the same. What the code really > does is shift the uncoded line to the left a certain amount.
As far as I know, use of coding shifts the BER curve up and to the left, which is why it usually crosses over with the uncoded curve (this wouldn't happen if was just a left shift).
> Since an > incoherently detected FSK signal isn't going to have the same shape to > it's waterfall curve the vertical distance (coding gain) will be different.
Coding gain is generally defined as the *horizontal* gain, i.e. the reduction in Eb/No required for a given BER. In fact, I think the *vertical* gain (BER improvement at a given uncoded BER) will remain constant, at least for hard-decision. -- Oli
Oli Filth wrote:
> Tim Wescott wrote: > > john wrote: > > > > > Hello all, > > > > > > I have a question about coding gain for a convolutional code. In the > > > books that I have, the coding gain is presented in the form of graph of > > > BER vs Eb/No for a given modulation format, typically BPSK. The coding > > > gain is the horizontal distance between the uncoded and coded curves on > > > the graph. > > > > > > My question is, what if I change the modulation format to FSK instead? > > > I understand that both curves (coded and uncoded) will shift to the > > > right and change shape a bit, but will the coding gain (horizontal > > > distance between them) stay the same? > > > > > > If it matters, at this point I am only considering hard decision, rate > > > 1/2, K=7. > > > > > Since an > > incoherently detected FSK signal isn't going to have the same shape to > > it's waterfall curve the vertical distance (coding gain) will be different. > > Coding gain is generally defined as the *horizontal* gain, i.e. the > reduction in Eb/No required for a given BER. > > In fact, I think the *vertical* gain (BER improvement at a given > uncoded BER) will remain constant, at least for hard-decision.
As an addendum, I believe that asymptotic coding gain (ACG) remains constant too. As Eb/No goes to infinity, then probability of non-nearest-neighbour errors goes to zero quicker than nearest-neighbour errors, and are therefore negligible. Nearest-neighbor error distances are defined by the minimum/free distance of the code, which doesn't change with modulation scheme, so the ACG will be the same. -- Oli
Oli Filth wrote:
> Oli Filth wrote: > > Tim Wescott wrote: > > > john wrote: > > > > > > > Hello all, > > > > > > > > I have a question about coding gain for a convolutional code. In the > > > > books that I have, the coding gain is presented in the form of graph of > > > > BER vs Eb/No for a given modulation format, typically BPSK. The coding > > > > gain is the horizontal distance between the uncoded and coded curves on > > > > the graph. > > > > > > > > My question is, what if I change the modulation format to FSK instead? > > > > I understand that both curves (coded and uncoded) will shift to the > > > > right and change shape a bit, but will the coding gain (horizontal > > > > distance between them) stay the same? > > > > > > > > If it matters, at this point I am only considering hard decision, rate > > > > 1/2, K=7. > > > > > > > Since an > > > incoherently detected FSK signal isn't going to have the same shape to > > > it's waterfall curve the vertical distance (coding gain) will be different. > > > > Coding gain is generally defined as the *horizontal* gain, i.e. the > > reduction in Eb/No required for a given BER. > > > > In fact, I think the *vertical* gain (BER improvement at a given > > uncoded BER) will remain constant, at least for hard-decision. > > As an addendum, I believe that asymptotic coding gain (ACG) remains > constant too. As Eb/No goes to infinity, then probability of > non-nearest-neighbour errors goes to zero quicker than > nearest-neighbour errors, and are therefore negligible. > Nearest-neighbor error distances are defined by the minimum/free > distance of the code, which doesn't change with modulation scheme, so > the ACG will be the same. > > > -- > Oli
Thank you for the helpful replies. Intuitively, I think that the hard decision coding gain should be the same whether FSK or BPSK is used, as long as the uncoded BER entering the Viterbi decoder is the same in each case. But I was wondering if the specifics of the noise distribution influence the coding gain. For BPSK, assuming perfect synchronization, we apply a sinx/x filter to white Gaussian noise and take the real part. The result is real, Guassian, and at zero Hertz. For noncoherent FSK, we apply bandpass sinx/x filters at plus and minus the deviation, then take the magnitudes of each filter output and difference them. The resulting noise is not Gaussian -- I think it is Rayleigh or Rician but I honestly don't remember the details. John
john said the following on 21/04/2006 16:59:
> Oli Filth wrote: >> Oli Filth wrote: >>> Tim Wescott wrote: >>>> john wrote: >>>> >>>>> Hello all, >>>>> >>>>> I have a question about coding gain for a convolutional code. In the >>>>> books that I have, the coding gain is presented in the form of graph of >>>>> BER vs Eb/No for a given modulation format, typically BPSK. The coding >>>>> gain is the horizontal distance between the uncoded and coded curves on >>>>> the graph. >>>>> >>>>> My question is, what if I change the modulation format to FSK instead? >>>>> I understand that both curves (coded and uncoded) will shift to the >>>>> right and change shape a bit, but will the coding gain (horizontal >>>>> distance between them) stay the same? >>>>> >>>>> If it matters, at this point I am only considering hard decision, rate >>>>> 1/2, K=7. >>>>> >>>> Since an >>>> incoherently detected FSK signal isn't going to have the same shape to >>>> it's waterfall curve the vertical distance (coding gain) will be different. >>> Coding gain is generally defined as the *horizontal* gain, i.e. the >>> reduction in Eb/No required for a given BER. >>> >>> In fact, I think the *vertical* gain (BER improvement at a given >>> uncoded BER) will remain constant, at least for hard-decision. >> As an addendum, I believe that asymptotic coding gain (ACG) remains >> constant too. As Eb/No goes to infinity, then probability of >> non-nearest-neighbour errors goes to zero quicker than >> nearest-neighbour errors, and are therefore negligible. >> Nearest-neighbor error distances are defined by the minimum/free >> distance of the code, which doesn't change with modulation scheme, so >> the ACG will be the same. >> > Thank you for the helpful replies. Intuitively, I think that the hard > decision coding gain should be the same whether FSK or BPSK is used, as > long as the uncoded BER entering the Viterbi decoder is the same in > each case. But I was wondering if the specifics of the noise > distribution influence the coding gain.
As long as the errors are independent, I would imagine the distribution is irrelevant. By definition, in hard-decision decoding, the error magnitudes (statistically given by noise distribution) are not used. Therefore, the only thing directly affected by noise is pre-decoder bit errors. -- Oli
On Fri, 21 Apr 2006 16:28:51 GMT, Oli Filth <catch@olifilth.co.uk>
wrote:
>john said the following on 21/04/2006 16:59: >> Oli Filth wrote: >>> >> Thank you for the helpful replies. Intuitively, I think that the hard >> decision coding gain should be the same whether FSK or BPSK is used, as >> long as the uncoded BER entering the Viterbi decoder is the same in >> each case. But I was wondering if the specifics of the noise >> distribution influence the coding gain. > >As long as the errors are independent, I would imagine the distribution >is irrelevant. By definition, in hard-decision decoding, the error >magnitudes (statistically given by noise distribution) are not used. >Therefore, the only thing directly affected by noise is pre-decoder bit >errors.
The distribution does matter for a lot of coding systems including convolutional coding. If the errors are clumped and about as long as the contraint length or longer, the decoder will have a much harder time maintaining the proper path through the trellis than if the errors are randomly distributed. This is often why convolutional codes are the inner codes for concatenated coding systems in gaussian channels...they work well on randomlly distributed errors. If the errors are clumped then block codes (like RS) are often a better choice. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Eric Jacobsen wrote:
> On Fri, 21 Apr 2006 16:28:51 GMT, Oli Filth <catch@olifilth.co.uk> > wrote: > > >john said the following on 21/04/2006 16:59: > >> Oli Filth wrote: > >>> > >> Thank you for the helpful replies. Intuitively, I think that the hard > >> decision coding gain should be the same whether FSK or BPSK is used, as > >> long as the uncoded BER entering the Viterbi decoder is the same in > >> each case. But I was wondering if the specifics of the noise > >> distribution influence the coding gain. > > > >As long as the errors are independent, I would imagine the distribution > >is irrelevant. By definition, in hard-decision decoding, the error > >magnitudes (statistically given by noise distribution) are not used. > >Therefore, the only thing directly affected by noise is pre-decoder bit > >errors. > > The distribution does matter for a lot of coding systems including > convolutional coding. If the errors are clumped and about as long as > the contraint length or longer, the decoder will have a much harder > time maintaining the proper path through the trellis than if the > errors are randomly distributed. > > This is often why convolutional codes are the inner codes for > concatenated coding systems in gaussian channels...they work well on > randomlly distributed errors. If the errors are clumped then block > codes (like RS) are often a better choice. > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.org
I agree about bursty errors. It turns out that the noncoherent FSK noise looks fairly white. The spectrum rolls off slowly, about 10 dB over 0 to Fs/2. The kurtosis is about 3. So from that I'd say the coding gain is not going to be much different than BPSK. John
Oli Filth wrote:
> Tim Wescott wrote: > >>john wrote: >> >> >>>Hello all, >>> >>>I have a question about coding gain for a convolutional code. In the >>>books that I have, the coding gain is presented in the form of graph of >>>BER vs Eb/No for a given modulation format, typically BPSK. The coding >>>gain is the horizontal distance between the uncoded and coded curves on >>>the graph. >>> >>>My question is, what if I change the modulation format to FSK instead? >>>I understand that both curves (coded and uncoded) will shift to the >>>right and change shape a bit, but will the coding gain (horizontal >>>distance between them) stay the same? >>> >>>If it matters, at this point I am only considering hard decision, rate >>>1/2, K=7. >>> >> >>I doubt that the coding gain will stay the same. What the code really >>does is shift the uncoded line to the left a certain amount. > > > As far as I know, use of coding shifts the BER curve up and to the > left, which is why it usually crosses over with the uncoded curve (this > wouldn't happen if was just a left shift). >
Dangit -- I had my right and left mixed up.
> > >>Since an >>incoherently detected FSK signal isn't going to have the same shape to >>it's waterfall curve the vertical distance (coding gain) will be different. > > > Coding gain is generally defined as the *horizontal* gain, i.e. the > reduction in Eb/No required for a given BER. > > In fact, I think the *vertical* gain (BER improvement at a given > uncoded BER) will remain constant, at least for hard-decision. >
That's the horizontal axis in my books (or at least in the graph in my head -- the one which I can't tell right from left). I should have said that explicitly, instead of being obscure. So I'll try again: The coder doesn't know squat about Eb, No, or anything else on that side of the detector. All it knows is what comes out of the detector. So the coding 'gain' is just a pretend number that depends not only on the modulation scheme and the demodulator, but on the nature of the channel. In fact, my first experience with radio modems was at medium frequencies* (around 300kHz). Radio on this band is dominated by electrostatic discharge noise. Such noise has a Cauer-like density function with effectively an infinite variance -- so barring absurd power increases on the transmitter you will _always_ have raw bit errors, which means that the coding 'gain' is effectively infinite. Since an infinite coding 'gain' is absurd, you find me using quote marks around the 'g' word. For details on the radio, it's whys and wherefores, see my master's thesis: http://www.wescottdesign.com/articles/MSK/mskTop.html. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
john wrote:
> Oli Filth wrote: > >>Oli Filth wrote: >> >>>Tim Wescott wrote: >>> >>>>john wrote: >>>> >>>> >>>>>Hello all, >>>>> >>>>>I have a question about coding gain for a convolutional code. In the >>>>>books that I have, the coding gain is presented in the form of graph of >>>>>BER vs Eb/No for a given modulation format, typically BPSK. The coding >>>>>gain is the horizontal distance between the uncoded and coded curves on >>>>>the graph. >>>>> >>>>>My question is, what if I change the modulation format to FSK instead? >>>>>I understand that both curves (coded and uncoded) will shift to the >>>>>right and change shape a bit, but will the coding gain (horizontal >>>>>distance between them) stay the same? >>>>> >>>>>If it matters, at this point I am only considering hard decision, rate >>>>>1/2, K=7. >>>>> >>>> >>>>Since an >>>>incoherently detected FSK signal isn't going to have the same shape to >>>>it's waterfall curve the vertical distance (coding gain) will be different. >>> >>>Coding gain is generally defined as the *horizontal* gain, i.e. the >>>reduction in Eb/No required for a given BER. >>> >>>In fact, I think the *vertical* gain (BER improvement at a given >>>uncoded BER) will remain constant, at least for hard-decision. >> >>As an addendum, I believe that asymptotic coding gain (ACG) remains >>constant too. As Eb/No goes to infinity, then probability of >>non-nearest-neighbour errors goes to zero quicker than >>nearest-neighbour errors, and are therefore negligible. >>Nearest-neighbor error distances are defined by the minimum/free >>distance of the code, which doesn't change with modulation scheme, so >>the ACG will be the same. >> >> >>-- >>Oli > > > Thank you for the helpful replies. Intuitively, I think that the hard > decision coding gain should be the same whether FSK or BPSK is used, as > long as the uncoded BER entering the Viterbi decoder is the same in > each case. But I was wondering if the specifics of the noise > distribution influence the coding gain. > > For BPSK, assuming perfect synchronization, we apply a sinx/x filter to > white Gaussian noise and take the real part. The result is real, > Guassian, and at zero Hertz. For noncoherent FSK, we apply bandpass > sinx/x filters at plus and minus the deviation, then take the > magnitudes of each filter output and difference them. The resulting > noise is not Gaussian -- I think it is Rayleigh or Rician but I > honestly don't remember the details. > > John >
Yes, distribution _does_ matter, sometimes a _lot_ -- see my post about atmospheric discharge noise for an extreme example. Coding 'gain' is only a valid measure for a given noise distribution, modulation format and demodulator design. It's a handy measure for reducing overall systems cost (should I go with the 1GW transmitter and no FEC, or the 1kW transmitter and a 4:1 code?), but beyond that it has little to recommend itself. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
