Subband - Affine projection algorithm
Started by thomas April 23, 2006
Dear All,
   I am doing a project on Variable step size Affine Projection
Algorithm with subbands.
It would be very helpful if i get a Matlab code of filterbank
application in any adaptive filtering algorithm (LMS,NLMS,RLS or APA).
 Awaiting an earliest reply.
Thanks.
Regards
Thomas Joseph.
>Dear All, > > I am doing a project on Variable step size Affine Projection >Algorithm with subbands. >It would be very helpful if i get a Matlab code of filterbank >application in any adaptive filtering algorithm (LMS,NLMS,RLS or APA).
You want code for any of the adaptive filtering algorithms!!!
> > Awaiting an earliest reply. >
Try Mathworks' website. There is a LMS toolbox available. - Krishna
No, he wants an example of adaptive SUBBAND processing with any adaptive filtering algorithm so that he can, I presume, see the structure and replace the adaptive algorithm used with APA code. Original poster - your best bet is a Google search. Someone out there has what you want - probably not Mathworks, however. BR, Dan
HI Dan,
  thanks a lot Dan, i fixed the problem.
Kind Regards
Thomas.
dan wrote:
> >> You want code for any of the adaptive filtering algorithms!!! > > No, he wants an example of adaptive SUBBAND processing with any > adaptive filtering algorithm so that he can, I presume, see the > structure and replace the adaptive algorithm used with APA code. > > Original poster - your best bet is a Google search. Someone out there > has what you want - probably not Mathworks, however. > > BR, > Dan
Thanks Krishna
