Hello All, This is regarding the DMA Initialization Problem I am facing in C6416 DSP. I need to transfer 2 frames of 10 elements from DMA to Serial Port Transmit Register(DXR) and the Transmitter empty event from the Serial Port is the synchronization event for the DMA. The DMA is element synchronized, and as far as I understand, the end of Transfer interrupt should come as soon as the DMA Transfers 20 elements i.e (2 Frames of 10 elements each). But I am not getting, instead if I do frame synchronization, end of transfer element comes but only the last element is transferred to the Serial Port. The settings of the Serial Port is 1) Frame Transmit Length is 10 2) Transmit word length is 32 bit. 3) The clock setting is such that I am getting 1 MHz output clock. If I have missed out any settings , please do let me know. I think there should be some problem with the DMA Settings. Waiting for your response at the earliest, Thanks in advance, Srikanth
DMA-MCBSP-C6416
Started by ●April 24, 2006
