http://energy.51.net/hice218x/ http://energy.51.net/hice218x/hice218x.jpg 1. What's new? Home page setup[Jul.4, 2004] 2. Introduction to HICE-218x HICE-218x is another emulator for ADSP-218x family fixed-point DSPs. It's compatible with EZ-ICE-218x, but with a few improvements: * USB1.1 interface, powered by USB, no AC adapter needed * Fast data transfer at 921600bps * Support 5V, 3.3V, 2.5V and 1.8V DSP chips * More stable, almost no need to reset * Work with VisualDSP 6.1, and VisualDSP++ 3.x * many others... 3. What's different between HICE-218x and EZ-ICE-218x? HICE-218x is a new emulator for the ADSP-218x family DSPs. It uses USB interface and COM-to-USB converting technology to connect to the VisualDSP IDE. Since the power waste of HICE-218x is very low, it's powered by the USB directly. To use it, just plug in the USB cable, and a new COM port will be installed in your computer. Select the new COM port, such as COM3, and the VisualDSP software will connect with HICE-218x automatically at the speed of 921600 bps. HICE-218x is not just a copy of EZ-ICE-218x. Both the PCB and the firmwire are totally new designed. Due to ustable serial port communication, EZ-ICE-218x will lose connection frequently. HICE-218x has a more robust communication protocol, and you don't need to shut down VisualDSP IDE and reset the emulator so frequently. HICE-218x is cheap, the price will be less than USD300. 4. Developing Progress HICE-218x is under developing. Task 5: System testing. TBD. Task 4: firmwire porting and debuging. TBD. Task 3: Serial port communication protocol debugging. Almost finished @ July 4, 2004 Task 2: PCB design. Finished @ June 20, 2004 Task 1: ADSP-218x family DSP EZICE protocol analyzing. Almost finished @ May 5, 2004
[ANN] HICE-218x (ADSP-218x emulator) developing progress...
Started by ●July 4, 2004
Reply by ●July 6, 20042004-07-06
Is it going to be open source? "qhe" <qhe@nospam.tsinghua.org.cn> wrote in message news:cc9bqu$1tpf$1@mail.cn99.com...> http://energy.51.net/hice218x/ > http://energy.51.net/hice218x/hice218x.jpg > > 1. What's new? > Home page setup[Jul.4, 2004] > > 2. Introduction to HICE-218x > HICE-218x is another emulator for ADSP-218x family fixed-point DSPs.It's> compatible with EZ-ICE-218x, but with a few improvements: > * USB1.1 interface, powered by USB, no AC adapter needed > * Fast data transfer at 921600bps > * Support 5V, 3.3V, 2.5V and 1.8V DSP chips > * More stable, almost no need to reset > * Work with VisualDSP 6.1, and VisualDSP++ 3.x > * many others... > > 3. What's different between HICE-218x and EZ-ICE-218x? > HICE-218x is a new emulator for the ADSP-218x family DSPs. It uses USB > interface and COM-to-USB converting technology to connect to the VisualDSP > IDE. Since the power waste of HICE-218x is very low, it's powered by theUSB> directly. To use it, just plug in the USB cable, and a new COM port willbe> installed in your computer. Select the new COM port, such as COM3, and the > VisualDSP software will connect with HICE-218x automatically at the speedof> 921600 bps. > HICE-218x is not just a copy of EZ-ICE-218x. Both the PCB and the > firmwire are totally new designed. Due to ustable serial portcommunication,> EZ-ICE-218x will lose connection frequently. HICE-218x has a more robust > communication protocol, and you don't need to shut down VisualDSP IDE and > reset the emulator so frequently. > HICE-218x is cheap, the price will be less than USD300. > > 4. Developing Progress > HICE-218x is under developing. > Task 5: System testing. TBD. > Task 4: firmwire porting and debuging. TBD. > Task 3: Serial port communication protocol debugging. Almost finished@> July 4, 2004 > Task 2: PCB design. Finished @ June 20, 2004 > Task 1: ADSP-218x family DSP EZICE protocol analyzing. Almost finished@> May 5, 2004 > >
Reply by ●July 13, 20042004-07-13
No, at least in the first few months. "KG7HF" <KG7HF@amsat.org> news:IvadnU-HD5IlsnbdRVn-vg@adelphia.com...> Is it going to be open source? > > > "qhe" <qhe@nospam.tsinghua.org.cn> wrote in message > news:cc9bqu$1tpf$1@mail.cn99.com... > > http://energy.51.net/hice218x/ > > http://energy.51.net/hice218x/hice218x.jpg > > > > 1. What's new? > > Home page setup[Jul.4, 2004] > > > > 2. Introduction to HICE-218x > > HICE-218x is another emulator for ADSP-218x family fixed-point DSPs. > It's > > compatible with EZ-ICE-218x, but with a few improvements: > > * USB1.1 interface, powered by USB, no AC adapter needed > > * Fast data transfer at 921600bps > > * Support 5V, 3.3V, 2.5V and 1.8V DSP chips > > * More stable, almost no need to reset > > * Work with VisualDSP 6.1, and VisualDSP++ 3.x > > * many others... > > > > 3. What's different between HICE-218x and EZ-ICE-218x? > > HICE-218x is a new emulator for the ADSP-218x family DSPs. It usesUSB> > interface and COM-to-USB converting technology to connect to theVisualDSP> > IDE. Since the power waste of HICE-218x is very low, it's powered by the > USB > > directly. To use it, just plug in the USB cable, and a new COM port will > be > > installed in your computer. Select the new COM port, such as COM3, andthe> > VisualDSP software will connect with HICE-218x automatically at thespeed> of > > 921600 bps. > > HICE-218x is not just a copy of EZ-ICE-218x. Both the PCB and the > > firmwire are totally new designed. Due to ustable serial port > communication, > > EZ-ICE-218x will lose connection frequently. HICE-218x has a more robust > > communication protocol, and you don't need to shut down VisualDSP IDEand> > reset the emulator so frequently. > > HICE-218x is cheap, the price will be less than USD300. > > > > 4. Developing Progress > > HICE-218x is under developing. > > Task 5: System testing. TBD. > > Task 4: firmwire porting and debuging. TBD. > > Task 3: Serial port communication protocol debugging. Almostfinished> @ > > July 4, 2004 > > Task 2: PCB design. Finished @ June 20, 2004 > > Task 1: ADSP-218x family DSP EZICE protocol analyzing. Almostfinished> @ > > May 5, 2004 > > > > > >
If all you are doing is copying the old protocol, won't you be copying the bugs in the ADI ice as well? "qhe" <qhe@nospam.tsinghua.org.cn> wrote in message news:cd1123$24tk$1@mail.cn99.com...> No, at least in the first few months. > > "KG7HF" <KG7HF@amsat.org> news:IvadnU-HD5IlsnbdRVn-vg@adelphia.com... > > Is it going to be open source? > > > > > > "qhe" <qhe@nospam.tsinghua.org.cn> wrote in message > > news:cc9bqu$1tpf$1@mail.cn99.com... > > > http://energy.51.net/hice218x/ > > > http://energy.51.net/hice218x/hice218x.jpg > > > > > > 1. What's new? > > > Home page setup[Jul.4, 2004] > > > > > > 2. Introduction to HICE-218x > > > HICE-218x is another emulator for ADSP-218x family fixed-point DSPs. > > It's > > > compatible with EZ-ICE-218x, but with a few improvements: > > > * USB1.1 interface, powered by USB, no AC adapter needed > > > * Fast data transfer at 921600bps > > > * Support 5V, 3.3V, 2.5V and 1.8V DSP chips > > > * More stable, almost no need to reset > > > * Work with VisualDSP 6.1, and VisualDSP++ 3.x > > > * many others... > > > > > > 3. What's different between HICE-218x and EZ-ICE-218x? > > > HICE-218x is a new emulator for the ADSP-218x family DSPs. It uses > USB > > > interface and COM-to-USB converting technology to connect to the > VisualDSP > > > IDE. Since the power waste of HICE-218x is very low, it's powered bythe> > USB > > > directly. To use it, just plug in the USB cable, and a new COM portwill> > be > > > installed in your computer. Select the new COM port, such as COM3, and > the > > > VisualDSP software will connect with HICE-218x automatically at the > speed > > of > > > 921600 bps. > > > HICE-218x is not just a copy of EZ-ICE-218x. Both the PCB and the > > > firmwire are totally new designed. Due to ustable serial port > > communication, > > > EZ-ICE-218x will lose connection frequently. HICE-218x has a morerobust> > > communication protocol, and you don't need to shut down VisualDSP IDE > and > > > reset the emulator so frequently. > > > HICE-218x is cheap, the price will be less than USD300. > > > > > > 4. Developing Progress > > > HICE-218x is under developing. > > > Task 5: System testing. TBD. > > > Task 4: firmwire porting and debuging. TBD. > > > Task 3: Serial port communication protocol debugging. Almost > finished > > @ > > > July 4, 2004 > > > Task 2: PCB design. Finished @ June 20, 2004 > > > Task 1: ADSP-218x family DSP EZICE protocol analyzing. Almost > finished > > @ > > > May 5, 2004 > > > > > > > > > > > >
