Greg Berchin's filter design method
Started by Martin Eisenberg ●April 24, 2006
Folks,
a bit over a year ago, in message
<q99bu0lqffhjhd40vc1n0689nfcidv7s12@4ax.com>, Greg Berchin outlined a
filter design method he had invented and there was talk of writing an
article about it. Has that come to pass in the meantime?
Martin
Quidquid latine scriptum sit, altum viditur.
Rick Lyons and I were exchanging drafts of the article, and then he had
to put things on hold for more pressing matters.  I have not heard from
him in quite some time.  (I am astonished that a year has passed.  Time
flies.)
Greg Berchin
Greg Berchin wrote:
> Rick Lyons and I were exchanging drafts of the article, and then > he had to put things on hold for more pressing matters. I have > not heard from him in quite some time. (I am astonished that a > year has passed. Time flies.)
That's a pity. Would you be comfortable with sending me a draft? Otherwise, do you have any quick hints on using what you wrote back then? (Your message is at http://groups.google.com/group/comp.dsp/msg/2c307e8e77fb5178 .) Martin -- Quidquid latine scriptum sit, altum viditur.
On Wed, 26 Apr 2006 21:21:49 +0000 (UTC), Martin Eisenberg
No, but in the next few days I'll try to put together some Matlab code that implements the algorithm. Then perhaps I can make it available to interested parties on a "not for commercial use" basis.
>Otherwise, do you have any quick hints on using what you wrote back >then?
Yes; two of them. 1. Artificially adding a few samples of delay to the input data almost always improves the least-squares fit, especially at high frequencies. (If you use a pure cosine input and your frequency response tends toward an odd multiple of 90&#4294967295; as you approach half the sampling frequency, the output samples occur near the zero crossings and you have an observability problem -- a "finite-input-zero-output" situation. Delay minimizes the problem.) 2. Modifying the algorithm to perform a "weighted least squares" fit is trivially easy. I have found that the fit can often be improved by weighting the data by "1/magnitude" (lower magnitude => higher weighting). Furthermore, for input data that are linearly spaced in frequency, weighting low frequency data higher than high frequency data is often beneficial. Greg Berchin
Thanks, Greg!
Martin
On Mon, 24 Apr 2006 20:49:58 -0500, Greg Berchin
<76145.2455@compuswerve.com> wrote:
>Rick Lyons and I were exchanging drafts of the article, and then he had >to put things on hold for more pressing matters. I have not heard from >him in quite some time. (I am astonished that a year has passed. Time >flies.) > >Greg Berchin
Hi Greg, Sweet merciful Jesus in Heaven!! It's been so long! I've been waitin' to hear from you and you've been waiting to hear back from me. All of a sudden it's nine months later! Somehow we (perhaps I) have screwed up our communications. I took a quick look at my old E-mails and I see that you and I exchanged 10-15 E-mails last year. Darn, sometimes I put things "on the back burner" and then I don't realize they've falling off the stove top and out of sight completely. Greg, I'll get in touch with you. [-Rick-]
I have Matlab code for the algorithm.  If interested in a copy, send me
a private email message -- remove the "w" from my email address.
Private, non-commercial use only.
No guarantees, warranties, promises, assertions, hopes, dreams, or
delusions of any kind.  Please inform me of any errors that are found.
Greg Berchin
Greg Berchin <76145.2455@compuswerve.com> wrote in
news:k5q452ti91k19iksmnjtuq93ujgr20ru82@4ax.com:
> I have Matlab code for the algorithm. If interested in a copy, send me > a private email message -- remove the "w" from my email address. > > Private, non-commercial use only. > > No guarantees, warranties, promises, assertions, hopes, dreams, or > delusions of any kind. Please inform me of any errors that are found. > > Greg Berchin >
Hi Greg, What do you specifically mean by non commercial use? Do you mean don't use my method in a filter design product or do you mean don't use the results of my method (like filter coefficients) in a commercial product? -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
On Fri, 28 Apr 2006 20:27:44 GMT, Al Clark <dsp@danvillesignal.com>
wrote:
>What do you specifically mean by non commercial use? Do you mean don't use >my method in a filter design product or do you mean don't use the results >of my method (like filter coefficients) in a commercial product?
I mean the algorithm was first published in 1985, so it's in the public domain. If you write your own software that implements the algorithm, then it's yours to do with as you please. But don't use software that *I* wrote to make *you* money. Greg
"Greg Berchin" <76145.2455@compuswerve.com> wrote in message
news:390552t5dnsvd3lo4g9et0nsgesd5qh5r3@4ax.com...
> On Fri, 28 Apr 2006 20:27:44 GMT, Al Clark <dsp@danvillesignal.com> > wrote: > > >What do you specifically mean by non commercial use? Do you mean don't
use
> >my method in a filter design product or do you mean don't use the results > >of my method (like filter coefficients) in a commercial product? > > I mean the algorithm was first published in 1985, so it's in the public > domain. If you write your own software that implements the algorithm, > then it's yours to do with as you please. But don't use software that > *I* wrote to make *you* money. > > Greg
I dunno if this answers Al's question. I can see that you wouldn't want your code to be used in a filter design package (or similar) that Al might be selling for money. I'm not sure if you'll be upset if Al (or anyone) uses your software to help in creating filters that in turn are used in my application, which sells for money. Not that I plan to use your software, but I'm still curious. Cheers Bhaskar
