Many DAW's offer internal 32 bit floating point data transfer and processing. The question is, since the processing is done at 32 bit (and 64 bit) floating point then shouldn't dither be applied at 24 bits when exporting to a 24 bit int format? Also, even if the source material is at 16 bit int, shouldn't dither be applied at the end, since 32 bit float processing will produce information beyond the resolution of 16 bits? On the Cakewalk Forum, I believe this was answered in the affirmative: <http://www.cakewalk.com/forum/tm.asp?m=119201> It's a very long discussion, but if you wade through it you get these points: 1. 32 bit float gives an actual 25 bits of resolution/information. 2. If no processing has been done, no dither is necessary even though the signal has been converted to 32 bit float. 3. You should always dither your final output, whether 24 bit or 16 bit unless no processing has been done. 4. If you are going to do further processing, export to 24 bit using a non-noise shaped dither at 24 bits. 5. The distortion that occurs when you DON'T dither is not necessarily audible. It could be that point 5. is the overriding factor making the discussion irrelevant. But as far as I can tell, to avoid the distortion that occurs when reducing bit depths you should dither your final output after DSP regardless of whether your source is 16 bit or 24 bit, and regardless of whether your destination is 24 bit or 16 bit. I'd appreciate comments on this, but I'd also appreciate anyone who replies examining that thread above first, since that's where all of this is hashed out. I'm bringing this up here because I'd like to know where the discussion on the Cakewalk Forum went wrong. Thanks.
Dither audio signal to 24 bits
Started by ●July 4, 2004
Reply by ●July 5, 20042004-07-05
On Sun, 4 Jul 2004 14:38:09 +0000 (UTC), scorey_plonk@waterford.org wrote:>Many DAW's offer internal 32 bit floating point data transfer and >processing. The question is, since the processing is done at 32 bit >(and 64 bit) floating point then shouldn't dither be applied at 24 >bits when exporting to a 24 bit int format? Also, even if the source >material is at 16 bit int, shouldn't dither be applied at the end, >since 32 bit float processing will produce information beyond the >resolution of 16 bits? > >On the Cakewalk Forum, I believe this was answered in the affirmative: ><http://www.cakewalk.com/forum/tm.asp?m=119201> It's a very long >discussion, but if you wade through it you get these points: > >1. 32 bit float gives an actual 25 bits of resolution/information. >2. If no processing has been done, no dither is necessary even though >the signal has been converted to 32 bit float. >3. You should always dither your final output, whether 24 bit or 16 >bit unless no processing has been done. >4. If you are going to do further processing, export to 24 bit using a >non-noise shaped dither at 24 bits. >5. The distortion that occurs when you DON'T dither is not necessarily >audible. > >It could be that point 5. is the overriding factor making the >discussion irrelevant. But as far as I can tell, to avoid the >distortion that occurs when reducing bit depths you should dither your >final output after DSP regardless of whether your source is 16 bit or >24 bit, and regardless of whether your destination is 24 bit or 16 >bit.That's the "correct" thing to do. It's a lot more important to dither when the destination is 16 bits, because the distortion products will be 48dB louder than when going from something higher to 24 bits. Someone in that link (I did glance over it...) said he could hear a difference between dithered and non-dithered 32float-to-24bits, and I don't know maybe he does, but perhaps the software is doing something else that makes it not sound as good that adding the dither helps with.>I'd appreciate comments on this, but I'd also appreciate anyone who >replies examining that thread above first, since that's where all of >this is hashed out. I'm bringing this up here because I'd like to >know where the discussion on the Cakewalk Forum went wrong.This sort of thing has been discussed ad nauseum on rec.audio.pro over the years, by people who do this stuff a lot, you might want to read some of the archives through http://groups.google.com and if (when) you still have questions, post over there.>Thanks.
Well, I've not read the discussion on the Cakewalk forum, but in a nutshell, dithering trades off distortion for noise. Since noise is always cumulative, this is not something you would choose to do automatically but rather something you would decide to use in some cases, and in some rather not. The importance of dither decreases as the wordlength of the output increases. If your intermediate resolution across the whole processing chain is 32 or 64bit floating point you don't have to worry about requantization distortion that occurs *within* that part of the signal path during processing. And if all you do is a straight "software playthrough" 16 bit int -> 32 bit fp -> 16 bit int you don't even have to worry about requantization at all. But as for the *output* wordlength: if your target resolution is 8 or 16 bit, dither can be important because the distortion products from the requantization may be above your noise floor and therefore apparent. If your target resolution is > 16bit we're talking about distortion that occurs below or at -100dB DFS, you usually have enough noise sources in your signal chain already (the noise of the A/D converter(s) and (pre)amp(s) during track recording for example, or the noise floor contained in a 16bit source file) that will mask the distortion products resulting from a requantization to 24bit int after the 32bit fp chain, so there's no need to add additional dither noise. This is especially true in a multitrack environment where the noise from all tracks adds up quickly and all tracks are scaled and mixed at different volumes. I'd say, for the case of 24bit output wordlength you wouldn't need to worry much about requantization distortion, because in practice, (1) the reproduction equipment generally can't handle the dynamic range to make it audible and (2) there is generally enough noise present at the required level before the requantization occurs that does the job for you. There may be one exception where I could see an advantage in dithering during requantization to 24bit: If you're working entirely in software, without any recorded tracks from the analog world (ie. using softsynths only) it might be of advantage if you use dithering in the 24bit case, too, because some of these synths generate their signals algorithmically and therefore contribute only very little to the overall noise floor. Does that help? --smb (DSP guy @ Prosoniq) PS: I agree that this topic has been discussed in the rec.audio.pro NG and on some mailing lists ad nauseam, and be aware that there are always some extravagant claims from people who hear all kinds of things (mostly without ever subjecting themselves to a double-blind test), so I'd rather not go into this deeper than necessary here. Dither noise is nothing mythical, it's a tool. Like other tools, sometimes it makes sense to use it to yield an advantage, sometimes it doesn't do anything besides adding even more noise to an already noisy signal.
On Mon, 5 Jul 2004 12:54:57 UTC, spam@dspdimension.com (Stephan M. Bernsee) wrote:> PS: I agree that this topic has been discussed in the rec.audio.pro NG > and on some mailing lists ad nauseam, and be aware that there are > always some extravagant claims from people who hear all kinds of > things (mostly without ever subjecting themselves to a double-blind > test), so I'd rather not go into this deeper than necessary here.That's exactly why I asked on this group. There's a much higher signal to noise ratio here.>Dither noise is nothing mythical, it's a tool. Like other tools, >sometimes it makes sense to use it to yield an advantage, sometimesit>doesn't do anything besides adding even more noise to an alreadynoisy>signal.What about on the ADC stage? If the noise floor of your mics, pres and environment is higher than the resolution of your converter (-96dBFS for a 16 bit converter, yes?), do you need to add any additional dither noise to the signal before conversion?
Reply by ●July 6, 20042004-07-06
scorey_plonk@waterford.org wrote:> On Mon, 5 Jul 2004 12:54:57 UTC, spam@dspdimension.com (Stephan M. > Bernsee) wrote: > >>PS: I agree that this topic has been discussed in the rec.audio.pro NG >>and on some mailing lists ad nauseam, and be aware that there are >>always some extravagant claims from people who hear all kinds of >>things (mostly without ever subjecting themselves to a double-blind >>test), so I'd rather not go into this deeper than necessary here. > > > That's exactly why I asked on this group. There's a much higher > signal to noise ratio here. > > >>Dither noise is nothing mythical, it's a tool. Like other tools, >>sometimes it makes sense to use it to yield an advantage, sometimes > > it > >>doesn't do anything besides adding even more noise to an already > > noisy > >>signal. > > > What about on the ADC stage? If the noise floor of your mics, pres > and environment is higher than the resolution of your converter > (-96dBFS for a 16 bit converter, yes?), do you need to add any > additional dither noise to the signal before conversion?You NEVER want to add noise to the analog signal unless you want to cover something else up. Dither isn't noise for noise's sake, it's a way to convert quantization noise to something less offensive. An analog signal has no quantization noise. Why would you dither it? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Mon, 05 Jul 2004 23:39:38 -0400, Jerry Avins <jya@ieee.org> wrote:>scorey_plonk@waterford.org wrote:>> What about on the ADC stage? If the noise floor of your mics, pres >> and environment is higher than the resolution of your converter >> (-96dBFS for a 16 bit converter, yes?), do you need to add any >> additional dither noise to the signal before conversion?Yes, the included noise will tend to "self-dither" the signal, but without the added dither noise, the noise already there can sound "grainy." So even in this case, adding the appropriate amount of dither noise can help preserve the original signal.>You NEVER want to add noise to the analog signal unless you want to >cover something else up. Dither isn't noise for noise's sake, it's a way >to convert quantization noise to something less offensive. An analog >signal has no quantization noise. Why would you dither it?If you're going from a analog into a "less-than-ideal" (16 bits or less) A/D, adding noise for dither can help. An A/D converter is a "bit-reduction" device that goes from lots of bits (infinite if you listen to some people argue it) down to 16 bits, or however many bits it gives. Here are my "usual links," the first involving A/D's, the second descriobes dither totally in the "digital domain" [pun on the name of the firm]: http://www.national.com/an/AN/AN-804.pdf Click on articles, then dither: http://digido.com>Jerry
scorey_plonk wrote: ...> 1. 32 bit float gives an actual 25 bits of resolution/information.There seems to be quite some disagreement about this in your forum. I was down that avenue as well (search the comp.dsp archive). A 32bit float can represent all the numbers a 25bit two's complement integer can (plus lot's more). For unsigned 25bit integer you need to sign the integer first (by offseting), otherwise you loose information when you convert to 32bit float.> 2. If no processing has been done, no dither is necessary even though > the signal has been converted to 32 bit float.As long as you don't requantize, you don't need dither. Example: 1) Conversion from 25bit two's complement -> 32bit floating-point -> 25bit two's complement can be done without requantisation. 2) Conversion from 32bit two's complement -> 32bit floating-point -> 32bit two's complement _cannot_ be done without requantisation.> 3. You should always dither your final output, whether 24 bit or 16 > bit unless no processing has been done.You should dither when you requantize - for example, you must dither when converting a 24bit recording to 16bits (even if no processing is done).> 4. If you are going to do further processing, export to 24 bit using a > non-noise shaped dither at 24 bits.24bits two's complement is fine for storing (transfering) digital audio - 32bit floating-point is better. The quantisation in 32bit float is much finer than 24 (or 25) bit two's complement. If you want to, you can add dither when converting from 32bit float to 24bit two's complement. Your dither noise will drown in the noise floor of the analog audio chain, it won't make much difference.> 5. The distortion that occurs when you DON'T dither is not necessarily > audible. > > It could be that point 5. is the overriding factor making the > discussion irrelevant. But as far as I can tell, to avoid the > distortion that occurs when reducing bit depths you should dither your > final output after DSP regardless of whether your source is 16 bit or > 24 bit, and regardless of whether your destination is 24 bit or 16 > bit. > > I'd appreciate comments on this, but I'd also appreciate anyone who > replies examining that thread above first, since that's where all of > this is hashed out. I'm bringing this up here because I'd like to > know where the discussion on the Cakewalk Forum went wrong.You can also search the comp.dsp archives - lot's of talk about dither there as well. Regards, Andor
The standard range for 32bit float audio is +- 1.0, which makes full use of the 24bit mantissa (which then gives an effective 25bits becasue of the hidden bit); hence the very close relationship between 24bit int and 32bit float. SO I would say the quantization is about the same (I have even heard of tricks that convert float to 24bit int by direct manipulation of the mantissa, rather than using the "proper" conversion). You will find for example that SoundForge will refer to 24bit processing, when in fact they are using 32bit floats. They say they do this deliberately to make it clear that the precision is more akin to 24bits than "real" 32. I agree there is no point in dithering to 24bit (at least from a 32bit float). You would need helium-cooled circuitry to escape the internal brownian noise of the electronics, and helium-cooled ears too to hear all the way down to -144dB, assuming you don't run it loud enough to damage your ears! Most 24bit DACs are unlikely to be truly linear down there anyway (without helium cooling...). Richard Dobson Andor wrote: ...> > 24bits two's complement is fine for storing (transfering) digital > audio - 32bit floating-point is better. The quantisation in 32bit > float is much finer than 24 (or 25) bit two's complement. If you want > to, you can add dither when converting from 32bit float to 24bit two's > complement. Your dither noise will drown in the noise floor of the > analog audio chain, it won't make much difference. > >
scorey_plonk@waterford.org wrote:> What about on the ADC stage? If the noise floor of your mics, pres > and environment is higher than the resolution of your converter > (-96dBFS for a 16 bit converter, yes?), do you need to add any > additional dither noise to the signal before conversion?The dynamic range for a 16 bit signal is ~96 dB. If you mix several digitized, noisy signals (either 16bit with an inherently higher noise floor or recordings from a mic, tape or anything else that has even more noise in it) you usually don't require extra dither noise at the output if your destination wordlength is 24 bit or higher. On average, most sampled realworld signals in the audio/music biz use at most 18-20 bits for the actual signal, so there's quite a bit of noise present already. In your DAW, you're mixing all these signals at different ratios inside a 32bit fp signal path, thereby spreading the noise over all fractions of the lowest few of your 24 output bits. This effectively "auto-dithers" the signal with a Gaussian PDF noise. Even though the Gaussian PDF isn't an ideal one for that purpose, adding even more noise with a triangular PDF doesn't change much in that case, except that it degrades the SNR further. --smb
In article <laake0140klhjulfushvkakeu43gl2g1i2@4ax.com>, ben_nospam_bradley@mindspring.com says...> If you're going from a analog into a "less-than-ideal" (16 bits or > less) A/D, adding noise for dither can help. An A/D converter is a > "bit-reduction" device that goes from lots of bits (infinite if you > listen to some people argue it) down to 16 bits, or however many bits > it gives. Here are my "usual links," the first involving A/D's, the > second descriobes dither totally in the "digital domain" [pun on the > name of the firm]: > > http://www.national.com/an/AN/AN-804.pdf(I had always thought of analog as having "infinite bits." is that not a useful way of looking at it?) The pdf article states that in an ADC if the signal is at an amplitude of more than 10 bits above the LSB, then dither gives you no advantage in the dither-noise vs. distortion tradeoff. Is this true when dithering a digital signal when reducing bit-depth? It seems like it would be...
