Hi, This is a beamforming question, but I thought perhaps some of the SP people might know the answer to this question, as it is a commonly enough occurring term in SP applications. I am a mathematician working on some interferometric problems, and I find myself having trouble getting an actual definition of "direction of arrival" (or DOA). Some older analyses using linear antenna arrays seem to use the inclination angle, theta, (i.e. the angle with the +z-axis or "azimuthal angle") for the DOA, but for a source that is not coplanar with the array, there is a factor of Cos(phi) in the phase portion of the steering vector (where phi is the angle with the +x-axis or polar angle). Some analyses seem to define a generic phase angle from the inner product of the source orientation with the array position vector. This definition is consistent for a linear array, but it is not for a planar array. Is there a rigorous definition of what is meant for "direction of arrival" (or angle of arrival) that holds for a general array and source? You can respond directly to this post or via my e-mail address. TIA, Matt
Is there an actual definition for "direction of arrival"?
Started by ●April 25, 2006
Reply by ●April 25, 20062006-04-25
Brenneman skrev:> Hi, > > This is a beamforming question, but I thought perhaps some of the SP > people might know the answer to this question, as it is a commonly > enough occurring term in SP applications. > I am a mathematician working on some interferometric problems, and I > find myself having trouble getting an actual definition of "direction > of arrival" (or DOA). > > Some older analyses using linear antenna arrays seem to use the > inclination angle, theta, (i.e. the angle with the +z-axis or > "azimuthal angle") for the DOA, but for a source that is not coplanar > with the array, there is a factor of Cos(phi) in the phase portion of > the steering vector (where phi is the angle with the +x-axis or polar > angle).In the case of the linear array and point source, the analysis is done in the plane defined by the line of the array, and the point source. In certain practical applications, this definition is somewhat arbitrarily expanded to include a medium of some thickness. In passive sonar, for instance, DoA is usually refered to the horizontal plane, depth information is seldom included.> Some analyses seem to define a generic phase angle from the inner > product of the source orientation with the array position vector. This > definition is consistent for a linear array, but it is not for a planar > array.Correct. For planar arrays one needs to define an (azimuth, elevation) pair of angles.> Is there a rigorous definition of what is meant for "direction of > arrival" (or angle of arrival) that holds for a general array and > source? You can respond directly to this post or via my e-mail address.Not other than the geometrical references. When the physical position and orientation of the array is known, one wants to detect what (azimuth,elevation) direction a signal arrives from. I am not aware of any generic mathematical definitions of the DoA. Rune
Brenneman wrote:> Hi, > > This is a beamforming question, but I thought perhaps some of the SP > people might know the answer to this question, as it is a commonly > enough occurring term in SP applications. > I am a mathematician working on some interferometric problems, and I > find myself having trouble getting an actual definition of "direction > of arrival" (or DOA). > > Some older analyses using linear antenna arrays seem to use the > inclination angle, theta, (i.e. the angle with the +z-axis or > "azimuthal angle") for the DOA, but for a source that is not coplanar > with the array, there is a factor of Cos(phi) in the phase portion of > the steering vector (where phi is the angle with the +x-axis or polar > angle). > > Some analyses seem to define a generic phase angle from the inner > product of the source orientation with the array position vector. This > definition is consistent for a linear array, but it is not for a planar > array. > > Is there a rigorous definition of what is meant for "direction of > arrival" (or angle of arrival) that holds for a general array and > source? You can respond directly to this post or via my e-mail address. > > TIA,DoA makes sense when the receiving antenna subtends an infinitesimal angle at the source and the source subtends an infinitesimal angle at the receiving antenna. The mathematics becomes very complex otherwise. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●April 26, 20062006-04-26
> > DoA makes sense when the receiving antenna subtends an infinitesimal > angle at the source and the source subtends an infinitesimal angle at > the receiving antenna. The mathematics becomes very complex otherwise. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AFHi Jerry, Thank you for your response. Let me ask you one follow up question to make sure I understand what you are saying. I am interested in antenna arrays in the far-field of point sources that emit plane wave radiation (like a GPS source for example). I am wondering if this is the same context to which you are referring. When you say that BOTH source and receiver "subtend an infinitesimal angle" with respect to each other, the only scenario I can envision that fits that criertion is perhaps when the source is on the horizon, so that the angle to which you are referring is essentially the complement of theta. Even then, I still don't understand what is meant by the reciever subtending a small angle wrt the source. If the source emits plane radiation, in the far-field approximation we think of the relative geometrical relationship of antenna and source as being characterized by a single line from the point source to some fixed point wrt the array (i.e. origin). I don't understand where the "other side" that would define an angle comes from. Sorry if this seems like a dumb question or if I seem a bit slow: I'm new to this field, and I guess I'm a stickler for getting down things like definitions (occupational hazard, I guess). Thanks again, Matt
Brenneman wrote:>>DoA makes sense when the receiving antenna subtends an infinitesimal >>angle at the source and the source subtends an infinitesimal angle at >>the receiving antenna. The mathematics becomes very complex otherwise. >> >>Jerry >>-- >>Engineering is the art of making what you want from things you can get. >>�� > > > Hi Jerry, > > Thank you for your response. Let me ask you one follow up question to > make sure I understand what you are saying. > I am interested in antenna arrays in the far-field of point sources > that emit plane wave radiation (like a GPS source for example). I am > wondering if this is the same context to which you are referring.Yes> When > you say that BOTH source and receiver "subtend an infinitesimal angle" > with respect to each other, the only scenario I can envision that fits > that criertion is perhaps when the source is on the horizon, so that > the angle to which you are referring is essentially the complement of > theta. Even then, I still don't understand what is meant by the > reciever subtending a small angle wrt the source. If the source emits > plane radiation, in the far-field approximation we think of the > relative geometrical relationship of antenna and source as being > characterized by a single line from the point source to some fixed > point wrt the array (i.e. origin). I don't understand where the "other > side" that would define an angle comes from. > Sorry if this seems like a dumb question or if I seem a bit slow: I'm > new to this field, and I guess I'm a stickler for getting down things > like definitions (occupational hazard, I guess).Knowing what we -- and the other guy -- means is a always a good thing. I meant that the transmitter seems like a point source to the receiver, and that it is sufficiently remote that the bearing to it is the same from every point on the receiving array. If these conditions are met, they would also be met if the role of receiver and transmitter were interchanged. "Plane wave" encompasses these conditions, but doesn't serve well as a definition. "Point source" and "plane wave" are in fact mutually contradictory, but serve well as local approximations. A true plane wave doesn't have inverse-square intensity. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Brenneman skrev:> > > > DoA makes sense when the receiving antenna subtends an infinitesimal > > angle at the source and the source subtends an infinitesimal angle at > > the receiving antenna. The mathematics becomes very complex otherwise. > > > > Jerry > > -- > > Engineering is the art of making what you want from things you can get. > > =AF=AF > > Hi Jerry, > > Thank you for your response. Let me ask you one follow up question to > make sure I understand what you are saying. > I am interested in antenna arrays in the far-field of point sources > that emit plane wave radiation (like a GPS source for example).These are contradictions in terms. The frame of refernce is the reciever system. A "point source" is a source which is so small that it resembles a point when viewed from the reciever. A simple example is a star shining in the sky. It resembles a point. Good examples of "distributed sources" are the sun and the moon, that have clear angular extents. A "point source" emits a spherical or cylindrical wave, which energy dilutes as function of traveled distance. Also, the local curvature of the wave front reduces as the distance to the source increases. At some distance there is no point in dealing with local curvature, and the plane wave approximation is used instead.> I am > wondering if this is the same context to which you are referring. When > you say that BOTH source and receiver "subtend an infinitesimal angle" > with respect to each other, the only scenario I can envision that fits > that criertion is perhaps when the source is on the horizon, so that > the angle to which you are referring is essentially the complement of > theta.The source is never a point source, it has some physical extension. However, for the far field to be valid, the angular extension of that source, when viewed from the reciever, must be infitesimal. Again, a star as example. The star Betelgeuze has a diameter on the order of the diameter of the earth's orbit around the sun http://en.wikipedia.org/wiki/Betelgeuze. Nevertheless, when viewed from earth, it is seen as just a point. Rune
> > I meant that the transmitter seems like a point source to the receiver, > and that it is sufficiently remote that the bearing to it is the same > from every point on the receiving array. If these conditions are met, > they would also be met if the role of receiver and transmitter were > interchanged.Thank you for the explanation: I understand exactly what you mean now and the distinction you make is an important one. Since the case to which you are referring is the one of interest to me let me go back to your first post now. When you say that the "DOA makes sense" under these conditions, what do YOU mean by DOA: the two spherical coordinate angles (phi,theta)? Thanks, Matt
Brenneman skrev:> > > > I meant that the transmitter seems like a point source to the receiver, > > and that it is sufficiently remote that the bearing to it is the same > > from every point on the receiving array. If these conditions are met, > > they would also be met if the role of receiver and transmitter were > > interchanged. > > Thank you for the explanation: I understand exactly what you mean now > and the distinction you make is an important one. Since the case to > which you are referring is the one of interest to me let me go back to > your first post now. When you say that the "DOA makes sense" under > these conditions, what do YOU mean by DOA: the two spherical coordinate > angles (phi,theta)?Don't know about Jerry, but *I* think of the pair of angles (phi, theta) as the DoA in the case of the planar array. Rune
Reply by ●April 27, 20062006-04-27
Jerry Avins wrote:> I meant that the transmitter seems like a point source to the receiver, > and that it is sufficiently remote that the bearing to it is the same > from every point on the receiving array. If these conditions are met, > they would also be met if the role of receiver and transmitter were > interchanged. "Plane wave" encompasses these conditions, but doesn't > serve well as a definition. "Point source" and "plane wave" are in fact > mutually contradictory, but serve well as local approximations. A true > plane wave doesn't have inverse-square intensity. >Jerry, Another way of looking at it is this: Those two terms: "point source" and "plane wave" are not mutually contradictory if you take into account the 'optical' location of the source. If you trace back the 'nearly' plane-wave radiated by a large dish or array, the wave appears to be coming from a point that is located well behind the antenna. The less curvature you have on that wave-front the further behind the antenna the source appears to be. In the case of a theoretical-perfect plane-wave, the source appears to be located at an infinite distance behind the antenna aperture. As the apparent distance between the signal source and the receiving antenna is already infinite it is not possible to change this distance to any significant degree by changing the physical separation between the antennas. The inverse-square law is working correctly when it shows us that there is no change in received signal under these circumstances. Regards, John
Brenneman wrote:>>I meant that the transmitter seems like a point source to the receiver, >>and that it is sufficiently remote that the bearing to it is the same >>from every point on the receiving array. If these conditions are met, >>they would also be met if the role of receiver and transmitter were >>interchanged. > > > Thank you for the explanation: I understand exactly what you mean now > and the distinction you make is an important one. Since the case to > which you are referring is the one of interest to me let me go back to > your first post now. When you say that the "DOA makes sense" under > these conditions, what do YOU mean by DOA: the two spherical coordinate > angles (phi,theta)?Matt, I'm sorry I didn't get back to you sooner. Two linear antenna arrays are needed to get two angles. (Of course, a plane structure serves also.) The best illustration of the One-dimensional situation I can think of is the usual freshman physics explanation of a diffraction grating. That explanation also makes clear why an extended line of closely spaces antennas reduces ambiguity (sidelobes). Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
