Hi~ everybody~ I have one thing about OFDM to want to know. In general OFDM system, DC sub-carrier is not used, that is, null is inserted there. Suddenly I come to curious about the reason. According to the some documents that I found in the web, the reason is due to direct conversion which cannot pass DC component. Is it correct? and is it the only reason why DC sub-carrier was stuffed with zero? Any response would be helpful to me. Thanks for reading and have a nice day! - Mabinogi -
OFDM uses null DC. Why?
Started by ●April 25, 2006
Reply by ●April 26, 20062006-04-26
The reason is that you can remove the DC offset by applying a DC blocking filter since there is no information around DC. The DC offset is a very big problem in receiver design and it is much larger in Direct-Conversion receiver. Mabinogi =E5=AF=AB=E9=81=93=EF=BC=9A> Hi~ everybody~ > > I have one thing about OFDM to want to know. > > In general OFDM system, DC sub-carrier is not used, that is, null is > inserted there. > Suddenly I come to curious about the reason. > According to the some documents that I found in the web, the reason is > due to direct conversion which cannot pass DC component. > > Is it correct? > and is it the only reason why DC sub-carrier was stuffed with zero? > > Any response would be helpful to me. >=20 > Thanks for reading and have a nice day! >=20 > - Mabinogi -
