Hello All, After Block based FFT an overlap is done between blocks to remove block artifacts. But my query is if i perform FFT on 512 block of data, i get 512 freq samples output. If i continue this for 10 blocks i will get 512 * 10 samples in freq samples then how can perform overlab of the block? if i do i will be loosing data also and aliasing will be thr. Can any one explain how to perform overlap of block after FFT? and also other advantages of it. Rgds -Prasad
need FFT Overlap
Started by ●April 26, 2006
Reply by ●April 26, 20062006-04-26
Prasad wrote:> Hello All, > > After Block based FFT an overlap is done between blocks to remove > block artifacts. But my query is if i perform FFT on 512 block of > data, i get 512 freq samples output. If i continue this for 10 blocks i > will get 512 * 10 samples in freq samples then how can perform overlab > of the block? if i do i will be loosing data also and aliasing will be > thr. > > Can any one explain how to perform overlap of block after FFT? and > also other advantages of it.We have done this a couple of times, for example here (also view the follow up messages): http://groups.google.ch/group/comp.dsp/msg/7585d35fd4ba3693 Online documentation of overlap-add and -save methods can be viewed, for example, here: http://www.dspguide.com Regards, Andor
