Dear members, I work on magneto-optical imaging (MOIF) of magnetic nanostructures. To compare exact calculations of magnetic field distributions with experimental data, I want to perform some low-pass filtering on my theoretical simulations. As a first try I convolved my data with a gaussian kernel via complex multiplication in fourier domain using 2D complex-to-complex dft (FFTW release 3.1.1 included in C++ code; g++ compiler on Unix system). My data is represented as a greyscale image (grey value corresponds to magnetic field strength), e.g. a bright (i.e magnetized) quadratic pattern in a dark (i.e. nonmagnetic) surrounding. For the convolution I centered such a quadratic pattern and a normalized gaussian bell each on a 1000x1000 point grid, performed the forward trafos, complex multiplication and subsequent back trafo. The output shows the favoured features like an unsharpening of the pattern's edges, but two problems occur: - the original pattern is cut in four congruent pieces, each of them displaced to one corner of the underlying grid - the outcoming field strengths, i.e. the intensity of the greyscale image is several orders of magnitude too large, even though I scaled the output with 1/(N*N) (where N=1000 is the number of grid points per axis). I feel like this point has something to do with the chosen variance of the normalized gaussian. I'd be very thankful for any help with this. Greetings, J.Norpoth
Low-pass filtering via FFTW: artefacts and wrong scaling
Started by ●April 27, 2006
Reply by ●April 27, 20062006-04-27
"norpoth" <norpoth@ump.gwdg.de> wrote in message news:v7SdnenlaPl1T83ZnZ2dnUVZ_sKdnZ2d@giganews.com...> Dear members, > I work on magneto-optical imaging (MOIF) of magnetic nanostructures. To > compare exact calculations of magnetic field distributions with > experimental data, I want to perform some low-pass filtering on my > theoretical simulations. As a first try I convolved my data with a > gaussian kernel via complex multiplication in fourier domain using 2D > complex-to-complex dft (FFTW release 3.1.1 included in C++ code; g++ > compiler on Unix system). > > My data is represented as a greyscale image (grey value corresponds to > magnetic field strength), e.g. a bright (i.e magnetized) quadratic pattern > in a dark (i.e. nonmagnetic) surrounding. For the convolution I centered > such a quadratic pattern and a normalized gaussian bell each on a > 1000x1000 point grid, performed the forward trafos, complex multiplication > and subsequent back trafo. > > The output shows the favoured features like an unsharpening of the > pattern's edges, but two problems occur: > > - the original pattern is cut in four congruent pieces, each of them > displaced to one corner of the underlying grid > > - the outcoming field strengths, i.e. the intensity of the greyscale image > is several orders of magnitude too large, even though I scaled the output > with 1/(N*N) (where N=1000 is the number of grid points per axis). I feel > like this point has something to do with the chosen variance of the > normalized gaussian.Maybe this thread will give you some hints: http://groups.google.com/group/comp.dsp/browse_thread/thread/e3c0bcc5bd09ae7c/3a37e015d004f554?lnk=st&q=comp.dsp+%22Fred+Marshall%22+gaussian+image&rnum=3&hl=en#3a37e015d004f554
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:-e6dnfGoRbkhQM3ZRVn-sg@centurytel.net...> > Maybe this thread will give you some hints: > > http://groups.google.com/group/comp.dsp/browse_thread/thread/e3c0bcc5bd09ae7c/3a37e015d004f554?lnk=st&q=comp.dsp+%22Fred+Marshall%22+gaussian+image&rnum=3&hl=en#3a37e015d004f554 >I might have also said: I'm going to assume that nonvarying energy is in the middle of the grid (around 500,500). For me, it's just that much easier to deal with the information - to read it and visualize it, to plot it, etc. This requires that you do a "shift" in the frequency domain: See: http://www.mathworks.com/access/helpdesk/help/techdoc/ref/fftshift.html Then, you apply a lowpass filter with a peak, the passband, at the *center* of the frequency array. Where scaling is concerned you may want the Gaussian in frequency to be normalized so that it has a peak of 1.0 at the center - thus not changing the energy of components at low frequencies. Then you shift the information back before the ifft. Or, it may be more efficient to do this: Get the filter you want, centered at 500,500. Then shift the filter and use its shifted version on non-shifted data ffts. You can work out the details and test it. Then, with FFTW, you have to do all the scaling - as it does none I believe. This could mean scaling by 1/N^2 with the ifft. Or it could mean scaling by 1/N in the forward fft and in the ifft. NOTE: these apply to 2D and not 1D! Fred
Reply by ●April 28, 20062006-04-28
Thanks for the quick answer. Since we have a public holiday here in Germany I won't give it a go until next week. I'll report on progress. Greetings, J.Norpoth
Reply by ●May 4, 20062006-05-04
Hello, the first problem is solved. After performing the pointwise complex multiplication of the two convolution partner in fourier domain I had to multiply each of these products by (-1)^(i+j), where i,j label the respective position on the underlying NxN grid. According to the FFTW FAQ (Question 3.10) this trick has to be applied to the input of a forward trafo to shift the zero-frequency component to the center of the output and it seems to work in the other direction too. Unfortunately the scaling problem remains. Greetings, J.Norpoth
Reply by ●June 28, 20122012-06-28
