"Rune Allnor" <allnor@tele.ntnu.no> wrote in message news:1146219830.185098.304600@g10g2000cwb.googlegroups.com...> > Clay S. Turner wrote: >> "thom" <soniceric@hotmail.com> wrote in message >> news:svKdna87uJkuTM3ZnZ2dnUVZ_tmdnZ2d@giganews.com... >> > Hi, >> > >> > I would like to know if you think it's possible to implement a noise >> > reduction system in every receivers with spectral subtraction method >> > (for >> > example could it reduce noise in a signal with a bandwith of 10MHz at a >> > frequency of 500MHz)? >> > >> > Thank you >> > >> > Thom >> >> Hello Thom, >> >> Basically all receivers employ noise reduction via spectral subtraction. >> The >> preselect and IF filters do exactly this. > > Hmmm.... I may be splitting hairs here, but I think this at best is a > gross > oversimplification; at worst it is plain wrong. > > A filter does not *subtract* noise from a frequency band. It > *mutliplies* > the noise inside that band wit a factor H(w) << 1. The difference is > that > with multiplication, you don't need to know the amplitude of the > noise, whaile if you want to subtract in spectrum domain, you both > need to know the amplitude and the phase, or you will de facto > *add* noise to your signal. > > So spectrum subtraction is not a very good way to do things. > > Rune >Hello Rune and others, The interpretation of my answers depends of what exactly "spectral subtraction" means. Certainly in receiver design one places filters which either absorb or reflect incoming energy based upon frequency. So if a receiver has a bandwidth at any point wider than the channel of interest, then one admits extra noise. This can be common Johnson noise or man made noise. So my saying that using filters for noise reduction based upon spectral subtraction is correct in than the receiver's bandwidth gets reduced to the channel of interest so out of band noise is excluded. Hence the out of band spectrum's energy is subtracted from the total. Imagine putting wideband noise into a cavity filter. The power coming out the other end is reduced mostly because out of band power is reflected back towards the input. The inband portion is barely affected. For example standard cavity filters have an in-band insertion loss of around 1dB. Some super conducting ones are around 0.1 dB insertion loss. Now once someone has zoomed in to just look at a channel of interest, then further filtering in that channel while removing noise will also likely remove information. So this is generally not done although some spread spectrum methods will do this with dynamic filtering. This works by having the signal not occupy the whole channel at any one time. And this is likely the situation the OP referred to, but his question was quite general so I gave a quite general answer hoping he would father refine his question. Clay
Spectral subtraction
Started by ●April 27, 2006
Reply by ●April 28, 20062006-04-28
