Hallo, I'm simulating a transmission line with FD-TD. I have to compute the numerical transfer function of the simulated line, which is dispersive, with a gaussian pulse stimulus. To do that I compute the fft of gaussian pulse before puttin it into line (easy: I exactly know how long it is in time), then after some propagation, and then compute H(f)=V(f,out)/V(f,in). My question is: after propagating a bit, the pulse is wider in time.. how can I take into account this when computing fft? is there a sort of threshold I can apply? thanx in advance
Computing a transfer function (dispersive tx line)
Started by ●May 3, 2006
Reply by ●May 3, 20062006-05-03
Gianguido wrote:> Hallo, > I'm simulating a transmission line with FD-TD. I have to compute the > numerical transfer function of the simulated line, which is dispersive, > with a gaussian pulse stimulus. To do that I compute the fft of gaussian > pulse before puttin it into line (easy: I exactly know how long it is in > time), then after some propagation, and then compute H(f)=V(f,out)/V(f,in). > My question is: after propagating a bit, the pulse is wider in time.. > how can I take into account this when computing fft? is there a sort of > threshold I can apply? > > thanx in advanceThe time dispersal is part of the system behavior, you don't want to throw it away. Why don't you use a sinusoidal input, and look at the magnitude and phase of the sinusoidal output? That will give you H(f) directly. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
Reply by ●May 4, 20062006-05-04
> The time dispersal is part of the system behavior, you don't want to throw > it away.yes, that's the point: maybe I'll try a fft of the whole signal vector in space at the desired time T. This way I should get the effective H(f)> Why don't you use a sinusoidal input, and look at the magnitude and phase > of the sinusoidal output? That will give you H(f) directly.Such a way is good, but to get a wideband H(f) I should run a lot of simulations, one for every frequency of the observation band. That's why I wanted to use a wideband pulse such gaussian, to get all information in one step thanx
Gianguido wrote:>> The time dispersal is part of the system behavior, you don't want to >> throw it away. > > > yes, that's the point: maybe I'll try a fft of the whole signal vector > in space at the desired time T. This way I should get the effective H(f)Not if the line is dissipative -- in a non dissipative line you could do that, though.> >> Why don't you use a sinusoidal input, and look at the magnitude and >> phase of the sinusoidal output? That will give you H(f) directly. > > > Such a way is good, but to get a wideband H(f) I should run a lot of > simulations, one for every frequency of the observation band. That's why > I wanted to use a wideband pulse such gaussian, to get all information > in one step >If you're determined to do it using an FFT then all I can suggest is that you make your simulation long enough to capture a good long bit of the tail as the thing settles out, and window the data with something that prevents the very end from getting chopped off -- I'd use a constant that transitions to a raised cosine at the very end of the time sample. No matter what you do you're going to find inaccuracies at the high-frequency end where there's not much signal content from the cable and lots of windowing effects from the finite measurement interval. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
> Not if the line is dissipative -- in a non dissipative line you could do > that, though.sure, I didn't say.. non dissipative is my case.> If you're determined to do it using an FFT then all I can suggest is > that you make your simulation long enough [...]thanx for your tips, Tim! now implementation time ;) bye
Gianguido wrote:>> Not if the line is dissipative -- in a non dissipative line you could >> do that, though. > > > sure, I didn't say.. non dissipative is my case.I was seeing "dispersive" and making it into "dissipative". I think that looking at the volts/position relationship is still not valid in a dispersive line, however.> >> If you're determined to do it using an FFT then all I can suggest is >> that you make your simulation long enough [...] > > > thanx for your tips, Tim! now implementation time ;) > > byeLet us know how it works out. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
