Hi Do you if there is a toolbox or function to generate noise which is received after a RF transmission (a model of external noise with man-made noise, galactic noise, noise due to attenuation and noise due to lightning discharges)? Thank you
External noise generation with Matlab
Started by ●May 4, 2006
Reply by ●May 4, 20062006-05-04
"thom" <soniceric@hotmail.com> wrote in message news:hd2dnZOmbbF7ZsTZnZ2dnUVZ_vqdnZ2d@giganews.com...> Hi > > Do you if there is a toolbox or function to generate noise which is > received after a RF transmission (a model of external noise with man-made > noise, galactic noise, noise due to attenuation and noise due to lightning > discharges)? > > Thank you"wgn" perhaps? I'm not familiar with "noise due to attenuation" - maybe you can explain what that is.... fred
Reply by ●May 5, 20062006-05-05
>"wgn" perhaps? > >I'm not familiar with "noise due to attenuation" - maybe you can explain>what that is.... > >fredWell, we often model noise received after a wireless transmission by Additive White Gaussian Noise. Actually in the HF band noise from electric discharge in the atmosphere is dominant; then for frequencies between 20Mhz to 1GHz, it is noise from space (galactic noise); for frequency up to 1GHz thermal noise due to atmospheric attenuation is the dominant noise source. You can add noise due to human activity. I would like to model this noise, not only with White Noise if it's possible. Maybe someone knows if it is??
>Hi > >Do you if there is a toolbox or function to generate noise which is >received after a RF transmission (a model of external noise withman-made>noise, galactic noise, noise due to attenuation and noise due tolightning>discharges)? > >Thank you >Do you want to model the noise or generate a RF noise? In both cases I would first generate a pseudo random complex waveform in baseband for the desired noise according to its stochastic characteristics. If the latter is known it's not difficult to program by e.g. Matlab, C or C++. Then the waveform can be loaded into a general purpose signal generator and modulated to the band of interest. That's it.
>Do you want to model the noise or generate a RF noise? In both cases I >would first generate a pseudo random complex waveform in baseband forthe>desired noise according to its stochastic characteristics. If the latter >is known it's not difficult to program by e.g. Matlab, C or C++. Thenthe>waveform can be loaded into a general purpose signal generator and >modulated to the band of interest. That's it. >I would like to generate a noise with Matlab which could look like noise that an antenna receives (not only a white gaussian noise which is an approximation). Then this noise will be added to a signal, to simulate noise reduction methods.
How about design a filter that has the same PSD as your noise and then use that filter on a AWGN sequence?
thom wrote: ...> ... for frequencies between 20Mhz > to 1GHz, it is noise from space (galactic noise) ...You never spent much time on the 10- and 6-meter ham bands, or tuned to an unused television channel. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
