Hello,
I am new to Kalman filters but know the basics fairly well. I have a
device that will be pulled behind a boat (in the y direction) with several
accelerometers and a few gyros - I implemented the linear discrete Kalman
filter but got a terrible integration offset because obviously I have to
integrate the accelerometers twice and the gyros once with the transition
matrix A, state vector xk, control matrix B and control vector u:
1 T 0 0 0 0 0 0 0 x
0 1 0 0 0 0 0 0 0 x_dot
0 0 1 T 0 0 0 0 0 y
A = 0 0 0 1 0 0 0 0 0 xk = y_dot
0 0 0 0 1 T 0 0 0 z
0 0 0 0 0 1 0 0 0 z_dot
0 0 0 0 0 0 1 0 0 phi_x
0 0 0 0 0 0 0 1 0 phi_y
0 0 0 0 0 0 0 0 1 phi_z
0 0 0 0 0 0 0 0 0 0
0 T 0 0 0 0 0 0 0 x_dot_dot
0 0 0 0 0 0 0 0 0 0
0 0 0 T 0 0 0 0 0 y_dot_dot
B = 0 0 0 0 0 0 0 0 0 uk = 0
0 0 0 0 0 T 0 0 0 z_dot_dot
0 0 0 0 0 0 T 0 0 phi_x_dot
0 0 0 0 0 0 0 T 0 phi_y_dot
0 0 0 0 0 0 0 0 T phi_z_dot
The uk vector is also the measurement vector zk, as the accelerations and
changes in angle are the sensor outputs I am reading from.
I cannot understand how to change this to conform with the EXTENDED kalman
filter, as I assume this would eliminate the integration offset. I am not
yet looking to translate from the free body frame to the navigation frame
or anything - shouldn't this be simple?!
I am so confused,
any help would be SO appreciated -
you Kalman dudes are amazing.
Ellie
EKF for a basic underwater navigation situation
Started by ●May 7, 2006
Reply by ●May 7, 20062006-05-07
Sorry - the matrices got all screwed up:>1 T 0 0 0 0 0 0 0 > 0 1 0 0 0 0 0 0 0 > 0 0 1 T 0 0 0 0 0 >A = 0 0 0 1 0 0 0 0 0 > 0 0 0 0 1 T 0 0 0 > 0 0 0 0 0 1 0 0 0 > 0 0 0 0 0 0 1 0 0 > 0 0 0 0 0 0 0 1 0 > 0 0 0 0 0 0 0 0 1 > > 0 0 0 0 0 0 0 0 0 > 0 T 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 0 > 0 0 0 T 0 0 0 0 0 >B = 0 0 0 0 0 0 0 0 0 > 0 0 0 0 0 T 0 0 0 > 0 0 0 0 0 0 T 0 0 > 0 0 0 0 0 0 0 T 0 > 0 0 0 0 0 0 0 0 T >Ellie
Check http://www.taygeta.com/kalman.html http://www.cs.unc.edu/~tracker/media/pdf/SIGGRAPH2001_CoursePack_08.pdf In article <25WdnY1nEPRJesDZnZ2dnUVZ_vWdnZ2d@giganews.com>, "elspeth" <v_enusinfurs@yahoo.co.nz> wrote:>Hello, >I am new to Kalman filters but know the basics fairly well. I have a >device that will be pulled behind a boat (in the y direction) with several >accelerometers and a few gyros - I implemented the linear discrete Kalman >filter but got a terrible integration offset because obviously I have to >integrate the accelerometers twice and the gyros once with the transition >matrix A, state vector xk, control matrix B and control vector u: > > 1 T 0 0 0 0 0 0 0 x > 0 1 0 0 0 0 0 0 0 x_dot > 0 0 1 T 0 0 0 0 0 y >A = 0 0 0 1 0 0 0 0 0 xk = y_dot > 0 0 0 0 1 T 0 0 0 z > 0 0 0 0 0 1 0 0 0 z_dot > 0 0 0 0 0 0 1 0 0 phi_x > 0 0 0 0 0 0 0 1 0 phi_y > 0 0 0 0 0 0 0 0 1 phi_z > > 0 0 0 0 0 0 0 0 0 0 > 0 T 0 0 0 0 0 0 0 x_dot_dot > 0 0 0 0 0 0 0 0 0 0 > 0 0 0 T 0 0 0 0 0 y_dot_dot >B = 0 0 0 0 0 0 0 0 0 uk = 0 > 0 0 0 0 0 T 0 0 0 z_dot_dot > 0 0 0 0 0 0 T 0 0 phi_x_dot > 0 0 0 0 0 0 0 T 0 phi_y_dot > 0 0 0 0 0 0 0 0 T phi_z_dot > >The uk vector is also the measurement vector zk, as the accelerations and >changes in angle are the sensor outputs I am reading from. > >I cannot understand how to change this to conform with the EXTENDED kalman >filter, as I assume this would eliminate the integration offset. I am not >yet looking to translate from the free body frame to the navigation frame >or anything - shouldn't this be simple?! > >I am so confused, >any help would be SO appreciated - >you Kalman dudes are amazing. >Ellie > >
Reply by ●May 8, 20062006-05-08
"elspeth" <v_enusinfurs@yahoo.co.nz> wrote in message news:25WdnY1nEPRJesDZnZ2dnUVZ_vWdnZ2d@giganews.com...> Hello, > I am new to Kalman filters but know the basics fairly well. I have a > device that will be pulled behind a boat (in the y direction) with several > accelerometers and a few gyros -You'd better watch that the EKF doesn't get wet. They don't perform well when they're wet. M.P
