Spectrum of audio data
Started by Unknown ●May 10, 2006
robert bristow-johnson wrote:
> i think that should be " 10*log10(abs^2) " where abs^2 = Re^2 + Im^2 . >
Yes, of course. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Anything is possible if you don't know what you are talking about.
Hi Stereo,
    The procedure what i have followed is i have read the PCM samples
from the wave file passed throught the Hanning window and taken FFT of
it and then computed the spectrum so i think here there is no need to
take care of conversion to dB SPL.
  i will try some more audio files.
Rgds
-Prasad
<mailprassi@gmail.com> wrote in message
news:1147237208.666338.272260@j73g2000cwa.googlegroups.com...
> Dear All, > > i want to do a spectrum plot of audio data, for this i am doing > like this > 1. Taking the FFT of the data; > 2. Finding the absolute(magnitude) of the fft output abs = > (sqrt(Re^2 + Im^2)). > 3. Then i am normalizing Norm = (2 * abs )/N) where N is FFT Length. > 4. I am taking 20 * log10(Norm). > > when i check the values i am getting spectrum values more -120 dB > like -132dB. > > My query is > 1. Can the spectrum of audio can be more than -120dB > 2. Is the normalization what i am doing is right. > > Please help me out, > Thanks a lot in advance, > With warm regards, > -Prasad B C >
dB is a relative measure. On it's own it means nothing - you need something to compare it with. M.P *** Posted via a free Usenet account from http://www.teranews.com ***
Mad Prof wrote:
> > dB is a relative measure. On it's own it means nothing - you need something > to compare it with.
that true, strictly speaking. but they have defined reference voltages and SPL levels. you know, the "dBFS" and "dBv" and "dBu", the 1 mW into 600 ohms thingie, and the threshold of hearing at 1 kHz. i can never keep them straight. ~~~~
> Mad Prof wrote: > >>dB is a relative measure. On it's own it means nothing - you need something >>to compare it with. > > > that true, strictly speaking. but they have defined reference voltages > and SPL levels. you know, the "dBFS" and "dBv" and "dBu", the 1 mW > into 600 ohms thingie, and the threshold of hearing at 1 kHz. i can > never keep them straight.
SPL is standardized on acoustic pressure in air. Conversion to voltage is a matter of calibrating the microphone system. 100 dB-SPL = 2 pascal = .01 watt/meter^2 in air. http://www.sengpielaudio.com/calculator-soundlevel.htm Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
That's wrong. 2 pascal = 100 dB-SPL (sound pressure level) .01 watt/meter^2 = 100 dB-SIL (sound intensity level) Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Jerry Avins <jya@ieee.org> wrote in
news:2f2dnXn2247bVfnZnZ2dnUVZ_sGdnZ2d@rcn.net:
> I wrote: > >> 100 dB-SPL = 2 pascal = .01 watt/meter^2 in air. > > That's wrong. > 2 pascal = 100 dB-SPL (sound pressure level) > .01 watt/meter^2 = 100 dB-SIL (sound intensity level) > > Jerry
dB(SPL) is sometimes written dBre20uPa. You will also see dB(A) for sound pressure level. This is db(SPL) with A Weighting. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
